- What's New
- Function Overview
Service Overview
- ELB Infographics
- What Is ELB?
- ELB Advantages
- How ELB Works
- Application Scenarios
- Differences Between Dedicated and Shared Load Balancers
- Load Balancing on a Public or Private Network
- Network Traffic Paths
- Specifications of Dedicated Load Balancers
- Notes and Constraints
- Security
- Permissions
- Product Concepts
- ELB and Other Services
Billing
- Billing Overview
- Billing Mode
- Billing Items (Dedicated Load Balancers)
- Billing Items (Shared Load Balancers)
- Billing Examples
- Bills
- Arrears
- Stopping Billing
- Cost Management
- When Do I Need Public Bandwidth for ELB?
- Will I Be Billed for Both the Bandwidth Used by the Load Balancer and the Bandwidth Used by Backend Servers?
- Do I Need to Adjust the Bandwidth of Shared Load Balancers Based on the Bandwidth Used by Backend Servers?
- Can I Modify the Bandwidth of a Load Balancer?
- What Functions Will Become Unavailable If a Load Balancer Is Frozen?
- Getting Started
User Guide
User Guide for Dedicated Load Balancers
- Using a Dedicated Load Balancer
- Permissions Management
Load Balancer
- Dedicated Load Balancer Overview
- Creating a Dedicated Load Balancer
- Enabling or Disabling Modification Protection for Dedicated Load Balancers
- Modifying the Basic Configurations of a Dedicated Load Balancer
- Modifying the Network Configurations of a Dedicated Load Balancer
- Exporting Dedicated Load Balancers
- Deleting a Dedicated Load Balancer
- Copying a Dedicated Load Balancer
- Enabling or Disabling a Load Balancer
- Listener
- Backend Server Group
- Backend Server
- Health Check
- Security
- Access Logging
- Tags and Quotas
- Cloud Eye Monitoring
- Auditing
User Guide for Shared Load Balancers
Load Balancer
- Shared Load Balancer Overview
- Creating a Shared Load Balancer
- Configuring Modification Protection for Shared Load Balancers
- Changing the Network Configurations of a Shared Load Balancer
- Deleting a Shared Load Balancer
- Enabling or Disabling a Shared Load Balancer
- Enabling Guaranteed Performance for a Shared Load Balancer
- Listener
- Backend Server
- Health Check
- Security
- Access Logging
- Tags and Quotas
- Auditing
- Self-service Troubleshooting
- Appendix
Best Practices
- Using IP as a Backend to Route Traffic Across Backend Servers
- Using Advanced Forwarding for Application Iteration
- Integrating WAF with ELB to Protect Your Websites
- Configuring HTTPS Mutual Authentication to Improve Service Security
- Using ELB to Redirect HTTP Requests to an HTTPS Listener for Higher Service Security
API Reference
- Before You Start
- API Overview
- Selecting an API Version
- Calling APIs
APIs (V3)
- API Version
- Quota
- AZ
- Load Balancer Flavor
- Reserved IP Address
Load Balancer
- Creating a Load Balancer
- Batch Creating Load Balancers
- Upgrading a Load Balancer
- Querying Load Balancers
- Copying a Load Balancer
- Viewing the Details of a Load Balancer
- Updating a Load Balancer
- Deleting a Load Balancer
- Deleting a Load Balancer and Its Associated Resources
- Deleting a Load Balancer and Its Associated Resources (Including EIPs)
- Querying the Status Tree of a Load Balancer
- Deploying a Load Balancer in Other AZs
- Removing a Load Balancer from AZs
- Certificate
- Security Policy
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying the Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Updating IP Addresses in an IP Address Group
- Deleting IP Addresses from an IP Address Group
- Querying the Listeners Associated with an IP Address Group
- Listener
- Backend Server
- Health Check
- Forwarding Policy
- Forwarding Rule
- Active/Standby Backend Server Group
- Log
- Asynchronous Task
- Feature Configuration
- Asynchronous Tasks
- APIs (V2)
APIs (OpenStack)
Tag
- Adding a Tag to a Load Balancer
- Batch Adding Load Balancer Tags
- Batch Deleting Load Balancer Tags
- Querying All Tags of a Load Balancer
- Querying the Tags of All Load Balancers
- Querying Load Balancers by Tag
- Deleting a Tag from a Load Balancer
- Adding a Tag to a Listener
- Batch Adding Tags to a Listener
- Batch Deleting Tags from a Listener
- Querying All Tags of a Listener
- Querying the Tags of All Listeners
- Querying Listeners by Tag
- Deleting a Tag from a Listener
- Status Codes
Tag
- Examples
Historical APIs
- Shared Load Balancer APIs (OpenStack) (Discarded)
- Asynchronous Job Query (Discarded)
- Querying Versions (Discarded)
Getting Started
- Obtaining a Token
- Creating a Public Network Load Balancer
- Adding a Listener
- Creating a Backend Server Group
- Adding Backend Servers
- Configuring a Health Check
- Adding a Forwarding Policy
- Adding a Forwarding Rule
- Adding a Whitelist
- Creating an SSL Certificate
- Appendix
- SDK Reference
- Popular Questions
Service Abnormality
- What Can I Do If There Is Packet Loss?
