Help Center/ Elastic Load Balance/ User Guide/ User Guide for Dedicated Load Balancers/ Security/ Configuring TLS Security Policies for Encrypted Communication
Updated on 2026-03-25 GMT+08:00
HTTPS encryption is commonly used for applications that require secure data transmission, such as banks and finance. ELB allows you to use common TLS security policies to secure data transmission.
When you add HTTPS and TLS listeners, you can select the default security policies or create a custom policy by referring to Creating a Custom Security Policy to improve security.
A security policy is a combination of TLS protocols of different versions and supported cipher suites.
Default Security Policies
A later TLS version ensures higher HTTPS communication security, but is less compatible with some browsers.
You can use later TLS versions for applications that require enhanced security, and earlier TLS versions for applications that need wider compatibility.
Table 1 Default security policies
Security Policy
TLS Versions
Cipher Suites
tls-1-0
TLS 1.2
TLS 1.1
TLS 1.0
  • ECDHE-RSA-AES256-GCM-SHA384
  • ECDHE-RSA-AES128-GCM-SHA256
  • ECDHE-ECDSA-AES256-GCM-SHA384
  • ECDHE-ECDSA-AES128-GCM-SHA256
  • AES128-GCM-SHA256
  • AES256-GCM-SHA384
  • ECDHE-ECDSA-AES128-SHA256
  • ECDHE-RSA-AES128-SHA256
  • AES128-SHA256
  • AES256-SHA256
  • ECDHE-ECDSA-AES256-SHA384
  • ECDHE-RSA-AES256-SHA384
  • AES128-SHA
  • AES256-SHA
tls-1-1
TLS 1.2
TLS 1.1
tls-1-2
TLS 1.2
tls-1-0-inherit
TLS 1.2
TLS 1.1
TLS 1.0
  • AES128-GCM-SHA256
  • AES256-GCM-SHA384
  • AES128-SHA256
  • AES256-SHA256
  • DHE-RSA-AES128-SHA
  • AES128-SHA
  • AES256-SHA
  • DHE-DSS-AES128-SHA
  • CAMELLIA128-SHA
  • EDH-RSA-DES-CBC3-SHA
  • DES-CBC3-SHA
  • ECDHE-RSA-RC4-SHA
  • RC4-SHA
  • DHE-RSA-AES256-SHA
  • DHE-DSS-AES256-SHA
  • DHE-RSA-CAMELLIA256-SHA
tls-1-2-strict
TLS 1.2
  • AES128-GCM-SHA256
  • AES256-GCM-SHA384
  • AES128-SHA256
  • AES256-SHA256
tls-1-0-with-1-3
TLS 1.3
TLS 1.2
TLS 1.1
TLS 1.0
  • AES128-GCM-SHA256
  • AES256-GCM-SHA384
  • AES128-SHA256
  • AES256-SHA256
  • AES128-SHA
  • AES256-SHA
  • TLS_AES_128_GCM_SHA256
  • TLS_AES_256_GCM_SHA384
  • TLS_CHACHA20_POLY1305_SHA256
  • TLS_AES_128_CCM_SHA256
  • TLS_AES_128_CCM_8_SHA256
tls-1-2-fs-with-1-3
TLS 1.3
TLS 1.2
tls-1-2-fs
TLS 1.2
tls-1-2-strict-no-cbc
TLS 1.2
The above table lists the cipher suites supported by ELB. Generally, clients also support multiple cipher suites. In actual use, the cipher suites supported both by ELB and clients are used, and the cipher suites supported by ELB take precedence.
Differences Between Default Security Policies
√ indicates the item is supported, and x indicates the item is not supported.
