- What's New
- Function Overview
- Billing
User Guide
- Enabling EdgeSec
- Site Acceleration
Security Protection
- Connecting a Domain Name to EdgeSec
- Dashboard
- Protection Statistics
Protection Policy
- Creating a Protection Policy
- Applying a Policy to Your Website
Configuring Protection Policies
- Configuration Guidance
- Configuring Basic Protection Rules to Defend Against Common Web Attacks
- Configuring CC Attack Protection Rules to Defend Against CC Attacks
- Configuring a Precise Protection Rule
- Creating a Reference Table to Configure Protection Metrics In Batches
- Configuring IP Address Blacklist and Whitelist Rules to Block Specified IP Addresses
- Configuring a Known Attack Source Rule
- Configuring Geolocation Access Control Rules to Block Requests from Specific Locations
- Configuring a BOT Protection Rule
- Configuring a Global Whitelist Rule to Ignore False Positives
- Configuring a Data Masking Rule
- Address Group Management
- System Management
- Permissions Management
- Key Operations Recorded by CTS
- Best Practices
API Reference
- Before You Start
- API Overview
- API Calling
API
- Protected Domain Name Management
HTTP Protection Policy Management
- This API is used to query the protection policy list.
- This API is used to create a protection policy.
- This API is used to query a protection policy.
- This API is used to update a protection policy.
- This API is used to delete a protection policy.
- This API is used to update domain names a policy applies to.
- This API is used to update a protection policy rule.
- EdgeSec HTTP Protection Rule Management - CC
- HTTP Protection Rule Management - Precise Protection
HTTP Protection Rule Management - IP Address Blacklist and Whitelist
- This API is used to query IP address blacklist and whitelist rules.
- This API is used to create an IP address blacklist or whitelist rule.
- This API is used to query an IP address blacklist or whitelist rule.
- This API is used to update an IP address blacklist or whitelist rule.
- This API is used to delete a blacklist or whitelist rule.
HTTP Protection Rule Management - Geographical Location
- This API is used to query the geolocation access control rules.
- This API is used to create a geolocation access control rule.
- This API is used to query a geolocation access control rule.
- This API is used to update a geolocation access control rule.
- This API is used to delete a geolocation access control rule.
HTTP Protection Rule Management - False Alarm Masking
- This API is used to query false alarm masking rules.
- This API is used to add a false alarm masking rule.
- This API is used to query a false alarm masking rule.
- This API is used to update a false alarm masking rule.
- This API is used to delete a false alarm masking rule.
- This API is used to reset a false alarm masking rule.
- HTTP Protection Rule Management - Attack Penalty
- IP Address Group Management
- Security Overview
- Reference Table Management
- DDoS Statistics
- HTTP Statistics
- DDoS Attack Logs
Appendix
- Status Code
- Error Codes
Troubleshooting
- EdgeSec.00000005 Invalid Parameter
- EdgeSec.00000013 Concurrent Modification Exception
- EdgeSec.00000014 Only Default Enterprise Project Supported (Not support operation in this enterprise project)
- EdgeSec.00000015 Write Operation Not Supported When All Enterprise Projects Are Selected (All enterprise projects do not support the write operation)
- EdgeSec.00000018 Migration of Resources to Non-Default Enterprise Project Not Supported (This version only supports default enterprise project)
- EdgeSec.00000019 Frozen Resources Cannot Be Migrated to or from an Enterprise Project (frozen cannot create eps tag)
- EdgeSec.00000023 Operation Not Supported by the Current Specifications
- EdgeSec.00000025 Invalid Block Time (Invalid block time)
- EdgeSec.00000026 Invalid Whitelist Rule Type (Invalid rule type)
- EdgeSec.00000027 Invalid CC Rule Condition Length (Invalid cc condition length value)
- EdgeSec.00010001 Invalid IAM Service Project (Failed to get IAM projects)
- EdgeSec.00010005 Insufficient WAF Policy Rule Quota
- EdgeSec.00010006 Blacklist and Whitelist Rules of Edge WAF Exceed the Quota
- EdgeSec.00010007 Insufficient IP Address Group Quota of Edge WAF
- EdgeSec.00010008 Insufficient Edge WAF Certificate Quota
- EdgeSec.00030001 Invalid DDoS Overview Parameters (Illegal Elasticsearch Request)
- EdgeSec.00030003 DDoS Overview Query Type Exception (Statistic Type Error)
- EdgeSec.00030002 DDoS Overview Query Type Exception (Search Error)
- EdgeSec.00040007 No Permission To Operate
- EdgeSec.00040013 Insufficient Top-Level Domain Name Quota
- EdgeSec.00040014 Expansion Resource Quota Has Been Used
- WAF.00022002 Resource Already Exists (Domain Already Exists)
- WAF.00014002 Resource Already Exists
- common.01010003 No Purchase Permission
- Obtaining a Project ID
- SDK Reference
- About the Product
About Functions
- How Does EdgeSec Detect SQL Injection, XSS, and PHP Injection Attacks?
