Updated on 2026-03-06 GMT+08:00
Reserved Instance Overview
Concept
A reserved instance (RI) is not an actual instance, but a billing discount that can be applied to the use of pay-per-use ECSs in your account. When the attributes of your pay-per-use ECSs match those of an RI, the RI billing benefit automatically applies to your ECSs. The combination of RIs and pay-per-use billing fully utilizes the flexibility of pay-per-use resources at lower costs.
A purchased RI is billed, regardless of whether it is used or not.
Table 1 ECS billing modes
Billing Mode
How to Use
RI
A billing discount applied to pay-per-use ECSs.
Pay-per-use
A billing mode based on the usage frequency and duration. Pay-per-use ECSs can be created or deleted at any time.
A pay-per-use ECS is a basic computing unit that consists of vCPUs, memory, OS, and EVS disks. After purchasing a pay-per-use ECS, you can use it on the cloud.
Yearly/Monthly
A billing mode based on the required duration. This mode is ideal when the duration of ECS usage is predictable.
A yearly/monthly ECS is a basic computing unit that consists of vCPUs, memory, OS, and EVS disks. After purchasing a yearly/monthly ECS, you can use it on the cloud.
Spot pricing
A spot pricing billing mode.
A spot ECS is a basic computing unit that consists of vCPUs, memory, OS, and EVS disks. After purchasing a spot ECS, you can use it on the cloud.
What Is Attribute Mapping Between an RI and a Pay-per-Use ECS?
A regional RI is purchased for a region and without an AZ specified. A zonal RI is purchased for an AZ.
  • Attribute matching of a regional RI: The instance series, vCPU/memory ratio, and OS of a regional RI must be the same as those of a pay-per-use ECS.
    If you modify specifications or change the OS of an ECS and still want to enjoy the RI discount, you need to purchase a new RI with the same attributes as the ECS.
  • Attribute matching of a zonal RI: The flavor and OS of a zonal RI must be the same as those of a pay-per-use ECS.
Application Scenarios
If your ECSs will be used in a short term, it is a good practice to use the pay-per-use billing mode. If you plan to use ECSs for one or three years, it is a good practice to use RIs. RIs offer discounts for pay-per-use ECSs with matched attributes.
For example, after you purchase two s3.2xlarge Linux RIs with a one-year term in AZ 1, the billing benefit of the RIs is immediately applied to up to two pay-per-use s3.2xlarge Linux ECSs running in AZ 1.
Working Rules
For example, you have a running pay-per-use ECS in your account. After you purchase an RI that matches the attributes of this ECS, the billing benefit of the RI is automatically applied to your ECS when the RI takes effect. A purchased RI takes effect at the next hour.
Table 2 lists RI attributes. You can purchase your desired RIs based on these attributes.
Table 2 RI attributes
Region or AZ
  • Regional RI: indicates an RI purchased in a region, without an AZ specified. Capacity reservations are not supported for regional RIs.
  • Zonal RI: indicates an RI purchased with an AZ specified. Capacity reservations are supported for zonal RIs.
Flavor Name
  • When purchasing a regional RI, ensure that the ECS series and vCPU/memory ratio specified in the RI are the same as those of the target pay-per-use ECS.
  • When purchasing a zonal ECS, ensure that the flavor specified in the RI is the same as that of the target pay-per-use ECS.
After an RI is purchased, its flavor cannot be directly changed, but you can split or combine it. For details, see Modifying RI Attributes.
OS
The OS of the ECS to be bought, which must match the OS specified in your RI. For example, if you want to use a Linux RI, select a Linux public or private image when purchasing an ECS.
Term
The service duration of an RI. A year is defined as 31,536,000 seconds (365 days).
Offering Class
Standard: Certain attributes, such as the instance size, can be modified during the term. However, the instance type cannot be changed.
Payment Option
No upfront
Zonal RIs
A zonal RI refers to an RI purchased for a specified AZ. It offers a billing discount for the ECSs with the same flavor and OS as the RI in that AZ.
For example, after you purchase two c3.xlarge.2 Linux RIs with a one-year term in an AZ, the RI discounts can be applied to up to two pay-per-use c3.xlarge.2 Linux ECSs running in that AZ.
