Listener Overview
A listener checks requests from clients and routes requests to backend servers using the protocol, port, and load balancing algorithm you select. You need to add at least one listener after you have created a shared load balancer.
Supported Protocols
ELB provides load balancing at both Layer 4 and Layer 7. You can select TCP or UDP for load balancing at Layer 4 and HTTP or HTTPS for load balancing at Layer 7.
| Protocol | Description | Scenario | |
| Layer 4 | TCP |
| Layer 4 | UDP |
| Scenarios that require quick response, such as video chat, gaming, and real-time financial news |
| Layer 7 | HTTP |
| Web applications where data content needs to be identified, such as mobile games |
| Layer 7 | HTTPS |
| Web applications that require encrypted transmission |
Frontend Protocols and Ports
Frontend protocols and ports are used by load balancers to receive requests from clients. Load balancers use TCP or UDP at Layer 4, and HTTP or HTTPS at Layer 7. Select a protocol and a port that best suit your requirements.
The frontend protocol and port cannot be changed once a listener is added. If you want to use a different protocol and port, add another listener.
| Frontend Protocol | TCP, UDP, HTTP, and HTTPS |
| Frontend Port | Listeners using different protocols of a load balancer cannot use the same port. However, UDP listeners can use the same port as listeners that use other protocols. For example, if there is a UDP listener that uses port 88, you can add a TCP listener that also uses port 88. The port number ranges from 1 to 65535. The following are some commonly-used protocols and ports: TCP/80 HTTPS/443 |
Backend Protocols and Ports
Backend protocols and ports are used by backend servers to receive requests from load balancers. If Windows servers have Internet Information Services (IIS) installed, the default backend protocol and port are HTTP and 80.
| Backend Protocol | TCP, UDP, and HTTP |
| Backend Port | Backend servers of a load balancer can use the same port. The port number ranges from 1 to 65535. The following are some commonly-used protocols and ports: TCP/80 HTTP/443 |
