Help Center/ Elastic Cloud Server/ User Guide/ Recycle Bin (OBT)/ Recovering an ECS from the Recycle Bin
Updated on 2025-08-28 GMT+08:00
You can recover ECSs from the recycle bin as needed within the kept duration.
If your account is frozen or restricted, the recycle bin is unavailable. ECSs in the recycle bin cannot be recovered.
  2. Click in the upper left corner and select a region and project.
  3. Click . Under Compute, click Elastic Cloud Server.
  4. Click the Recycle Bin tab.
  5. In the recycle bin list, locate the ECS to be recovered and click Recover in the Operation column.
    The Recover ECS page is displayed.
  6. Click Submit.
    • If the recovery is successful, the ECS is displayed in the ECS list and the ECS status is Running.
      To view the details of the ECS associated resources that have been recovered, see Viewing ECS Details.
    • If the recovery fails, the ECS remains in the recycle bin, and the ECS status is Stopped.
      After an ECS is recovered, its associated resources are processed as described in Associated Resource Recycling.
      ECSs recovered from the recycle bin are billed on a pay-per-use basis. If you want to change the billing mode to yearly/monthly, see From Pay-per-Use to Yearly/Monthly.