- Why Can't I Access My Backend Servers Through a Load Balancer?
- Why Does a Server Occasionally Time Out When a Client Access It Through Different Load Balancers or Different Listeners of a Load Balancer?
- What Can I Do If ELB Can't Be Accessed or Traffic Routing is Interrupted?
- How Can I Handle Abnormal Status Codes?
- How Do I Handle Abnormal Request Headers?
- How Do I Check for Traffic Inconsistencies?
- Why Does ELB Fail to Distribute Traffic Evenly?
- How Do I Check If There Is Excessive Access Delay?
- What Do I Do If a Load Balancer Fails a Stress Test?
- How Do I Check If Sticky Sessions Failed to Take Effect?
- How Do I Check SSL/TLS Authentication Errors?
Health Checks
- How Do I Troubleshoot an Unhealthy Backend Server of a Dedicated Load Balancer?
- How Do I Troubleshoot an Unhealthy Backend Server of a Shared Load Balancer?
- Why Is the Interval at Which Backend Servers Receive Health Check Packets Different from the Configured Interval?
- How Does ELB Perform UDP Health Checks? What Are the Precautions for UDP Health Checks?
- Why Does ELB Frequently Send Requests to Backend Servers During Health Checks?
- When Does a Health Check Start?
- What Do I Do If a Lot of Access Logs Are Generated During Health Checks?
- What Status Codes Will Be Returned If Backend Servers Are Identified as Healthy?
ELB Functionality
- Can Load Balancers Be Used Separately?
- Can ELB Block DDoS Attacks and Secure Web Code?
- What Types of APIs Does ELB Provide? What Are Permissions of ELB?
- Can Backend Servers of a Load Balancer Run Different OSs?
- Can ELB Be Used Across Accounts or VPCs?
- Can a Backend Server Access Its Load Balancer?
- Can Both the Listener and Backend Server Group Use HTTPS?
- Does ELB Support IPv6 Networks?
- How Do I Determine the Server Response Time Based on Monitoring Data and Logs?
- How Can I Transfer the IP Address of a Client?
- What Are the Differences Between Persistent Connections and Sticky Sessions?
- How Do I Test Sticky Sessions Using Linux Curl Commands?
Load Balancers
- How Does ELB Distribute Traffic?
- How Can I Configure Load Balancing for Containerized Applications?
- Can I Bind Multiple EIPs to a Load Balancer?
- Why Multiple IP Addresses Are Required When I Create a Dedicated Load Balancer?
- Can Backend Servers Access the Internet Using the EIP of the Load Balancer?
- Do Shared Load Balancers Have Specifications?
- What Is the Difference Between the Bandwidth Defined in Each Specification of a Dedicated Load Balancer and the Bandwidth of an EIP?
- How Do I Combine ELB and WAF?
Listeners
- What Are the Relationships Between Load Balancing Algorithms and Sticky Session Types?
- What HTTP Headers Can I Configure for an HTTP and HTTP Listener?
- Will ELB Stop Distributing Traffic Immediately After a Listener Is Deleted?
- Does ELB Have Restrictions on the File Upload Speed and Size?
- Can Multiple Load Balancers Route Requests to One Backend Server?
- How Is WebSocket Used?
- What Are the Three Timeouts of a Listener and What Are the Default Durations?
- Why Can't I Select the Target Backend Server Group When Adding or Modifying a Listener?
- Why Is There a Security Warning After a Certificate Is Configured for an HTTPS Listener?
- Why Is a Forwarding Policy in the Faulty State?
Backend Servers
- Can Backend Servers Access the Internet After They Are Associated with a Load Balancer?
- Can ELB Distribute Traffic Across Servers That Are Not Provided by Huawei Cloud?
- Why Are Backend Servers Frequently Accessed by IP Addresses in 100.125.0.0/16 or 214.0.0.0/8?
- Can ELB Route Traffic Across Regions?
- Does Each Backend Server Need an EIP to Receive Requests from a Public Network Load Balancer?
- How Do I Check the Network Conditions of a Backend Server?
