- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Show all
Supported Metrics
Introduction
This section describes the event subscription metrics and dimensions reported to Cloud Eye. You can search metrics and alarms on the Cloud Eye console or on the monitoring page of EG.
Metrics
ID |
Name |
Description |
Value Range |
Monitored Object |
Raw Data Monitoring Period (Minute) |
sub_num |
Total Deliveries |
Number of times event delivery is attempted. |
≥ 0 |
Event subscription |
1 |
sub_success_num |
Successful Deliveries |
Number of times events are actually delivered. |
≥ 0 |
1 |
sub_success_rate |
Success Rate |
Percentage of total deliveries that are successful. |
0%–100% |
1 |
sub_failed_num |
Failed Deliveries |
Number of times events could not be delivered. |
≥ 0 |
1 |
sub_failed_rate |
Failure Rate |
Percentage of total deliveries that failed. |
0%–100% |
1 |
sub_retry_num |
Delivery Retries |
Number of times delivery retry is attempted. |
≥ 0 |
1 |
sub_retry_rate |
Retry Rate |
Percentage of total deliveries that are retried. |
0%–100% |
1 |
sub_process_time |
Processing Time |
Average time spent processing an event delivery. |
≥ 0 ms |
1 |
Dimension |
Key |
Value |
subscription_id |
Event subscription ID |
Event subscription - target |
target_id |
Event target ID |
