Updated on 2026-09-07 GMT+08:00
Security Group and Network ACL Rules
To ensure normal communications between the load balancer and backend servers, you need to check the security group and network ACL rules.
When backend servers receive requests from the load balancer, source IP addresses are translated into those in 100.125.0.0/16.
  • Security group rules of backend servers must allow traffic from 100.125.0.0/16 to backend servers. For details about how to configure security group rules, see Configuring Security Group Rules.
  • Network ACL rules are optional for subnets. If network ACL rules are configured for the subnet where the backend servers are deployed, the rules must allow traffic from the backend subnet of the load balancer to the subnet of the backend servers. For details about how to configure network ACL rules, see Configuring Network ACL Rules.
If Transfer Client IP Address is enabled for Layer 4 listeners, network ACL and security group rules will not take effect. You can use access control to limit which IP addresses are allowed to access the listener. Learn how to configure What Is Access Control?
  • If health check is enabled for a backend server group, security group rules must allow traffic over the health check port and protocol.
  • If UDP is used for health check, there must be a rule that allows ICMP traffic. If there is no such rule, the health of the backend servers cannot be checked.
Default Security Group Rules
Note the following when using default security group rules:
  • Inbound rules control incoming traffic to instances in the default security group. The instances can communicate with each other but cannot be accessed from external networks.
  • Outbound rules allow all traffic from the instances in the default security group to external networks.
Figure 1 Default security group
Table 1 describes the default rules for the default security group.
Table 1 Rules in the default security group
Direction
Action
Type
Protocol & Port
Source/Destination
Inbound
Allow
IPv4
All
Source: default security group (default)
Allows IPv4 instances in the security group to communicate with each other using any protocol over any port.
Inbound
Allow
IPv6
All
Allows IPv6 instances in the security group to communicate with each other using any protocol over any port.
Outbound
Allow
IPv4
All
Destination: 0.0.0.0/0
Allows all traffic from the instances in the security group to any IPv4 address over any port.
Outbound
Allow
IPv6
All
Destination: ::/0
Allows all traffic from the instances in the security group to any IPv6 address over any port.
Requirements on the Security Group Rules of Backend Servers
The default security group denies all external requests but allows all instances in the security group to access external networks. So you only need to configure inbound security group rules to allow all traffic over the health check protocol and port. If you have configured outbound security group rules, ensure that outbound traffic is allowed over the associated protocols, ports, and IP addresses.
Table 2 Security group rules for backend servers using TCP
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
Determined by the source IP address type
TCP: health check port
IP address: 100.125.0.0/16
Outbound
Allow
Table 3 Security group rules for backend servers using UDP
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
UDP: health check port
Inbound
Allow
ICMP: All
Outbound
Allow
Outbound
Allow
ICMP: All
Table 4 Security group rules for backend servers using HTTP or HTTPS
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
TCP: backend server port and health check port
Outbound
Allow
If you have no VPCs when creating a server, the system automatically creates one for you. Default security group rules allow instances in the security group to communicate with each other but block access from external networks. To ensure that the load balancer can communicate with associated backend servers over both the frontend and health check ports, configure inbound rules for the security group containing these servers.
  1. Log in to the ECS console.
  2. In the ECS list, click the name of the target ECS.
    The page providing the details about the ECS is displayed.
  3. Click the Security Groups tab, locate the security group, click its name, and view security group rules.
  4. On the Inbound Rules tab, click Add Rule. Configure inbound rules based on Table 5.
    Table 5 Security group rules
    Backend Protocol
    Action
    Protocol & Port
    Source IP Address
    HTTP
    Allow
    Protocol: TCP
    Port: the port used by the backend server and health check port
    100.125.0.0/16
    TCP
    Allow
    Protocol: TCP
    Port: health check port
    100.125.0.0/16
    UDP
    Allow
    Protocol: UDP and ICMP
    100.125.0.0/16
  5. Click OK.
To control traffic in and out of a subnet, you can associate a network ACL with the subnet. Network ACL rules control access to subnets and add an additional layer of defense to your subnets. Default network ACL rules reject all inbound and outbound traffic. If the subnet of a load balancer or associated backend servers has a network ACL associated, the load balancer cannot receive traffic from the Internet or route traffic to backend servers, and backend servers cannot receive traffic from and respond to the load balancer.
Configure an inbound network ACL rule to allow access from 100.125.0.0/16.
ELB translates the public IP addresses into private IP addresses in 100.125.0.0/16 before forwarding traffic to backend servers. So public IP addresses cannot be configured as the source for a network ACL rule to prevent public IP addresses from accessing backend servers.
Network ACL rules configured for the backend subnet of the load balancer will not restrict the traffic from the clients to the load balancer. If these rules are configured, the clients can directly access the load balancer. To control access to the load balancer, configure access control for all listeners added to the load balancer. For details, see What Is Access Control?
  2. In the upper left corner of the page, click and select the desired region and project.
  3. Choose Networking > Virtual Private Cloud.
  4. In the navigation pane on the left, choose Access Control > Network ACLs.
  5. In the network ACL list, locate the target network ACL and click its name.
  6. On the Inbound Rules or Outbound Rules tab, click Add Rule to add an inbound or outbound rule.
    • Action: Select Allow.
    • Protocol: The protocol must be the same as the backend protocol.
    • Source: Set it to 100.125.0.0/16.
    • Source Port Range: Select a port range.
    • Destination: Enter a destination address allowed in this direction. The default value is 0.0.0.0/0, which indicates that traffic to all IP addresses is permitted.
    • Destination Port Range: Select a port range.
    • (Optional) Description: Describe the network ACL rule if necessary.
  7. Click OK.
