Forwarding Policy
Overview
You can configure forwarding policies for HTTP and HTTPS listeners to forward requests to different backend server groups based on domain names or paths.
A forwarding policy consists of two parts: forwarding rule and action. For details, see Table 1.
| Policy Type | Forwarding Rules | Actions |
| Forwarding policy | Domain name and Path | Forward to a backend server group and Redirect to another listener (only for HTTP listeners) |
| Advanced forwarding policy | Domain name, Path, HTTP request method, HTTP header, Query string, and CIDR block | Forward to a backend server group, Redirect to another listener, Redirect to another URL, Rewrite, Write header, Remove header, Limit request, and Return a specific response body |
You can configure an advanced forwarding policy by referring to Managing an Advanced Forwarding Policy.
How Requests Are Matched
- After receiving a request, the load balancer attempts to find a matching forwarding policy based on the domain name or path in the request:
- If a match is found, the request is forwarded to the backend server group you select or create when you add the forwarding policy.
- If no match is found, the request is forwarded to the default backend server group that is specified when the listener is created.
- If both a domain name and path are configured for a forwarding policy, the request can match the forwarding policy only when the domain name and path are both met.
- If advanced forwarding is not enabled for a dedicated load balancer, the matching order is determined by the following rules:
- When a request matches both a domain name-based policy and a path-based policy, the domain name-based policy is matched first. Table 2 shows an example.
- Forwarding policy priorities are independent of each other regardless of domain names.
- Path-based forwarding rules are applied in the following order of priority: an exact match rule, a prefix match rule, and a regular expression match rule. For multiple matches of the same type, only the longest path rule will be applied.
| Request | Forwarding Policy | Forwarding Rule | Specified Value |
| www.elb.com/test | 1 | Path | /test |
| 2 | Domain name | www.elb.com |
In this example, although request www.elb.com/test matches both forwarding policies, it is routed based on forwarding policy 2 because domain name-based forwarding rules are applied first.
- Forwarding policies can be configured only for HTTP and HTTPS listeners.
- Forwarding policies must be unique.
- A maximum of 100 forwarding policies can be configured for a listener. If the number of forwarding policies exceeds the quota, the excess forwarding policies will not be applied.
- When you add a forwarding policy, note the following:
- The URL in a forwarding rule can contain only a path but cannot contain query strings. For example, if the path is set to /path/resource?name=value, the forwarding policy is invalid.
- Each path must exist on the backend server. If the path does not exist, the backend server will return 404 Not Found.
- In the regular expression match, the characters are matched sequentially, and the matching ends when any rule is matched. Matching rules cannot overlap with each other.
- A path cannot be configured for two forwarding policies.
- The length of each domain name cannot exceed 100 characters.
Adding a Forwarding Policy
- Go to the load balancer list page.
- On the displayed page, locate the load balancer you want to add forwarding policy for and click its name.
- On the Listeners tab, add a forwarding policy in either of the following ways:
- Locate the target listener and click Add/Edit Forwarding Policy in the Forwarding Policies column.
- Locate the target listener, click its name, and click the Forwarding Policies tab.
- Click Add Forwarding Policy. Configure the parameters based on Table 3.
- Click Save.