- How Can I Check the Network Configuration of a Backend Server?
- How Do I Check the Status of a Backend Server?
- How Do I Check Whether a Backend Server Can Be Accessed Through an EIP?
- Why Is the Number of Active Connections Monitored by Cloud Eye Different from the Number of Connections Established with the Backend Servers?
- Why Can I Access Backend Servers After a Whitelist Is Configured?
- When Will the Changes to Server Weights Be Applied?
- Certificates
- Access Logging
- Monitoring
Billing
- Videos
- Glossary
More Documents
- Load Balancer
- Listener
- Backend Server
- Health Check
- Certificate
- Access Logging
- Monitoring
- Auditing
- Questions Summary
- ELB Usage
- Load Balancer
- Listener
Backend Server
- Why Is the Interval at Which Backend Servers Receive Health Check Packets Is Different from the Configured Health Check Interval?
- Can Backend Servers Access the Public Network After They Are Associated with a Load Balancer?
- How Can I Check the Network Conditions of a Backend Server?
- How Can I Check the Status of a Backend Server?
- When Is a Backend Server Considered Healthy?
- Health Check
- Obtaining Source IP Addresses
- HTTP/HTTPS Listeners
- Sticky Session
- Appendix
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- Load Balancer APIs
- Load Balancer (Enterprise Project) APIs
- Common Parameters
- Appendix
- Change History
User Guide (Paris Region)
Service Overview
- What Is ELB?
- Product Advantages
- How ELB Works
- Quotas and Constraints
- Billing (Shared Load Balancers)
- Billing (Dedicated Load Balancers)
- Permissions
- Product Concepts
- How ELB Works with Other Services
- Getting Started
Load Balancer
- Overview
- Preparations for Creating a Load Balancer
- Configuring Deletion Protection for Load Balancers
- Modifying the Bandwidth
- Changing the Specifications of a Dedicated Load Balancer
- Changing an IP Address
- Binding an IP Address to or Unbinding an IP Address from a Load Balancer
- Adding to or Removing from an IPv6 Shared Bandwidth
- Exporting the Load Balancer List
- Listener
- Advanced Features of HTTP/HTTPS Listeners
- Backend Server (Dedicated Load Balancers)
- Backend Server (Shared Load Balancers)
- Certificate
- Access Control
- TLS Security Policy
- Tag
- Access Logging
- Monitoring
- Auditing
- Load Balancer Migration
- Quotas
FAQ
- Popular Questions
- How Can I Handle Error Codes?
- Can ELB Be Used Separately?
- Does ELB Support Persistent Connections?
- Does ELB Support FTP on Backend Servers?
- Is an EIP Assigned Exclusively to a Load Balancer?
- How Many Load Balancers and Listeners Can I Have?
- Can I Adjust the Number of Backend Servers When a Load Balancer is Running?
- Can Backend Servers Run Different OSs?
- Can I Configure Different Backend Ports for a Load Balancer?
- Can Backend Servers Access the Ports of a Load Balancer?
- Can I Change the VPC and Subnet for My Load Balancer?
- Can I Upgrade a Shared Load Balancer to a Dedicated Load Balancer Without Interrupting Traffic Routing?
- How Do I Check If Traffic Is Being Evenly Distributed?
Load Balancers
- How Can I Access a Load Balancer Across VPCs?
- Why Can't I Delete My Load Balancer?
- Do I Need to Configure EIP Bandwidth for My Load Balancers?
- Why Multiple IP Addresses Are Required When I Create or Enable a Dedicated Load Balancer?
- Why Are Requests from the Same IP Address Routed to Different Backend Servers When the Load Balancing Algorithm Is Source IP Hash?
- Will Traffic Routing Be Interrupted If the Load Balancing Algorithm Is Changed?
- What Is the Difference Between the Bandwidth Included in Each Specification of a Dedicated Load Balancer and the Bandwidth of an EIP?
Listeners
- Can I Bind Multiple Certificates to a Listener?
- Why Cannot I Add a Listener to a Dedicated Load Balancer?
Backend Servers
- Why Is the Interval at Which Backend Servers Receive Health Check Packets Different from What I Have Configured?
- Why Are Backend Servers Frequently Accessed by IP Addresses in 100.125.0.0/16?
- When Will Modified Weights Take Effect?
- Why Must the Subnet Where the Load Balancer Resides Have at Least 16 Available IP Addresses for Enabling IP as a Backend?
Health Checks
- How Do I Troubleshoot an Unhealthy Backend Server?
- Do Maximum Retries Include Health Checks That Consider Backend Servers Unhealthy?
- Which Protocol Should I Select for the Backend Server Group When Adding an HTTPS Listener?
