Obtaining the Password for Logging In to a Windows ECS
Password authentication is required to log in to a Windows ECS. If you select the key pair as the login credential when creating an ECS, you can obtain the administrator password generated when the ECS was initially installed based on the private key file used for creating the ECS. The administrator is the Administrator account or the account configured in Cloudbase-Init. This password is randomly generated, which is secure.
You can obtain the initial password for logging in to a Windows ECS through the management console or APIs. For details, see this section.
You have obtained the private key file (.pem file) which was generated during the ECS creation.
When you selected the key pair login mode during the ECS creation, a private key file (.pem file) was generated during the creation of the key pair. For details about how to create and use a key pair, see Application Scenarios for Using Key Pairs.
If the private key file is lost, you can reset the key pair and bind it to the ECS. If you select I agree to host the private key of the key pair, you can export the managed private key as required. For details, see Exporting a Private Key.
- After obtaining the initial password, you are advised to delete the record from the system to ensure security.
Deleting the initial password record does not affect the ECS operation or login. After the password record is deleted, the password cannot be retrieved. It is a good practice to record the password before deleting the record. For details, see Deleting the Initial Password for Logging In to a Windows ECS.
- The private key file of the ECS must be in .pem format.
If the private key file is in .ppk format, convert it to .pem format. For details, see How Do I Convert the Format of a Private Key File?
Obtaining the Password Through the Management Console
- Obtain the private key file (.pem file) used when you created the ECS.
- Click
in the upper left corner and select a region and project.
- Click
. Under Compute, click Elastic Cloud Server.
- On the Elastic Cloud Server page, select the target ECS.
- In the Operation column, click More and select Get Password.
Figure 1 Get Password
If Get Password is not displayed, the one-click password reset plug-in may not be installed.
In this case, you can reset the password by referring to Resetting the Password for Logging In to a Windows ECS Without the Password Reset Plug-in Installed.
- Use either of the following methods to obtain the password through the private key:
- Click Select File and upload the private key from a local directory.
- Copy the content of the private key file and paste it into the text box.
- Click Get Password to obtain a random password.
Obtaining the Password Through APIs
- Set up the API calling environment.
- Call APIs. For details, see "Before You Start" in the Elastic Cloud Server API Reference.
- Obtain the ciphertext password.
Call the password obtaining APIs to obtain the ciphertext password of the public key encrypted using RSA. The API URI is in the format "GET /v2/{project_id}/servers/{server_id}/os-server-password".
For details, see "Obtaining the Password for Logging In to an ECS" in the Elastic Cloud Server API Reference.
- Decrypt the ciphertext password.
Use the private key file used when you created the ECS to decrypt the ciphertext password obtained in step 4.
- Run the following command to convert the ciphertext password format to ".key -nocrypt" using OpenSSL:
openssl pkcs8 -topk8 -inform PEM -outform DER -in rsa_pem.key -out pkcs8_der.key -nocrypt
- Invoke the Java class library org.bouncycastle.jce.provider.BouncyCastleProvider and use the key file to edit the code decryption ciphertext.
Follow-up Procedure
If the password has been reset, use the new password to log in to the Windows ECS.
If the password has not been reset, use the initial system password obtained in this section to log in to the Windows ECS.
For details about how to log in to the Windows ECS, see Logging In to a Windows ECS.
