- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Show all
Supported Metrics
Introduction
This section describes the event stream metrics and dimensions reported to Cloud Eye. You can search metrics and alarms on the Cloud Eye console or on the monitoring page of EG.
Metrics
ID |
Name |
Description |
Value Range |
Monitored Object |
Raw Data Monitoring Period (Minute) |
streaming_process_num |
Event Processes |
Number of times event processing is attempted. |
≥ 0 |
Event stream |
1 |
streaming_success_num |
Successful Processes |
Number of times events are actually processed. |
≥ 0 |
Event stream |
1 |
streaming_success_rate |
Success Rate |
Percentage of total processing attempts that are successful. |
0%–100% |
Event stream |
1 |
streaming_failed_num |
Failed Processes |
Number of times events could not be processed. |
≥ 0 |
Event stream |
1 |
streaming_failed_rate |
Failure Rate |
Percentage of total processing attempts that failed. |
0%–100% |
Event stream |
1 |
streaming_process_time |
Processing Time |
Average time spent processing an event. |
≥ 0 ms |
Event stream |
1 |
Dimension |
Key |
Value |
Event stream |
streaming_id |
Event stream ID |