- Why Is There a Security Warning After a Certificate Is Configured?
- Why Can't I Add a Forwarding Policy to a Listener?
- Why Cannot I Select an Existing Backend Server Group When Adding a Forwarding Policy?
- Sticky Sessions
- Certificates
- Monitoring
- Change History
Service Overview
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- Dedicated Load Balancer APIs
- Classic Load Balancer APIs
- Enhanced Load Balancer APIs
- Appendix
- Change History
- Getting Started
Load Balancer
- Overview
- Listener
- Backend Server
- Certificate
- Access Control
- Access Logging
- Monitoring
- Auditing
- Quotas
FAQ
- Popular Questions
- Service Abnormality
ELB Functionality
- Load Balancing Performance
Load Balancers
Listeners
Backend Servers
Health Checks
- Sticky Sessions
- Certificates
- Monitoring
- Change History
- Before You Start
- API Overview
- Calling APIs
- APIs
- Appendix
- Historical APIs
- Change History
User Guide (Ankara Region)
- Load Balancer
- Listener
- Backend Server
- Certificate
- Access Control
- Access Logging
- Monitoring
- Quotas
FAQ
- Popular Questions
ELB Functionality
Load Balancers
Listeners
Backend Servers
Health Checks
- Sticky Sessions
- Certificates
- Monitoring
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- APIs (V3)
- APIs (V2)
APIs (OpenStack)
Tag
- Status Codes
Tag
- Appendix
- Change History
Health Check
ELB periodically sends requests to backend servers to check whether they can process requests. This process is called health check.
If a backend server is detected unhealthy, the load balancer will stop routing requests to it. After the backend server recovers, the load balancer will resume routing requests to it.
If backend servers have to handle large number of requests, frequent health checks may overload the backend servers and cause them to respond slowly. To address this problem, you can prolong the health check interval or use TCP or UDP instead of HTTP. You can also disable health check. If you choose to disable health check, requests may be routed to unhealthy servers, and service interruptions may occur.
Health Check Protocol
You can configure health checks when configuring backend server groups. Generally, you can use the default setting or select a different health check protocol as you need.
If you want to modify health check settings, see details in Configuring a Health Check.
Select a health check protocol that matches the backend protocol as described in Table 1.
Backend Protocol |
Health Check Protocol |
TCP |
TCP, HTTP, or HTTPS |
UDP |
UDP |
QUIC |
UDP |
TLS |
TCP, HTTP, TLS, gRPC, or HTTPS |
HTTP |
HTTPS |
gRPC |
TLS and gRPC are available in certain regions. You can see which regions support them on the console.
Health Check Source IP Address
A dedicated load balancer uses the IP addresses in its backend subnet to send requests to backend servers and verify their health status. To perform health checks, ensure that the security group rules of the backend servers allow access from the backend subnet where the load balancer works. For details, see Security Group and Network ACL Rules.
TCP Health Check
For TCP, HTTP, and HTTPS backend protocols, you can use TCP to initiate three-way handshakes to obtain the statuses of backend servers.
The TCP health check process is as follows:
- The load balancer sends a TCP SYN packet to the backend server (in the format of {Private IP address}:{Health check port}).
- The backend server returns an SYN-ACK packet.
- If the load balancer does not receive the SYN-ACK packet within the timeout duration, it declares that the backend server is unhealthy and sends an RST packet to the backend server to terminate the TCP connection.
- If the load balancer receives the SYN-ACK packet from the backend server within the timeout duration, it sends an ACK packet to the backend server and declares that the backend server is healthy. After that, the load balancer sends an RST packet to the backend server to terminate the TCP connection.
After a successful TCP three-way handshake, an RST packet will be sent to close the TCP connection. The application on the backend server may consider this packet a connection error and reply with a message, for example, "Connection reset by peer". To avoid this issue, take either of the following actions:
- Use HTTP Health Check.
- Have the backend server ignore the connection error.
UDP Health Check
For UDP backend protocol, ELB sends ICMP and UDP probe packets to backend servers to check their health.
The UDP health check process is as follows:
- The load balancer sends an ICMP Echo Request packet and UDP probe packet to the backend server.
- If the load balancer receives an ICMP Echo Reply packet and does not receive an ICMP Port Unreachable error within the health check timeout duration, it considers the backend server as healthy. If the load balancer receives an ICMP Port Unreachable error, it considers the backend server as unhealthy.
- If there is a large number of concurrent requests, the health check result may be different from the actual health of the backend server.
If the backend server runs Linux, it may limit the rate of ICMP packets as a defense against ping flood attacks. In this case, even if there is a service exception, ELB will not receive the error message "port XX unreachable", and the server will still be determined healthy. This causes the health check result to be different from the actual health of the backend server.
