- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Dead Letter Queue
Introduction
If the dead letter queue function is enabled, EG sends failed events to the specified queue. If disabled, such events will be discarded.
- Log in to the EG console.
- In the navigation pane, choose Event Subscriptions.
- Click Create Event Subscription.
- Click Event Target.
- In the displayed dialog box, select an event target.
- Enable Dead Letter Queue and configure the required parameters.
Figure 1 Configuring a dead letter queue
Table 1 Dead letter queue parameters Parameter
Queue Type
Select a queue type.
Instance
Select an instance.
Connection
Select a connection.
Select a connection whose type is the same as the queue type.
Topic
Select a topic.
Do not use the same topic as the event target, or EG cannot distinguish successful events from failed ones.
- Click OK.
Processing Data in the Dead Letter Queue
Perform the following procedure to process the data in the dead letter queue.
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click Create Function in the upper right. For details, see Creating an Event Function.
Figure 2 Function list
- Click the created function to go to the details page.
- Choose Configuration > Triggers and click Create Trigger.
Figure 3 Creating a trigger
- Set the following parameters:
- Trigger Type: Select DMS (for Kafka).
- Instance: Select the same Kafka instance as the dead letter queue.
- Topic: Select the same topic as the dead letter queue.
- Batch Size: Set the number of messages to be retrieved from the topic each time. Recommended: 10.
- Username: Enter the username of the instance if SSL has been enabled for it.
- Password: Enter the password of the instance if SSL has been enabled for it.
- Click OK.
- Click Enable to enable the Kafka trigger.
Figure 4 Enabling a Kafka trigger
- Compile the logic for processing data in the dead letter queue.
Figure 5 Data processing logic
- Configure a test event.
- Click Configure Test Event.
- Select DMS (for Kafka) and click Create.
Figure 6 Configuring a test event
- Select the created test event from the drop-down list.
- Click Test and then view the execution result.
Figure 7 Execution result
