- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
On this page
Show all
Help Center/
EventGrid/
User Guide/
Event Streams/
Event Stream Management/
Deleting an Event Stream
Delete an event stream that will no longer be used.
- Log in to the EG console.
- In the navigation pane, choose Event Streams.
- Click Delete in the row that contains the desired event stream.
- Click Yes.
Parent topic: Event Stream Management