Table 2 Differences between TLS security policies
Security Policy
tls-1-0
tls-1-1
tls-1-2
tls-1-0-inherit
tls-1-2-strict
tls-1-0-with-1-3
tls-1-2-fs-with-1-3
tls-1-2-fs
hybrid-policy-1-0
Protocol-TLS 1.3
Protocol-TLS 1.2
Protocol-TLS 1.1
Protocol-TLS 1.0
Table 3 Differences between TLS security policies (cipher suites)
Security Policy
tls-1-0
tls-1-1
tls-1-2
tls-1-0-inherit
tls-1-2-strict
tls-1-0-with-1-3
tls-1-2-fs-with-1-3
tls-1-2-fs
hybrid-policy-1-0
AES128-GCM-SHA256
AES256-GCM-SHA384
AES128-SHA256
AES256-SHA256
AES128-SHA
AES256-SHA
DHE-RSA-AES128-SHA
DHE-DSS-AES128-SHA
CAMELLIA128-SHA
DES-CBC3-SHA
ECDHE-RSA-RC4-SHA
RC4-SHA
DHE-RSA-AES256-SHA
DHE-DSS-AES256-SHA
ECC-SM4-SM3
ECDHE-SM4-SM3
Table 4 Security policies and compatible browsers and clients
Security Policy
tls-1-0
tls-1-1
tls-1-2
tls-1-0-inherit
tls-1-2-strict
tls-1-0-with-1-3
tls-1-2-fs-with-1-3
tls-1-2-fs
hybrid-policy-1-0
Android 8.0
Android 9.0
Chrome 70 / Win 10
Chrome 80 / Win 10
Firefox 62 / Win 7
Firefox 73 / Win 10
IE 8 / XP
IE 8-10 / Win 7
IE 11 / Win 7
IE 11 / Win 10
Edge 15 / Win 10
Edge 16 / Win 10
Edge 18 / Win 10
Java 8u161
Java 11.0.3
Java 12.0.1
OpenSSL 1.0.2s
OpenSSL 1.1.0k
OpenSSL 1.1.1c
Safari 10 / iOS 10
Safari 10 / OS X 10.12
Safari 12.1.1 / iOS 12.3.1
ELB allows you to use common TLS security policies to secure data transmission. If you need to use a certain TLS version and disable some cipher suites, you can create a custom security policy and add it to an HTTPS listener to improve service security.
  1. Go to the load balancer list page.
  2. In the navigation pane on the left, choose TLS Security Policies.
  3. On the displayed page, click Create Custom Security Policy in the upper right corner.
  4. Configure the parameters based on Table 5.
    Table 5 Custom security policy parameters
    Name
    Specifies the name of the custom security policy.
    TLS Version
    Specifies the TLS versions supported by the custom security policy.
    You can select multiple versions:
    • TLS 1.0
    • TLS 1.1
    • TLS 1.2
    • TLS 1.3
    Cipher Suite
    Specifies the cipher suites that match the selected TLS versions.
    Description (Optional)
    Provides supplementary information about the custom security policy.
  5. Click OK.
Managing a Custom Security Policy
After a custom security policy is created, you can modify or delete it.
You can modify the name, TLS versions, cipher suites, and description of a custom security policy as required.
  3. On the displayed page, locate the custom security policy, and click Modify in the Operation column.
  4. In the displayed dialog box, modify the custom security policy based on Table 5.
  5. Click OK.
You can delete a custom security policy as you need.
If a custom security policy is used by a listener, it cannot be deleted. Delete the security policy from the listener first.
  3. On the displayed page, locate the custom security policy, and click Delete in the Operation column.
  4. In the displayed dialog box, click OK.
Selecting a Security Policy for an HTTPS Listener
  2. On the displayed page, locate the load balancer and click its name.
  3. On the Listeners tab, click Add Listener.
  4. On the Add Listener page, set Frontend Protocol to HTTPS.
  5. Expand More (Optional) and select a security policy.
    You can select a default security policy or custom security policy.
    If there is no custom security policy, you can create one by referring to Creating a Custom Security Policy.
  6. Confirm the configurations and go to the next step.
Changing a Security Policy for an HTTPS Listener
  3. On the Listeners tab, locate the listener, and click its name.
  4. On the Summary tab, click Edit on the top right.
  5. On the displayed page, expand More (Optional) and select a security policy.
  6. Click OK.
