Configuring a Precise Protection Rule
EdgeSec allows you to customize protection rules by combining HTTP headers, cookies, URLs, request parameters, and client IP addresses.
You can combine common HTTP fields, such as IP, Path, Referer, User Agent, and Params in a protection rule to let EdgeSec block or only log the requests that match the combined conditions.
A reference table can be added to a precise protection rule. The reference table takes effect for all protected domain names.
A protected website has been added. For details, see Adding a Website to EdgeSec.
- It takes several minutes for a new rule to take effect. After the rule takes effect, protection events triggered by the rule will be displayed on the Events page.
- If you configure Protective Action to Block for a precise protection rule, you can configure a known attack source rule by referring to Configuring a Known Attack Source Rule. EdgeSec will block requests matching the configured IP address, Cookie, or Params for a length of time configured as part of the rule.
Application Scenarios
Precise protection rules are used for anti-leeching and website management background protection.
- Click
in the upper left corner of the page and choose .
- In the navigation pane on the left, choose Website Settings page is displayed. . The
- In the Policy column of the row containing the domain name, click the number to go to the Policies page.
Figure 1 Website list
- In the Precise Protection configuration area, change Status as needed and click Customize Rule to go to the Precise Protection page.
Figure 2 Precise Protection configuration area
- On the Precise Protection page, set Detection Mode.
Two detection modes are available:
- Instant Detection: If a request matches a configured precise protection rule, EdgeSec immediately ends threat detection and blocks the request.
When the request meets the blocking conditions in Precise Protection, CC attack detection is still performed.
- Full Detection: If a request matches a configured precise protection rule, EdgeSec finishes its scan first and then blocks all requests that match the configured precise protection rule.
Figure 3 Setting Detection Mode
- Click Add Rule.
- In the displayed dialog box, add a rule by referring to Table 1 and Table 2.
The settings shown in Figure 4 are used as an example. If a visitor tries to access a URL containing /admin, EdgeSec will block the request.
To ensure that EdgeSec blocks only attack requests, configure Protective Action to Log only first and check whether normal requests are blocked on the Events page. If no normal requests are blocked, configure Protective Action to Block.
Table 1 Rule parameters Parameter
Example Value
Rule Name
Name of a user-defined precise protection rule.
Condition List
Click Add to add conditions. At least one condition needs to be added. You can add up to 30 conditions to a protection rule. If more than one condition is added, all of the conditions must be met for the rule to be applied. A condition includes the following parameters:
Parameters for configuring a condition are described as follows:- Field
- Subfield: Configure this field only when IP, Params, Cookie, or Header is selected for Field.
NOTICE:
The length of a subfield cannot exceed 2,048 bytes. Only digits, letters, underscores (_), and hyphens (-) are allowed.
- Logic: Select a logical relationship from the drop-down list.
- If Include any value, Exclude any value, Equal to any value, Not equal to any value, Prefix is any value, Prefix is not any of them, Suffix is any value, or Suffix is not any of them is selected, select an existing reference table in the Content drop-down list. For details, see Creating a Reference Table to Configure Protection Metrics In Batches.
- Exclude any value, Not equal to any value, Prefix is not any of them, and Suffix is not any of them indicates, respectively, that EdgeSec performs the protection action (block or log only) when the field in the access request does not contain, is not equal to, or the prefix or suffix is not any value set in the reference table. For example, assume that Path field is set to Exclude any value and the test reference table is selected. If test1, test2, and test3 are set in the test reference table, EdgeSec performs the protection action when the path of the access request does not contain test1, test2, or test3.
- If the condition is length-related logic, the length value cannot be too large. Large requests can be intercepted before reaching WAF, preventing them from being processed and making protection rules ineffective.
- Content: Enter or select the content of condition matching.
NOTE:For more details about the configurations in general, see Table 2.
- Path Include /admin
- User Agent Prefix is not mozilla/5.0
- IP Equal to 192.168.2.3
- Cookie key1 Prefix is not jsessionid
Protective Action
You can select Block, Allow, Record only, or JS Challenge (EdgeSec returns JavaScript code).
NOTE:JS challenge cannot be performed across domains.
Block
Known Attack Source
If you set Protective Action to Block, you can select a blocking type for a known attack source rule. EdgeSec will block requests matching the configured IP address, Cookie, or Params for a length of time configured as part of the rule.
Long-term IP address blocking
Priority
Rule priority. If you have added multiple rules, rules are matched by priority. The smaller the value you set, the higher the priority.
NOTICE:If multiple precise access control rules have the same priority, EdgeSec matches the rules in the sequence of time the rules are added.
5
Effective Date
Select Immediate to enable the rule immediately, or select Custom to configure when you wish the rule to be enabled.
Immediate
Table 2 Condition list configurations Field
Subfield
Logic
Example Content
Path: Part of a URL that does not include a domain name. This value supports exact matches only. For example, if the path to be protected is /admin, Path must be set to /admin.
None
/buy/phone/
NOTICE:If Path is set to /, all paths of the website are protected.
User Agent: A user agent of the scanner to be checked.
None
Mozilla/5.0 (Windows NT 6.1)
IP: An IP address of the visitor to be protected.
- Client IP Address
- X-Forwarded-For
XXX.XXX.1.1
Params: A request parameter.
None
201901150929
Cookie: A small piece of data to identify web visitors
- All fields
- Any subfield
- Custom
jsessionid
Referer: A user-defined request resource.
For example, if the protected path is /admin/xxx and you do not want visitors to access the page from www.test.com, set Content to http://www.test.com.
None
http://www.test.com
Header: A user-defined HTTP header.
- All fields
- Any subfield
- Custom
text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Method: the user-defined request method.
None
GET, POST, PUT, DELETE, and PATCH
Request Line: Length of a user-defined request line.
None
50
Request: Length of a user-defined request. It includes the request header, request line, and request body.
None
None
ASN: AS number
- Include
- Exclude
- Greater than
- Less than
Geolocation
- Include
- Exclude
Known feature crawler
- Match
- Mismatch
- Search engine
- Scanner
- Script tool
- Other
- Click Confirm. You can then view the added precise protection rule in the protection rule list.
- To modify a rule, click Edit in the row containing the rule.
- To delete a rule, click Delete in the row containing the rule.
Protection Effect
If you have configured a precise protection rule as shown in Figure 4 for your domain name, to verify EdgeSec is protecting your website (www.example.com) against the rule:
- Clear the browser cache and enter the domain name in the address bar to check whether the website is accessible.
- If the website is inaccessible, connect the website domain name to EdgeSec by following the instructions in Adding a Website to EdgeSec.
- If the website is accessible, go to 2.
- Clear the browser cache and enter http://www.example.com/admin (or any page containing /admin) in the address bar. Normally, EdgeSec blocks the requests that meet the conditions and returns the block page.
Configuration Example - Disallowing Access Requests from IP Addresses in a Specified Region
Assume that domain name www.example.com has been connected to EdgeSec and you want to disallow only IP addresses in BeijingSingapore, to access the domain name. Perform the following steps:
- Add a precise protection rule. Set the Field to Geolocation, Content to BeijingSingapore, and Protective Action to Block.
- Enable the precise protection rule.
Figure 5 Precise Protection configuration area
- Clear the browser cache and access http://www.example.com.
When an access request from IP addresses in BeijingSingapore accesses a page, EdgeSec blocks the access request, as shown in Block page.
- Go to the EdgeSec console. In the navigation pane on the left, choose Events. View the event on the Events page. You will see that all requests from BeijingSingapore have been blocked.