- How Do I Obtain the Real IP Address of a Visitor in EdgeSec?
- How Does EdgeSec Block Requests?
- Do I Need to Enable All Ports When Configuring an EdgeSec Whitelist in a Security Group?
- Why Do Cookies Contain the HWEdgeSecSESID or HWEdgeSecSESTIME field?
- Does Edge Security Support Alarm Notifications for Attacks?
- Regions and AZs
After this function is enabled, EdgeSec can defend against common web attacks, such as SQL injections, XSS, remote overflow vulnerabilities, file inclusions, Bash vulnerabilities, remote command execution, directory traversal, sensitive file access, and command/code injections. You can also enable basic web protection, such as web shell detection.
A protected website has been added. For details, see Adding a Website to EdgeSec.
- Basic web protection has two modes: Block and Log only.
- It takes several minutes for a new rule to take effect. After the rule takes effect, protection events triggered by the rule will be displayed on the Events page.
- If you select Block for Basic Web Protection, you can configure access control criteria for a known attack source. EdgeSec will block requests matching the configured IP address, Cookie, or Params for a length of time configured as part of the rule.
- Click
in the upper left corner of the page and choose Content Delivery & Edge Computing > CDN and Security.
- In the navigation pane on the left, choose Edge Security > Website Settings. The Website Settings page is displayed.
- In the Policy column of the row containing the domain name, click the number to go to the Policies page.
Figure 1 Website list
- In the Basic Web Protection configuration area, change Status and Mode as needed by referring to Table 1.
Figure 2 Basic Web Protection configuration area
- In the Basic Web Protection configuration area, click Advanced Settings.
- On the Protection Status tab page, enable protection types you need by referring to Table 2.
Figure 3 Basic web protection
NOTICE:
If you select Mode for Block on the Protection Status tab, you can select a known attack source rule to let EdgeSec block requests accordingly. For details, see Configuring a Known Attack Source Rule.
- Set the protection type.
NOTICE:
By default, General Check is enabled. You can enable other protection types by referring to Table 2.
Table 2 Protection types Type
General Check
Defends against attacks such as SQL injections, XSS, remote overflow vulnerabilities, file inclusions, Bash vulnerabilities, remote command execution, directory traversal, sensitive file access, and command/code injections. SQL injection attacks are mainly detected based on semantics.
If you enable General Check, EdgeSec checks your websites based on the built-in rules.
Webshell Detection
Protects against web shells from upload interface.
If you enable Webshell Detection, EdgeSec detects web page Trojan horses inserted through the upload interface.
Example - Blocking SQL Injection Attacks
If domain name www.example.com has been connected to EdgeSec, perform the following steps to verify that EdgeSec can block SQL injection attacks.
- Enable General Check in Basic Web Protection and set the protection mode to Block.
Figure 4 Enabling General Check
- Enable EdgeSec basic web protection.
Figure 5 Enabling EdgeSec basic web protection
- Clear the browser cache and enter a simulated SQL injection (for example, http://www.example.com?id=' or 1=1) in the address box.
The access request is intercepted, as shown in Figure 6.
- Go to the EdgeSec console. In the navigation pane on the left, choose Events. View the event on the Events page.
