Help Center/ Elastic Load Balance/ User Guide/ User Guide for Dedicated Load Balancers/ Load Balancer/ Modifying the Basic Configurations of a Dedicated Load Balancer
Updated on 2025-01-20 GMT+08:00
After a dedicated load balancer is created, you can change its specifications and AZ as required.
Modifying Specifications
You can change the specifications of a dedicated load balancer on the console:
  • Change the elastic specifications to fixed specifications, or the other way round.
  • Change the application load balancing to network load balancing, or the other way round.
    You must keep at least one load balancing type. Before removing a load balancing type, you must delete the:
    • HTTP, QUIC, or HTTPS listeners added to an application load balancer.
    • TCP, TLS, or UDP listeners added to a network load balancer.
  • Upgrade or downgrade the fixed specifications, for example, upgrade small I to medium I, or downgrade large I to medium I.
Change options vary by billing mode. To find out what changes you can make, see Table 1.
  • Upgrading specifications does not interrupt your services.
  • Downgrading specifications will temporarily disconnect services.
    • Network load balancing (TCP/UDP/TLS): New connections may not be able to be established.
    • Application load balancing (HTTP/HTTPS/QUIC): New connections may not be able to be established and some persistent connections may be interrupted.
Table 1 Supported change options for a pay-per-use load balancer
Billing Mode
Specifications
Change to Elastic
Change to Fixed
Add Load Balancing Type
Remove Load Balancing Type
Upgrade Specifications
Downgrade Specifications
Pay-per-use
Elastic
N/A
Supported
Supported
Supported
N/A
N/A
Fixed
Supported
N/A
Supported
Supported
Supported
Supported
Billing Mode
Specifications
Change to Elastic
Change to Fixed
Pay-per-use
Elastic
N/A
Supported
Supported
Supported
N/A
N/A
Fixed
Supported
N/A
Supported
Supported
Supported
Supported
  1. Go to the load balancer list page.
  2. On the displayed page, locate the load balancer, click More in the Operation column, and select Change Specifications.
  3. Select the new specifications and click Next.
  4. Confirm the information and click Submit.
Changing an AZ
You can change the AZs of a dedicated load balancer as required on the console.
After the AZ is changed, traffic will be distributed to the new AZ.
You can only deploy the load balancer in an additional AZ but cannot remove it from an AZ.
This feature will be available in more regions. See details on the management console.
  2. On the displayed page, locate the load balancer, click More in the Operation column, and select Change AZs.
  3. Select one or more new AZs and click Next.
CAUTION:
You are advised to change the AZ during off-peak hours. Changing AZs will temporarily affect services. New connections may not be able to be established and some persistent connections may be interrupted.
Popular Questions
