- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Show all
Configuring Alarm Rules
This section describes the alarm policies of some metrics and how to configure them. In actual services, you are advised to configure alarm rules for metrics based on the following alarm policies.
Parameter |
Description |
Name |
Name of the alarm rule. The system generates a name randomly but you can change it. |
Description |
Alarm rule description. This parameter is optional. |
Alarm Type |
Alarm type to which the alarm rule applies. Default: Metric. |
Resource Type |
Resource type. Default: EventGrid. |
Dimension |
Alarm dimension. Default: Event Channels. |
Monitoring Scope |
Resources to monitor. Default: Specific resources. |
Monitored Objects |
Object to monitor. Default: event channel name. |
Method |
Alarm triggering method. Default: Configure manually. |
Alarm Policy |
Policy that triggers an alarm. For details, see Table 2. You cannot modify or add alarm policies for metric alarm rules created on the EG console. |
Alarm Notification |
After you enable this function and configure required parameters, you will be notified of alarms and alarm clearance by notification group or topic subscription. |
Notification Recipient |
Select Notification group or Topic subscription. |
Notification Group |
Select a notification group. If no notification group is available, create one by referring to Creating a Notification Object or Notification Group. |
Notification Object |
Select a notification contact and topic. If no topic is available, create one by referring to Creating a Notification Object or Notification Group. |
Notification Window |
Alarm notifications are only sent during the configured validity period. |
Trigger Condition |
Condition for triggering a notification. |
Enterprise Project |
Enterprise project to which the alarm rule belongs. For details, see Creating an Enterprise Project. |
Period |
Number of Times |
Comparison |
Value |
Interval |
Severity |
Raw data |
1 time |
Number |
Every 10 minutes |
Critical |
Max. |
2 consecutive times |
Number |
Every 15 minutes |
Major |
Min. |
3 consecutive times |
Number |
Every 30 minutes |
Minor |
Sum |
4 consecutive times |
Number |
Every hour |
Information |
Variance |
5 consecutive times |
Number |
Every 3 hours |
- Click
in the upper left and select a region.
Select the region where your event channel is located.
- Click
in the upper left and choose Middleware > EventGrid.
- Choose Event Channels.
- Click Monitor in the Operation column to go to the monitoring page.
- Hover over a metric and click
to create an alarm rule for it.
- Specify the alarm rule details.
For details about how to create an alarm rule, see Creating an Alarm Rule.