- The UDP probe packet's payload has no significance and is simply used to fill the packet with data. Typically, the payload is set to "H". Clients should not attempt to interpret its content.
HTTP Health Check
You can also configure HTTP health checks to obtain server statuses through HTTP GET requests if you select TCP, HTTP, or HTTPS as the backend protocol. Figure 3 shows how an HTTP health check works.
The HTTPS health check process is as follows:
- The load balancer sends an HTTP GET request to the backend server (in format of {Private IP address}:{Health check port}/{Health check path}). (You can specify a domain name when configuring a health check.)
- The backend server returns an HTTP status code to ELB.
- If the load balancer receives the status code within the health check timeout duration, it compares the status code with the preset one. If the status codes are the same, the backend server is declared healthy.
- If the load balancer does not receive any response from the backend server within the health check timeout duration, it declares the backend server is unhealthy.
- If HTTP health check is selected for the TCP listener of a dedicated load balancer, the load balancer uses HTTP/1.0 to send requests to backend servers. HTTP/1.0 is used to establish short-lived connections. This means the load balancer will not translate the HTTP responses until it receives the TCP disconnection packet. Ensure that the backend server disconnects the TCP connection immediately after sending the responses. Otherwise, the health check may fail.
- In an HTTP health check, the User-Agent header identifies that the requests are sent for health checks. The value of User-Agent may be adjusted based on service requirements. So, it is not recommended to rely on this header for verification or judgment.
- If the private IP address of a backend server is used as the domain name for a health check, do not rely on the host header for verification or judgment, as it may be empty.
HTTPS Health Check
For TCP, HTTP, and HTTPS backend protocols, you can use HTTPS to establish an SSL connection over TLS handshakes to obtain the statuses of backend servers. Figure 4 shows how an HTTPS health check works.
- The load balancer sends a Client Hello packet to establish an SSL connection with the backend server.
- After receiving the Server Hello packet from the backend server, the load balancer sends an encrypted HTTP GET request to the backend server (in the format of {Private IP address}:{Health check port}/{Health check path}). (You can specify a domain name when configuring a health check.)
- The backend server returns an HTTP status code to the load balancer.
- In an HTTPS health check, the User-Agent header identifies that the requests are sent for health checks. The value of User-Agent may be adjusted based on service requirements. So, it is not recommended to rely on this header for verification or judgment.
- If the private IP address of a backend server is used as the domain name for a health check, do not rely on the host header for verification or judgment.
TLS Health Check
For the TLS, HTTP, and HTTPS backend protocols, you can use TLS to initiate handshakes, and then send Client Hello to a backend server to check whether the server is healthy.
The TLS health check process is as follows:
- If the load balancer does not receive the SYN-ACK packet within the health check timeout duration, the backend server is declared unhealthy.
- If the load balancer receives an SYN+ACK packet within the timeout duration, it sends a Client Hello packet to the backend server. The TLS versions include TLSv1.0, TLSv1.1, TLSv1.2, and TLSv1.3.
- If the load balancer receives the Server Hello packet within the timeout duration, the backend server is declared healthy. If the load balancer does not receive the Server Hello packet within the timeout duration, it declares the backend server is unhealthy.
gRPC Health Check
The gRPC health check process is as follows:
- The load balancer sends an HTTP POST or GET request to the backend server (in format of {Private IP address}:{Health check port}/{Health check path}). (You can specify a domain name when configuring a health check.)
- The backend server returns a status code to the load balancer.
- The load balancer receives the value of grpc-status in the HTTP/2 header as the returned gRPC status code.
Health Check Time Window
Health checks greatly improve service availability. However, if health checks are too frequent, service availability will be compromised. To avoid the impact, ELB declares a backend server healthy or unhealthy after several consecutive health checks.
The health check time window is determined by the factors in Table 2.
Factor |
Description |
Check Interval |
How often health checks are performed. |
Timeout Duration |
How long the load balancer waits for the response from the backend server. |
Health Check Threshold |
The number of consecutive successful or failed health checks required for determining whether the backend server is healthy or unhealthy. |
The following is a formula for you to calculate the health check time window:
- Time window for a backend server to be detected healthy = Timeout duration x Healthy threshold + Interval x (Healthy threshold – 1)
- Time window for a backend server to be detected unhealthy = Timeout duration x Unhealthy threshold + Interval x (Unhealthy threshold – 1)
Rectifying an Unhealthy Backend Server
If a backend server is detected unhealthy, see How Do I Troubleshoot an Unhealthy Backend Server?
