Deleting a Domain Name
You can delete a domain name to switch back to CDN.
If you have enabled enterprise projects, ensure that you have all operation permissions for the project where your EdgeSec instance locates. Then, you can select the enterprise project from the Enterprise Project drop-down list and switch EdgeSec working mode for a specific domain name.
A protected website has been added. For details, see Adding a Website to EdgeSec.
- Log in to the EdgeSec console.
- In the navigation pane on the left, choose . The Website Settings page is displayed.
- In the row containing the target domain name, , choose Delete in the Operation column. In the dialog box displayed, click Confirm.
- A deleted domain name cannot be recovered. Exercise caution when performing this operation.
- After a domain name is deleted, Scheduling Status of the domain name is Scheduling to CDN. Then, manually refresh the page. The domain name is successfully deleted and switched back to CDN.
It takes a long time to delete a domain name of the whole site acceleration type.
