- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Show all
Viewing Event Traces
View traces of an event channel.
You can query sources, details, delivery targets, and delivery status of events in 72 hours.
Event traces are supported in these regions: CN East-Shanghai1, CN East-Shanghai2, CN North-Beijing4, CN North-Ulanqab1, and CN South-Guangzhou.
- Log in to the EG console.
- In the navigation pane, choose Event Channels.
- Click View Events.
- Click Filter.
Table 1 Filter parameters Parameter
Time Range
Select an event publishing period.
Event Source
Enter an event source name.
Event Type
Enter an event type.
Event ID
Enter an event ID.
- Click View Trace to view event information, traces, and delivery details.
Figure 1 Viewing event traces
- Click an event ID to view event details, as shown in Figure 2.
Details about events that failed to be delivered can be queried in 72 hours, but details about successfully delivered events may be available in a longer period.
