Configuring Modification Protection for Shared Load Balancers
You can enable modification protection and deletion protection for load balancers to prevent them from being modified or deleted by accident.
Enabling or Disabling Deletion Protection
- Go to the load balancer list page.
- On the displayed page, locate the load balancer and click its name.
- Switch to the Summary tab of the load balancer and enable or disable Deletion Protection.
If your load balancer is managed by CCE, modifying the load balancer will affect the running of the CCE cluster.
- After deletion protection is enabled, the load balancer cannot be deleted. Other operations are not affected.
- Switch to the Summary tab and click Configure next to Modification Protection.
- In the Configure Modification Protection dialog box, enable or disable Modification Protection.
Fill in the reason if needed.
- Click OK.
You need to disable Modification Protection if you want to modify or delete a load balancer.
