- What's New
- Function Overview
- Billing
User Guide
- Enabling EdgeSec
- Site Acceleration
Security Protection
- Connecting a Domain Name to EdgeSec
- Dashboard
- Protection Statistics
Protection Policy
- Creating a Protection Policy
- Applying a Policy to Your Website
Configuring Protection Policies
- Configuration Guidance
- Configuring Basic Protection Rules to Defend Against Common Web Attacks
- Configuring CC Attack Protection Rules to Defend Against CC Attacks
- Configuring a Precise Protection Rule
- Creating a Reference Table to Configure Protection Metrics In Batches
- Configuring IP Address Blacklist and Whitelist Rules to Block Specified IP Addresses
- Configuring a Known Attack Source Rule
- Configuring Geolocation Access Control Rules to Block Requests from Specific Locations
- Configuring a BOT Protection Rule
- Configuring a Global Whitelist Rule to Ignore False Positives
- Configuring a Data Masking Rule
- Address Group Management
- System Management
- Permissions Management
- Key Operations Recorded by CTS
- Best Practices
API Reference
- Before You Start
- API Overview
- API Calling
API
- Protected Domain Name Management
HTTP Protection Policy Management
- This API is used to query the protection policy list.
- This API is used to create a protection policy.
- This API is used to query a protection policy.
- This API is used to update a protection policy.
- This API is used to delete a protection policy.
- This API is used to update domain names a policy applies to.
- This API is used to update a protection policy rule.
- EdgeSec HTTP Protection Rule Management - CC
- HTTP Protection Rule Management - Precise Protection
HTTP Protection Rule Management - IP Address Blacklist and Whitelist
- This API is used to query IP address blacklist and whitelist rules.
- This API is used to create an IP address blacklist or whitelist rule.
- This API is used to query an IP address blacklist or whitelist rule.
- This API is used to update an IP address blacklist or whitelist rule.
- This API is used to delete a blacklist or whitelist rule.
HTTP Protection Rule Management - Geographical Location
- This API is used to query the geolocation access control rules.
- This API is used to create a geolocation access control rule.
- This API is used to query a geolocation access control rule.
- This API is used to update a geolocation access control rule.
- This API is used to delete a geolocation access control rule.
HTTP Protection Rule Management - False Alarm Masking
- This API is used to query false alarm masking rules.
- This API is used to add a false alarm masking rule.
- This API is used to query a false alarm masking rule.
- This API is used to update a false alarm masking rule.
- This API is used to delete a false alarm masking rule.
- This API is used to reset a false alarm masking rule.
- HTTP Protection Rule Management - Attack Penalty
- IP Address Group Management
- Security Overview
- Reference Table Management
- DDoS Statistics
- HTTP Statistics
- DDoS Attack Logs
Appendix
- Status Code
- Error Codes
Troubleshooting
- EdgeSec.00000005 Invalid Parameter
- EdgeSec.00000013 Concurrent Modification Exception
- EdgeSec.00000014 Only Default Enterprise Project Supported (Not support operation in this enterprise project)
- EdgeSec.00000015 Write Operation Not Supported When All Enterprise Projects Are Selected (All enterprise projects do not support the write operation)
- EdgeSec.00000018 Migration of Resources to Non-Default Enterprise Project Not Supported (This version only supports default enterprise project)
- EdgeSec.00000019 Frozen Resources Cannot Be Migrated to or from an Enterprise Project (frozen cannot create eps tag)
- EdgeSec.00000023 Operation Not Supported by the Current Specifications
- EdgeSec.00000025 Invalid Block Time (Invalid block time)
- EdgeSec.00000026 Invalid Whitelist Rule Type (Invalid rule type)
- EdgeSec.00000027 Invalid CC Rule Condition Length (Invalid cc condition length value)
- EdgeSec.00010001 Invalid IAM Service Project (Failed to get IAM projects)
- EdgeSec.00010005 Insufficient WAF Policy Rule Quota
- EdgeSec.00010006 Blacklist and Whitelist Rules of Edge WAF Exceed the Quota
- EdgeSec.00010007 Insufficient IP Address Group Quota of Edge WAF
- EdgeSec.00010008 Insufficient Edge WAF Certificate Quota
- EdgeSec.00030001 Invalid DDoS Overview Parameters (Illegal Elasticsearch Request)
- EdgeSec.00030003 DDoS Overview Query Type Exception (Statistic Type Error)
- EdgeSec.00030002 DDoS Overview Query Type Exception (Search Error)
- EdgeSec.00040007 No Permission To Operate
- EdgeSec.00040013 Insufficient Top-Level Domain Name Quota
- EdgeSec.00040014 Expansion Resource Quota Has Been Used
- WAF.00022002 Resource Already Exists (Domain Already Exists)
- WAF.00014002 Resource Already Exists
- common.01010003 No Purchase Permission
- Obtaining a Project ID
- SDK Reference
- About the Product
About Functions
- How Does EdgeSec Detect SQL Injection, XSS, and PHP Injection Attacks?
- How Do I Obtain the Real IP Address of a Visitor in EdgeSec?
- How Does EdgeSec Block Requests?
- Do I Need to Enable All Ports When Configuring an EdgeSec Whitelist in a Security Group?
- Why Do Cookies Contain the HWEdgeSecSESID or HWEdgeSecSESTIME field?
- Does Edge Security Support Alarm Notifications for Attacks?
- Regions and AZs
Enabling Alarm Notifications
You can configure an SMN topic within the SMN application and authorize EdgeSec to send attack logs to you via your chosen notification mode (e.g., email or SMS).
- Currently, SMN topics can be configured only in the CN North-Beijing4 region.
- The default topic name is edgesec-topic.
Before onboarding EdgeSec, you must first access the CN North-Beijing4 region to verify the accessibility of the region.
Creating a Topic
- Click
in the upper left corner of the page and choose Management & Governance > Simple Message Notification.
- In the navigation pane on the left, choose Topic Management > Topics.
- On the Topics page, click Create Topic.
- Configure parameters.
Table 1 Parameters for creating a topic Parameter
Topic Name
edgesec-topic
Display name
Message sender name, which can contain up to 192 bytes
CTS Log
Whether to enable CTS log.
Tag
A tag is a key-value pair. Tags identify cloud resources so that you can easily categorize and search for your resources.
If you have configured tag policies for message notifications, add tags to your topics based on the tag policies. If you add a tag that does not comply with the tag policies, topics may fail to be created. Contact the administrator to learn more about tag policies.
- A key can contain a maximum of 128 characters, and a value can contain a maximum of 255 characters.
- A tag key can contain letters, digits, spaces, and special characters (_.:=+-@), but cannot start or end with a space or start with _sys_.
- A tag value can contain letters, digits, spaces, and any of the following characters: : / = + - @
- You can add up to 20 tags for each topic.
- Click OK.
Assigning Permissions
- Click the name of a topic to go to its details page, and click Configure Topic Policy in the upper right corner.
- In the dialog box displayed, set Services that can publish messages to this topic to EDGESEC. For details about how to configure other parameters, see Configuring Topic Policies.
Adding a Subscription
- Locate the topic that you want to add a subscription to. In the Operation column, click Add Subscription.
Alternatively, click a topic name in the Topic Name column. In the upper right corner of the displayed page, click Add Subscription.
- Select the required protocol from the Protocol drop-down list and enter the subscription endpoint in the Endpoint text box.
- Click OK. For details, see Adding a Subscription.
Example Alarm Notification Email
After SMN is configured, alarm notifications will be sent by email. EdgeSec sends attack logs to you. Figure 1 shows an example of an alarm notification email.
