- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Show all
Viewing Monitoring Data
Cloud Eye monitors event channel metrics in real time. You can view these metrics on the Cloud Eye console.
You have created an event channel.
- Click
in the upper left and select a region.
Select the region where your event channel is located.
- Click
in the upper left and choose Middleware > EventGrid.
- Choose Event Channels.
- Click
in the row that contains the target event channel to go to the monitoring page. Data of all accessed events in the last hour is displayed by default.
You can also click 1h, 3h, 12h, 1d, 7d, or 30d to view event accesses in different periods.
Figure 1 Viewing event channel monitoring dataNOTE:
To customize a time range, click
If you enable Auto Refresh, the metric data is refreshed every 5 seconds.
Click View details to go to the Cloud Eye console.
If you set Period to Raw data, the raw monitoring data is displayed. If you set Period to a specific time, you can select different aggregation methods, including Avg., Max., Min., Sum, and Variance.
