On this page
Routing to DMS for Kafka
Updated on 2024-09-06 GMT+08:00
Configure DMS for Kafka as the event target when creating an event stream.
You have enabled DMS for Kafka as the event target.
  1. Log in to the EG console.
  2. In the navigation pane, choose Event Streams.
  3. Click Create Event Stream.
  4. Enter an event stream name and description, and click OK.
  5. Configure the event source by referring to Configuring DMS for Kafka as the Event Source.
  6. Configure the event target.
    1. Click Event Target.
    2. Select Distributed Message Service (DMS) for Kafka for Target.
    3. Set event target parameters.
      Figure 1 Distributed Message Service (DMS) for Kafka
      Table 1 Distributed Message Service (DMS) for Kafka parameters
      Connection
      Select a connection. If no connection is available, create one with DMS for Kafka.
      Topic
      First select a connection, and then select a topic.
      Message Key
      Disable
      Do not use a message key.
      Enable
      Variable: The key is a variable value from CloudEvents-compliant events.
      Constant: The key is a specified constant. All messages will be sent to the same partition.
      Rule
      Transform Type
      EG transforms CloudEvents-compliant events for targets. The following three types are supported:
      • Pass-through: Route the complete structure of native events directly to the target.
      • Variables: Route only parameters extracted from events with JSONPath to the target.
      • Constants: Route only constants in events to the target as a trigger.
      For more information about the transform types, see Event Content Transformation.
      Message Push
      Batch Push
      Specify whether to enable batch push to aggregate multiple events.
      Messages
      Interval (s)
      The maximum number of aggregated records that can be pushed at a time. Default: 100. Range: 1–10,000. This parameter is available only when Batch Push is enabled.
      The interval between batch pushes, in seconds. Default: 1. Range: 0–15. This parameter is available only when Batch Push is enabled.
