Help Center/ EventGrid/ User Guide/ Event Channels/ Creating an Event Channel
Updated on 2025-08-07 GMT+08:00
Create a custom event channel.
  1. Log in to the EG console.
  2. In the navigation pane, choose Event Channels.
  3. Click Create Event Channel.
  4. Enter a channel name and description. Click OK. The following table describes the parameters.
    Table 1 Parameters for creating a custom event channel
    Channel
    Enter a channel name.
    Describe the channel.
    View this channel in the Custom area.
    • Only the event channel description can be modified. To modify it, click Edit in the row that contains the desired event channel.
    • To view details about a custom event channel, click its name in the custom event channel list.
