Updated on 2026-07-07 GMT+08:00
Tag
If you have a large number of cloud resources, you can add different tags to the resources to quickly identify them and use these tags to easily manage your resources.
You can also select Edit Tags of Associated Resources to manage tags of the resources associated with a load balancer in a unified manner. Modifications to the load balancer tags will also be synchronized to the tags of the selected associated resources. However, if the tags conflict with existing tags of the associated resources, or the associated resource tag quota is exceeded, the synchronization will fail.
If your organization has configured tag policies for ELB, add tags to load balancers based on the tag policies. If you add a tag that does not comply with the tag policies, load balancers may fail to be created. Contact your organization administrator to learn more about tag policies.
Adding a Tag to a Load Balancer
You can add a tag to a load balancer in the following ways:
  • Add a tag when you create a load balancer.
    For details, see Creating a Dedicated Load Balancer.
  • Add a tag to an existing load balancer.
    1. Go to the load balancer list page.
    2. On the displayed page, locate the load balancer and click its name.
    3. On the Tags tab, click Edit Tag.
    4. On the Edit Tag page, click Add and enter the tag key and value.
      Each tag is a key-value pair, and the tag key is unique.
    5. Confirm the information and click OK.
      A maximum of 20 tags can be added to a load balancer.
Adding a Tag to a Listener
To add a tag to an existing listener, perform the following steps:
  2. On the Load Balancers page, locate the load balancer and click its name.
  3. Click Listeners, locate the listener, and click its name.
  4. Switch to the Tags tab and click Edit Tag.
  5. On the Edit Tag page, click Add and enter the tag key and value.
  6. Confirm the information and click OK.
    A maximum of 20 tags can be added to a listener.
Modifying a Tag
  4. On the Edit Tag page, locate the tag and modify its value.
These are steps for modifying a load balancer tag. You can refer to these operations to modify a listener tag.
Deleting a Tag
  4. On the Edit Tag page, locate the tag to be deleted and click Delete.
  5. Click OK.
These are steps for deleting a load balancer tag. You can refer to these operations to delete a listener tag.
