Events
Updated on 2024-09-06 GMT+08:00
Events are data that complies with specific specifications. Events that event sources publish to EG must comply with the CloudEvents specification.
EG supports the following events:
  • Huawei Cloud service: events produced by Huawei Cloud service event sources
  • Custom: events produced by custom event sources connected to EG with SDKs
Example Event
The following is an example of an event published to EG:
    "events":[{
	"id": "4b26115b-778e-11ec-833e-cf74******",
        "specversion": "1.0",
	"source": "HC.OBS",
	"type": "object:put",
	"datacontenttype": "application/json",
	"subject": "xxx.jpg",
	"time": "2022-01-17T12:07:48.955Z",
	"data": {
		"name": "test01",
		"state": "enable"
Table 1 describes the parameters in this example.
Table 1 Event parameters
Type
Required
Example Value
id
String
Yes
4b26115b-778e-*******-833e-cf74af
Event ID, which identifies an event
specversion
String
Yes
1.0
Version of the CloudEvents specification
source
String
Yes
HC.OBS
Event source that produces the event
type
String
Yes
object:put
Event type related to the event source
datacontenttype
String
No
application/json
Content format of the data parameter
Only application/json is supported.
subject
String
No
Event subject
time
Timestamp
No
Time when the event was produced
data
Struct
No
    "name": "test01",
    "state": "enable"
Content of the event in JSON format
Sending Events in Batches
The following is an example of the request body for sending events in batches:
    "events":[{
	"id": "eg-test-001",
	"source": "HC.OBS",
	"data": {
		"name": "test01",
		"state": "enable"
	"id": "eg-test-002",
	"source": "HC.OBS",
	"data": {
		"name": "test01",
		"state": "enable"
	"id": "eg-test-003",
	"source": "HC.OBS",
	"data": {
		"name": "test01",
		"state": "enable"
  • Max. size per event: 64 KB
  • Max. size of all events per request: 256 KB
  • Max. events per request: 20
Response body returned when all events are successfully sent:
{"failed_count":0,"events":[{"error_code":null,"error_msg":null,"event_id":"eg-test-003"},{"error_code":null,"error_msg":null,"event_id":"eg-test-003"},{"error_code":null,"error_msg":null,"event_id":"eg-test-002"}]}
Status code: 200
Response body returned when the number of events per request exceeds the upper limit:
{"failed_count":1,"events":[{"error_code":"00533013","error_msg":"Too many events for a request.","event_id":"eg-test-003"},{"error_code":null,"error_msg":null,"event_id":"eg-test-003"},{"error_code":null,"error_msg":null,"event_id":"eg-test-002"}]}
Status code: 400
Response body returned when the size of an event exceeds the upper limit:
{"failed_count":3,"events":[{"error_code":00533012,"error_msg":An event is too large."event_id":"eg-test-003"},{"error_code":00533012,"error_msg":the number of events exceeds the limit,"event_id":"eg-test-003"},{"error_code":00533012,"error_msg":the number of events exceeds the limit,"event_id":"eg-test-002"}]}
Status code: 400
Response body returned when the total size of all events per request exceeds the upper limit:
{"error_code":"00533007","error_msg":"The total size of a request's all events is too large.","error_detail":"The total size of a request's all events is too large."}
{"error_code":"00533012","error_msg":"An event is too large.","error_detail":"An event is too large."}
{"error_code":"00533013","error_msg":"Too many events for a request.","error_detail":"Too many events for a request."}
Status code: 400
If the status code is 400:
  • The total size of all events per request exceeds the upper limit. (Error code: EG.00533007; error message: The total size of a request's all events is too large)
  • The number of events per request exceeds the upper limit. (Error code: EG.00533013; error message: Too many events for a request)
