- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
On this page
Show all
Viewing Monitoring Data
EG monitors event subscriptions and channels, and allows you to query event access and delivery information without any configuration.
- Click
in the upper left and select a region.
- Click
in the upper left and choose Middleware > EventGrid.
- On the Event Subscriptions page, click
in the row that contains the desired subscription, and view the event delivery monitoring data.
- View the monitoring data of a single event target.
- View the monitoring data of the last hour, last 4 hours, last 24 hours, last 7 days, or a custom time range.
- Specify a period (1 minute, 5 minutes, or 20 minutes) and method (average, maximum, or minimum).
- On the Event Channels page, click
in the row that contains the desired channel, and view the event access monitoring data.
- View the monitoring data of a single event source.
Parent topic: Event Monitoring
