Event Content Transformation
EG transforms CloudEvents-compliant events so that they can be processed by specified targets.
Supported transform types: pass-through, variables, constants.
Pass-through
Directly route CloudEvents-compliant events to the target. Example:
Before Transformation |
Transform Type |
After Transformation |
{ "events":[{ "id": "4b26115b-73e-cf74a******", "specversion": "1.0", "source": "HC.OBS", "type": "object:put", "datacontenttype": "application/json", "subject": "xxx.jpg", "time": "2022-01-17T12:07:48.955Z", "data": { "name": "test01", "state": "enable" } }] } |
Pass-through |
{ "events":[{ "id": "4b26115b-73e-cf74******", "specversion": "1.0", "source": "HC.OBS", "type": "object:put", "datacontenttype": "application/json", "subject": "xxx.jpg", "time": "2022-01-17T12:07:48.955Z", "data": { "name": "test01", "state": "enable" } }] } |
Variables
Route variables in CloudEvents-compliant events to the target by using a template. Example:
Transform Type |
Parameter {"name":"$.data.name"} Template My name is ${name} If the event target is FunctionGraph (function computing), the template must be in JSON format. Example: {"name":"${name}"} |
My name is test01 If the event target is FunctionGraph (function computing), the transformation result is as follows: {"name": "test01"} |
Example of complex transformation from OBS to EG and then to FunctionGraph:
Transform Type |
{ "specversion": "1.0", "id": "******9db447aa3******", "source": "HC.OBS.DWR", "type": "OBS:DWR:ObjectCreated:PUT", "datacontenttype": "application/json", "dataschema": "", "subject": "test.txt", "time": "2023-08-01T11:41:51.712759419Z", "ttl": "4000", "data": { "eventVersion": "3.0", "eventSource": "OBS", "eventRegion": "cn-north-4", "eventTime": "2023-08-01T19:41:47.879Z", "eventName": "ObjectCreated:Put", "userIdentity": { "ID": "******fef0f08c******" }, "requestParameters": { "sourceIPAddress": "1**.1**.1**.1**" }, "responseElements": { "x-obs-request-id": "******47aa3cdafb******", "x-obs-id-2": "", "x-amz-request-id": "", "x-amz-id-2": "" }, "obs": { "Version": "1.0", "configurationId": "******4aaac1******", "bucket": { "name": "test", "ownerIdentity": { "ID": "******f1234567******" }, "bucket": "test", "arn": "" }, "object": { "key": "test.txt", "eTag": "******48ce552c3******", "size": 13, "versionId": "******BE7FFFF******", "sequencer": "1", "oldpsxpth": "" } } } } |
Parameters { "eventVersion": "$.data.eventVersion", "eventTime": "$.data.eventTime", "requestParameters": "$.data.requestParameters.sourceIPAddress", "configurationId": "$.data.obs.configurationId", "eTag": "$.data.obs.object.eTag", "sequencer": "$.data.obs.object.sequencer", "key": "$.data.obs.object.key", "size": "$.data.obs.object.size", "arn": "$.data.obs.bucket.arn", "name": "$.data.obs.bucket.name", "ownerIdentity": "$.data.obs.bucket.ownerIdentity.ID", "Region": "$.data.eventRegion", "eventName": "$.type", "userIdentity": "$.data.userIdentity.ID" } Template { "Records": [ { "eventVersion": "${eventVersion}", "eventTime": "${eventTime}", "requestParameters": { "sourceIPAddress": "${requestParameters}" }, "obs": { "configurationId": "${configurationId}", "object": { "eTag": "${eTag}", "sequencer": "${sequencer}", "key": "${key}", "size": "${size}" }, "bucket": { "arn": "${arn}", "name": "${name}", "ownerIdentity": { "PrincipalId": "${ownerIdentity}" } } }, "Region": "${Region}", "eventName": "${eventName}", "userIdentity": { "principalId": "${userIdentity}" } } ] } The value in the template is the key of the corresponding parameter. |
{ "Records": [ { "eventVersion": "3.0", "eventTime": "2023-08-01T19:41:47.879Z", "requestParameters": { "sourceIPAddress": "1**.1**.1**.1**" }, "obs": { "configurationId": "******4aaac1******", "object": { "eTag": "******48ce552c3******", "sequencer": "1", "key": "test.txt", "size": "13" }, "bucket": { "arn": "", "name": "test", "ownerIdentity": { "PrincipalId": "******f1234567******" } } }, "Region": "cn-north-4", "eventName": "OBS:DWR:ObjectCreated:PUT", "userIdentity": { "principalId": "******fef0f08c******" } } ] } |
Constants
Route constants in events to the target. Example:
Rule |
{ "events":[{ "id": "4b26115b-73cf74a******", "specversion": "1.0", "source": "HC.OBS", "type": "object:put", "datacontenttype": "application/json", "subject": "xxx.jpg", "time": "2022-01-17T12:07:48.955Z", "data": { "name": "test01", "state": "enable" } }] } |
Parameter test01 If the event target is FunctionGraph (function computing), the rule must be in JSON format. Example: {"name": "test01"} |
More Examples
- After you set a DMS for RabbitMQ or DMS for RocketMQ event source for a subscription, messages will contain the context field in data after being transformed to CloudEvents-compliant events. If you set the transform type to Variables for the event target, the rule must also contain the context field. Example:
Transform Type
{ "type": "ROCKETMQ:CloudTrace:RocketmqCall", "data": { "context": { "name": "test01", "state": "enable" } }, "source": "zhang_roc", "time": "2023-02-01T10:47:07Z", "datacontenttype": "application/json", "specversion": "1.0", "id": "2f885496-570c-4925-82fd-d1ad09******", "subject": "ROCKETMQ:cn-north-7:eec88b34-9470-483e-8961-edb168******/0de095e33e00d36e2fd2c0019a******:ROCKETMQ:zhang_roc" }
{"name":"$.data.context.name"}
Template
My name is ${name}
My name is test01
