Help Center/ Edge Security/ User Guide/ Monitoring/ Configuring a Monitoring Alarm Rule
Updated on 2024-07-26 GMT+08:00
You can set EdgeSec alarm rules to customize the monitored objects and notification policies, and set parameters such as the alarm rule name, monitored object, metric, threshold, monitoring period, and whether to send notifications. This helps you learn the EdgeSec protection status in a timely manner.
The domain name to be protected has been connected to EdgeSec.
  1. Click in the upper left corner of the page and choose Management & Governance > Cloud Eye.
  2. In the navigation pane on the left, choose Alarm Management > Alarm Rules.
  3. In the upper right corner of the page, click Create Alarm Rule.
  4. Set the parameters as prompted. The key parameters are as follows. For details about more parameters, see Creating an Alarm Rule.
    • Alarm Type: Events
    • Event Type: system event and customized event
    Figure 1 EdgeSec monitoring alarm rule
  5. Click Create. In the displayed dialog box, click OK.
