- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Creating an IAM Project and Assigning Permissions
- Creating an IAM Project
Go to the management console, hover over the username in the upper right corner, and choose Identity and Access Management from the drop-down list. Choose Projects in the navigation pane, and click Create Project. On the displayed Create Project page, select a region and enter a project name.
- Authorization
You can assign permissions (for resources and operations) to user groups to associate projects with the user groups. To do so, add users to a user group to control projects that the users can access and the resources on which the users can perform operations. For details, see Creating a User Group and Assigning Permissions.
Creating an Enterprise Project and Assigning Permissions
- Creating an Enterprise Project
Go to the management console, and choose Enterprise > Project Management in the upper right corner. On the Enterprise Project Management console, click Create Enterprise Project to create a project.
Enterprise is available on the management console only if you have enabled the enterprise project, or your account is the primary account. To enable this function, contact customer service.
- Authorization
You can add a user group to an enterprise project and configure a policy to associate the enterprise project with the user group. To do so, add users to a user group to control projects that the users can access and the resources on which the users can perform operations. Perform the following procedure:
- On the Enterprise Management console, click the name of an enterprise project to go to the details page.
- On the Permissions tab, click Authorize User Group to go to the User Groups page on the IAM console. Associate the enterprise project with a user group and assign permissions to the group.
- Associating Resources with Enterprise Qualifications
Enterprise projects help you centrally manage cloud resources.
- Selecting an enterprise project when buying EG
On the page for buying EG, select an enterprise project to associate your resources with it.
- Adding resources
On the Enterprise Project Management page, you can add existing EG resources to a target enterprise project.
default is the default enterprise project. Resources that are not allocated to any enterprise project under your account are listed in this project.
For more information, see Enterprise Management User Guide.
