- What's New
- Function Overview
- Billing
User Guide
- Enabling EdgeSec
- Site Acceleration
Security Protection
- Connecting a Domain Name to EdgeSec
- Dashboard
- Protection Statistics
Protection Policy
- Creating a Protection Policy
- Applying a Policy to Your Website
Configuring Protection Policies
- Configuration Guidance
- Configuring Basic Protection Rules to Defend Against Common Web Attacks
- Configuring CC Attack Protection Rules to Defend Against CC Attacks
- Configuring a Precise Protection Rule
- Creating a Reference Table to Configure Protection Metrics In Batches
- Configuring IP Address Blacklist and Whitelist Rules to Block Specified IP Addresses
- Configuring a Known Attack Source Rule
- Configuring Geolocation Access Control Rules to Block Requests from Specific Locations
- Configuring a BOT Protection Rule
- Configuring a Global Whitelist Rule to Ignore False Positives
- Configuring a Data Masking Rule
- Address Group Management
- System Management
- Permissions Management
- Key Operations Recorded by CTS
- Best Practices
API Reference
- Before You Start
- API Overview
- API Calling
API
- Protected Domain Name Management
HTTP Protection Policy Management
- This API is used to query the protection policy list.
- This API is used to create a protection policy.
- This API is used to query a protection policy.
- This API is used to update a protection policy.
- This API is used to delete a protection policy.
- This API is used to update domain names a policy applies to.
- This API is used to update a protection policy rule.
- EdgeSec HTTP Protection Rule Management - CC
- HTTP Protection Rule Management - Precise Protection
HTTP Protection Rule Management - IP Address Blacklist and Whitelist
- This API is used to query IP address blacklist and whitelist rules.
- This API is used to create an IP address blacklist or whitelist rule.
- This API is used to query an IP address blacklist or whitelist rule.
- This API is used to update an IP address blacklist or whitelist rule.
- This API is used to delete a blacklist or whitelist rule.
HTTP Protection Rule Management - Geographical Location
- This API is used to query the geolocation access control rules.
- This API is used to create a geolocation access control rule.
- This API is used to query a geolocation access control rule.
- This API is used to update a geolocation access control rule.
- This API is used to delete a geolocation access control rule.
HTTP Protection Rule Management - False Alarm Masking
- This API is used to query false alarm masking rules.
- This API is used to add a false alarm masking rule.
- This API is used to query a false alarm masking rule.
- This API is used to update a false alarm masking rule.
- This API is used to delete a false alarm masking rule.
- This API is used to reset a false alarm masking rule.
- HTTP Protection Rule Management - Attack Penalty
- IP Address Group Management
- Security Overview
- Reference Table Management
- DDoS Statistics
- HTTP Statistics
- DDoS Attack Logs
Appendix
- Status Code
- Error Codes
Troubleshooting
- EdgeSec.00000005 Invalid Parameter
- EdgeSec.00000013 Concurrent Modification Exception
- EdgeSec.00000014 Only Default Enterprise Project Supported (Not support operation in this enterprise project)
- EdgeSec.00000015 Write Operation Not Supported When All Enterprise Projects Are Selected (All enterprise projects do not support the write operation)
- EdgeSec.00000018 Migration of Resources to Non-Default Enterprise Project Not Supported (This version only supports default enterprise project)
- EdgeSec.00000019 Frozen Resources Cannot Be Migrated to or from an Enterprise Project (frozen cannot create eps tag)
- EdgeSec.00000023 Operation Not Supported by the Current Specifications
- EdgeSec.00000025 Invalid Block Time (Invalid block time)
- EdgeSec.00000026 Invalid Whitelist Rule Type (Invalid rule type)
- EdgeSec.00000027 Invalid CC Rule Condition Length (Invalid cc condition length value)
- EdgeSec.00010001 Invalid IAM Service Project (Failed to get IAM projects)
- EdgeSec.00010005 Insufficient WAF Policy Rule Quota
- EdgeSec.00010006 Blacklist and Whitelist Rules of Edge WAF Exceed the Quota
- EdgeSec.00010007 Insufficient IP Address Group Quota of Edge WAF
- EdgeSec.00010008 Insufficient Edge WAF Certificate Quota
- EdgeSec.00030001 Invalid DDoS Overview Parameters (Illegal Elasticsearch Request)
- EdgeSec.00030003 DDoS Overview Query Type Exception (Statistic Type Error)
- EdgeSec.00030002 DDoS Overview Query Type Exception (Search Error)
- EdgeSec.00040007 No Permission To Operate
- EdgeSec.00040013 Insufficient Top-Level Domain Name Quota
- EdgeSec.00040014 Expansion Resource Quota Has Been Used
- WAF.00022002 Resource Already Exists (Domain Already Exists)
- WAF.00014002 Resource Already Exists
- common.01010003 No Purchase Permission
- Obtaining a Project ID
- SDK Reference
- About the Product
About Functions
- How Does EdgeSec Detect SQL Injection, XSS, and PHP Injection Attacks?
- How Do I Obtain the Real IP Address of a Visitor in EdgeSec?
- How Does EdgeSec Block Requests?
- Do I Need to Enable All Ports When Configuring an EdgeSec Whitelist in a Security Group?
- Why Do Cookies Contain the HWEdgeSecSESID or HWEdgeSecSESTIME field?
- Does Edge Security Support Alarm Notifications for Attacks?
- Regions and AZs
On this page
Show all
Querying Traces
After you enable CTS, the system starts recording operations on EdgeSec. You can view the operation records of the last 7 days on the CTS console.
For details about how to view audit logs, see Querying Real-Time Traces (for New Console).
Parent topic: Key Operations Recorded by CTS