Regional RIs
A regional RI, which is purchased within a specified region, has the following characteristics:
  • AZ flexibility: The RI discount applies to pay-per-use ECS usage in any AZ within a region.
  • Instance size flexibility: The RI discount applies to instance usage for ECSs that have the same instance series, vCPU/memory ratio, and OS as those specified in the regional RI. Instance size flexibility is determined based on the normalization factor of the instance size. Instance size flexibility does not apply to zonal RIs.
Instance size flexibility is applied from the smallest to the largest instance size within the instance series based on the normalization factor. Table 3 describes the instance size within an instance type and corresponding normalization factor per hour.
An ECS automatically benefits from the billing discount offered by a regional RI only when the instance series, vCPU/memory ratio, and OS are the same as those specified in the regional RI.
For example, a regional c3.large.4 RI cannot be used on a c3.large.2 ECS because their vCPU/memory ratios are different.
Table 3 Normalization factors
Instance Size
Normalization Factor
small
medium
large
2
xlarge
4
2xlarge
8
4xlarge
16
6xlarge
24
7xlarge
28
8xlarge
32
9xlarge
36
12xlarge
48
14xlarge
56
15xlarge
60
16xlarge
64
26xlarge
104
52xlarge
208
nxlarge
n × 4
For example, an s3.large.2 ECS has a normalization factor of 2. You purchase an s3.large.2 Linux RI for the CN-Hong Kong region of Huawei Cloud with a one-year term.
  • If you have two running s3.medium.2 pay-per-use Linux ECSs in this region, the billing benefit is fully applied to both ECSs.
    Figure 1 Example RI 1
  • If you have one running s3.xlarge.2 pay-per-use Linux ECS with a normalization factor of 4 in this region, the billing benefit is applied to 50% of the usage of the ECS.
    Figure 2 Example RI 2
Table 4 Comparison between regional and zonal RIs
RI Type
AZ Flexibility
Instance Size Flexibility
Capacity Reservation
Regional RI
Supported
The regional RI discount applies to any AZ in the region.
Supported
The regional RI discount can be applied only when the instance series, vCPU/memory ratio, and OS of the target ECS are the same as those specified in the RI.
Not supported
Resources are not reserved so ECS creation may fail when resources are insufficient.
Zonal RI (not recommended)
Not supported
A zonal RI only applies to a specified AZ.
Not supported
The instance series and OS of a zonal RI must match those of a pay-per-use instance.
Supported
Resources can be reserved for creating pay-per-use ECSs.
Examples
If you have the following pay-per-use ECSs in region A:
  • Five s3.large.2 Windows ECSs in AZ 1
  • Three m3.xlarge.2 Windows ECSs in AZ 2
  • One c3.xlarge.2 Windows ECS in AZ 3
You purchase the following RIs in the same region (region A):
  • Five s3.large.2 Windows RIs with a one-year term in AZ 1
  • Six m3.large.2 Windows RIs with a one-year term in region A
  • One c3.large.2 Windows RI with a one-year term in region A
The RI benefits are applied as follows:
  • Five s3.large.2 zonal RIs are applied to five s3.large.2 ECSs because their attributes (AZ, OS, and ECS type) match.
  • The m3.large.2 regional RIs offer both AZ flexibility and instance size flexibility.
    An m3.large.2 RI has two normalization factors. Six m3.large.2 regional RIs have 12 normalization factors (6 × 2). Your account has three running m3.xlarge.2 ECSs, each has 4 normalization factors, totalling 12 normalization factors (3 x 4). In this case, six m3.large.2 regional RIs can cover three m3.xlarge.2 ECSs.
  • The c3.large.2 regional RIs offer both AZ flexibility and instance size flexibility. They can be applied to c3.xlarge.2 pay-per-use ECSs.
    A c3.large.2 RI has two normalization factors (1 × 2). A c3.xlarge.2 pay-per-use ECS requires an RI with four normalization factors (1 × 4). Therefore, the c3.large.2 RI billing discount applies to 50% of the c3.xlarge.2 usage, and the remaining c3.xlarge.2 usage is billed at the pay-per-use rate without RI discount.
