- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Show all
Supported Metrics
Introduction
This section describes the monitoring metrics and dimensions of EG. View these metrics on the EG console.
Metrics
ID |
Name |
Description |
Value Range |
Monitored Object |
Raw Data Monitoring Period (Minute) |
num |
Total Deliveries |
Number of times event delivery attempts are made. Unit: count |
≥ 0 |
Event subscription |
1 |
success_num |
Successful Deliveries |
Number of times events are finally delivered. Unit: count |
≥ 0 |
1 |
process_time |
Processing Time |
Average time spent processing all event deliveries in a period. Unit: ms |
≥ 0 ms |
1 |
fail_num |
Failed Events |
Number of events that fail to be delivered without needing a retry attempt. Unit: count |
≥ 0 |
1 |
ID |
Name |
Description |
Value Range |
Monitored Object |
num |
Total Accesses |
Number of times event access attempts are made. Unit: count |
≥ 0 |
Event channel |
1 |
success_num |
Successful Accesses |
Number of times events are finally accessed. Unit: count |
≥ 0 |
Event channel |
1 |
fail_num |
Failed Accesses |
Number of times events could not be accessed. Unit: count |
≥ 0 |
Event channel |
1 |
process_time |
Processing Time |
Average time spent processing all event accesses in a period. Unit: ms |
≥ 0 ms |
Event channel |
1 |
Dimensions
Key |
Value |
subscription_id |
Event subscription ID |
channel_id |
Event channel ID |
