- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
DMS for RabbitMQ
Create a DMS for RabbitMQ event source.
DMS for RabbitMQ is supported in these regions: CN East-Shanghai1, CN East-Shanghai2, CN North-Beijing4, CN North-Ulanqab1, and CN South-Guangzhou.
- (Optional) You have created an event channel.
- You have purchased a DMS for RabbitMQ instance. The instance contains queues and is in the Running state. For details, see Buying an Instance.
- You have created a private endpoint with the same VPC and subnet as the RabbitMQ instance.
- You have configured the default security group with rules for the RabbitMQ instance. For details, see How Do I Configure a Security Group for an Event Source?
Creating a RabbitMQ Event Source
- Log in to the EG console.
- In the navigation pane, choose Event Sources.
- Click Create Event Source.
- Set event source information by referring to Table 1.
Table 1 RabbitMQ event source parameters Parameter
Type
Two types are available:
- Existing: Select an existing custom event channel.
- New: Create an event channel.
Channel
- If Type is set to Existing, select an existing custom event channel.
- If Type is set to New, enter a channel name and description.
The channel cannot be modified once the event source is created.
Name
Event source name.
The name cannot be modified once the event source is created.
Describe the event source.
Type
Select DMS for RabbitMQ.NOTE:
You will be prompted to create an agency when creating your first DMS for RabbitMQ event source. For details, see Authorization.
Instance
Select a RabbitMQ instance.
Username
Username of the RabbitMQ instance.
Password
Password of the RabbitMQ instance.
Vhost
Virtual host of the RabbitMQ instance.
Queue
Queue in the RabbitMQ instance.
- Click OK.
View this event source on the Custom tab.
- Only the event source description can be modified. To modify it, click Edit in the row that contains the desired event source.
- To view details about a custom event source, click its name in the custom event source list.
Follow-Up Procedure
(Optional) Creating an Event Subscription
