Managing Logs
Updated on 2025-03-04 GMT+08:00
After you authorize EdgeSec to access Log Tank Service (LTS), you can use the EdgeSec logs recorded by LTS for quick and efficient real-time analysis, device O&M management, and analysis of service trends.
LTS analyzes and processes a large number of logs. It enables you to process logs in real-time, efficiently, and securely. Logs can be stored in LTS for seven days by default but you can configure LTS for up to 30 days if needed. Logs earlier than 30 days are automatically deleted. However, you can configure LTS to dump those logs to an Object Storage Service (OBS) bucket or enable Data Ingestion Service (DIS) for long-term storage.
  • On the LTS console, you can view logs for the last 30 days and download logs for the last five days.
  • LTS is billed by traffic and is billed separately from EdgeSec. For details about LTS pricing, see Price Calculator.
  • If you have enabled enterprise projects, ensure that you have all operation permissions for the project where your EdgeSec instance locates. Then, you can select the project from the Enterprise Project drop-down list and configure EdgeSec logging.
A protected website has been added. For details, see Adding a Website to EdgeSec.
Enabling LTS for EdgeSec Protection Event Logging
  2. Click in the upper left corner of the page and choose Content Delivery & Edge Computing > CDN and Security.
  3. Select the configuration path as required.
    Configure EdgeSec logs. In the navigation pane, choose Edge SecurityEdge Security > Statistic. On the Statistic page that is displayed, click the Configure Logs tab.
  4. Enable the all log recording and select a log group or click LTS. Table 1 describes the related parameters. Go to the LTS console to create a log group and log stream. For details, see Creating Log Groups and Log Streams.
    Table 1 Log parameters
    Example Value
    Log Group
    Select a log group or click View Log Group to go to the LTS console and create a log group.
    lts-group-qhse
    HTTP Attack Log
    If this option is enabled, select a log stream or click View Log Stream to go to the LTS console and create a log stream.
    lts-topic-8dvf
    DDoS Attack Log
    lts-topic-8n7I
  5. Click OK.
Viewing Protection Logs on LTS
  2. Click in the upper left corner of the page and choose Management & Deployment > Log Tank Service.
  3. In the log group list, click to expand the log group (for example, lts-group-EdgeSec).
  4. Viewing attack logs
    1. In the log stream list, click the name of the configured attack log stream.
      Figure 1 Log stream name configured for attack logs
    2. View attack logs.
Fields in HTTP attack logs
Field
Type
Remarks
id
string
Attack event ID.
geo
string
Geolocation
c indicates the country, and r indicates the province.
sip
string
Attacking source IP address
attackTime
string
Attack time
tenantId
string
Tenant ID
host
string
Domain name
hostId
string
Domain name ID
enterpriseProjectId
string
Enterprise project ID
projectId
string
Project ID of the region where the tenant is located
siteSn
string
Site name
rule
string
Rule ID
ruleName
sting
Rule name
method
string
Attack request method
url
string
Attack request URL
requestHeader
string
Attack request header
requestParams
string
Attack request parameters
cookie
string
Attack request cookie
requestBody
string
Attack request body
status
string
Attack response code
When functioning as a web server, the Nginx processes client requests and returns this response code.
responseHeaders
string
Attack response header
responseBody
string
Attack response body
responseSize
long
Attack response body size
upstreamStatus
string
Attack response code of the upstream server
Response code returned by the upstream server when the Nginx functions as a reverse proxy server which forwards a client request to the upstream server.
upstreamResponseTime
string
Attack response time
processTime
string
Attack processing time
attackCount
long
Number of attacks
attackCategory
string
Attack type
attack
string
Attack details
The key and value of attack indicate the attack type and number of attacks, respectively. The key and value of action indicate the protection action and number of actions, respectively.
maliciousData
string
Malicious data that triggers the rule
maliciousLocation
string
Malicious data location
policyId
string
Policy ID
Fields in DDoS attack logs
Field
Type
Remarks
id
string
Attacked target IP address
attackTime
long
Attack time
tenantId
string
Tenant ID
siteId
string
Site ID
attackType
string
Attack source type
avgBps
long
Average attack traffic bandwidth
avgPps
long
Average number of forwarded attack data packets
maxBps
long
Maximum attack traffic bandwidth
maxPps
long
Maximum number of forwarded attack data packets
Log Tag Fields
Field
Type
Remarks
_resource_id
string
Resource ID
Attack source. Currently, HTTP and DDoS are supported.
_resource_name
string
Resource name.
Log type. Currently, only attack logs are supported.
_service_type
string
Service type.
Cloud service type. The value is EdgeSec.
