Filter Rule Parameters
Only events that match your filter rules will be routed to the associated targets. These filter rules must have the same structure as the events.
This section describes the restrictions of filter rules as well as the operators, condition expressions, and matching fields.
Restrictions
Event filter rules must meet the following requirements:
- Top-level fields can only be source, type, subject, or data.
- Top-level fields must include source, and source only supports the StringIn operator.
- The data field allows max. 5 subfields, and each can have max. 5 levels.
- Each field can have max. 5 conditions in an OR relationship.
- Multiple fields are ANDed with each other.
- A field that appears more than once at the same level will be used where it appears the last time.
Operators
Table 1 lists the operators that can be used in event filter rules.
Operator |
Input Value |
Condition Value |
Description |
StringIn |
String/String[] |
String[] values |
Check if the input value matches any condition value. |
StringNotIn |
String/String[] |
String[] values |
Check if the input value does not match any condition value. |
StringStartsWith |
String/String[] |
String[] values |
Check if the input value prefix matches any condition value. |
StringNotStartsWith |
String/String[] |
String[] values |
Check if the input value prefix does not match any condition value. |
StringEndsWith |
String/String[] |
String[] values |
Check if the input value suffix matches any condition value. |
StringNotEndsWith |
String/String[] |
String[] values |
Check if the input value suffix does not match any condition value. |
NumberIn |
Number/Number[] |
Number[] values |
NumberNotIn |
Number/Number[] |
Number[] values |
NumberLessThan |
Number/Number[] |
Number value |
Check if the input value is less than the condition value. |
NumberNotLessThan |
Number/Number[] |
Number value |
Check if the input value is greater than or equal to the condition value. |
NumberGreaterThan |
Number/Number[] |
Number value |
Check if the input value is greater than the condition value. |
NumberNotGreaterThan |
Number/Number[] |
Number value |
Check if the input value is less than or equal to the condition value. |
NumberInRange |
Number/Number[] |
Number[][] values |
Check if the input value is within any condition value range. |
NumberNotInRange |
Number/Number[] |
Number[][] values |
Check if the input value is not within any condition value range. |
IsNull |
None |
Check if the input value is null or undefined. |
IsNotNull |
None |
Check if the input value is neither null nor undefined. |
IsTrue |
Boolean |
None |
Check if the input value is true. |
IsNotTrue |
Boolean |
None |
Check if the input value is false. |
Condition Expressions
Table 2 lists the condition expressions that can be used in event filter rules.
Matching Fields
Table 3 lists the matching fields that can be used in event filter rules.
Field Name |
Condition Value Type |
Example |
source |
JSON array |
Event source. The condition value is in the JSON array. This field can only be used with the StringIn operator. Example: [{"op": "StringIn", "values": ["HC.OBS"]] |
type |
JSON array |
Event type. The condition value is in the JSON array. Example: [{"op": "StringIn", "values": ["object:put"]] |
subject |
JSON array |
Event body. The condition value is in the JSON array. Example: [{"op": "StringEndsWith", "values": [".jpg"]] |
data |
JSON object |
Event data. The condition value is in the JSON object, and can be nested in max. 5 layers. Example: {"state": [{"op": "StringIn", "values": ["running"]]}] |
