Configuring Secure Boot for an ECS
Secure boot is used to check the integrity of each component (driver loader, kernel, and kernel driver) during device startup. This prevents security threats to the system and user data caused by loading and running unauthenticated components.
Secure boot is a feature of the Unified Extensible Firmware Interface (UEFI) that requires all low-level firmware and software components to be verified before being loaded. During the boot process, UEFI secure boot checks the signature of each boot software, including the UEFI firmware driver (or option ROM), Extensible Firmware Interface (EFI) application, OS driver, and binary files. If the signature is valid or recognized by the original equipment manufacturer (OEM), the device will boot, and the firmware will hand over control to the OS.
- After secure boot is enabled, the system verifies component integrity during system startup, which does not affect services.
- After secure boot is disabled, the system does not verify component integrity during system startup, which does not affect services.
Background
UEFI is a standard that describes a new type of interface. It enables an OS to automatically load from a pre-boot operating environment to an OS.
The OSs that use the UEFI boot mode support secure boot. Secure boot provides verification of the boot chain status to ensure that only encrypted and verified UEFI binary files are executed after the firmware is initialized. These binary files include UEFI drivers, primary boot loaders, and chain loading components.
By default, secure boot is disabled and the system is in SetupMode. When the system is in SetupMode, all key variables can be updated without a cryptographic signature. After secure boot is enabled, the system exits SetupMode.
After secure boot is enabled, the system enforces signature validation on any UEFI binary files.
Secure boot uses key databases in a chain of trust, as shown in Table 1. These databases are stored in the UEFI variable storage.
| Key Database | Abbreviation | Mandatory | Description | Format Constraints |
| Platform key database | PK | Yes | The PK database is the root of trust for the secure boot instance. The PK database contains a public PK key, which is used in the chain of trust to update the key exchange key (KEK) database. To change the PK database, you must have the private PK key to sign an update request. This includes deleting the PK database by writing an empty PK key. |
| Key exchange key database | KEK | Yes | The KEK database is a list of public KEK keys used in the chain of trust to update the signature (DB) and the revocation list (DBX) databases. The private KEK is used to add keys to the DB, which is a list of authorized signatures to be booted on the system. To change the public KEK database, you must have the private PK key to sign an update request. |
| Signature database | DB | Yes | The DB database is a list of public keys and hash values used in the chain of trust to verify all UEFI boot binary files. The DB list contains the authorized keys that are allowed to boot on the system. To modify the list, you must have a private KEK. To change the DB database, you must have either the private PK key or any of the private KEK keys to sign an update request. |
| Forbidden signatures database | DBX | No | The DBX database is a list of untrusted public keys and binary hashes used to revoke files in the chain of trust. The DBX database always takes precedence over all other key databases. To change the DBX database, you must have either the private PK key or any of the private KEK keys to sign an update request. You can obtain a publicly available DBX from the UEFI forum. For details, see Unified Extensible Firmware Interface Forum. |
| Timestamp signatures database | DBT | No | The DBT database retains the signature of the code in the timestamp signature database. |
- UEFI secure boot is supported only by the following instance flavors: C7t, kC2, and aC8.
- Keys can be imported only when a private image is being created. Keys cannot be imported on the BIOS boot interface of an ECS.
- Keys or related configurations cannot be imported to an ECS using the mokutil tool.
- BMSs do not support UEFI secure boot.
- For details about the OSs that support UEFI boot, see OSs Supporting UEFI Boot Mode.
- For Windows, you need to download the corresponding certificate from the OS's official website. For details, see Keys Required for Secure Boot on all PCs.
Process Flow
Creating Secure Boot Keys (Linux)
You need to create keys based on the UEFI secure boot standard, create a certificate for each key, convert each certificate into a UEFI signature list (binary file), and sign each certificate using the related key.
The following tools and installation packages are required for creating secure boot keys:
- x86: The sbsign and efitools installation packages are required. For details, see "Preparations" in Huawei Cloud EulerOS Image (x86).
- Arm: The cert-to-efi-sig-list and sign-efi-sig-list command line tools and pesign signature tool are required. For details, see "Preparations" in Huawei Cloud EulerOS Image (Arm).
- Create a globally unique identifier (GUID).
Before creating a key pair, create a GUID for key generation.
- Connect to an ECS.
- Create and access the directory:
mkdir -p ~/certs cd ~/certs
- Create a GUID for key generation.
uuidgen --random > GUID.txt
- (Mandatory) Create a platform key (PK).
A PK is the root of trust for the UEFI secure boot instance.
- Create a key and name the variable PK.
openssl req -newkey rsa:4096 -nodes -keyout PK.key -new -x509 -sha256 -days 3650 -subj "/CN=Platform key/" -out PK.crt
Parameters in this command are described as follows:
- keyout PK.key: the private key file
- days 3650: the certificate validity period
- out PK.crt: the certificate for creating a UEFI variable
- CN=Platform key: common name (CN) of the key. You can enter the name of your enterprise instead of the platform key.
- Create a certificate.
openssl x509 -outform DER -in PK.crt -out PK.cer
- Convert the certificate into a UEFI signature list.
cert-to-efi-sig-list -g "$(< GUID.txt)" PK.crt PK.esl
- Use the private PK to sign the UEFI signature list.
sign-efi-sig-list -g "$(< GUID.txt)" -k PK.key -c PK.crt PK PK.esl PK.auth
- (Mandatory) Create a key exchange key (KEK).
The private KEK is used to add keys to the signature database (DB), which is the list of authorized signatures to boot on the system.
- Create a key.
openssl req -newkey rsa:4096 -nodes -keyout KEK.key -new -x509 -sha256 -days 3650 -subj "/CN=Key Exchange Key/" -out KEK.crt
openssl x509 -outform DER -in KEK.crt -out KEK.cer
cert-to-efi-sig-list -g "$(< GUID.txt)" KEK.crt KEK.esl
- Use the private PK to sign the signature list.
sign-efi-sig-list -g "$(< GUID.txt)" -k PK.key -c PK.crt KEK KEK.esl KEK.auth
- Create a key.
- (Mandatory) Create a signature database (DB).
Boot images will be signed with the private key that is created in this step.
- Create a key.
openssl req -newkey rsa:4096 -nodes -keyout db.key -new -x509 -sha256 -days 3650 -subj "/CN=Signature Database key/" -out db.crt
openssl x509 -outform DER -in db.crt -out db.cer
cert-to-efi-sig-list -g "$(< GUID.txt)" db.crt db.esl
- Use the private KEK to sign the signature list.
sign-efi-sig-list -g "$(< GUID.txt)" -k KEK.key -c KEK.crt db db.esl db.auth
- Create a key.
- (Optional) Create a forbidden signatures database (DBX).
The DBX disables specific DB certificates. It can be a certificate list or a hash list.
- (Optional) Create a timestamp signatures database (DBT).
The DBT database signs signature timestamps. If the DB certificate is in the DBX and the DBX specifies the revocation time, the DB certificate can be used for signature verification only if the signature time is earlier than the revocation time.
Using Keys to Sign ECS Images
The following describes how to sign the kernel and boot files of an ECS image. The signing method varies depending on the CPU architecture and OS. Follow the instructions below that correspond to your environment.
Preparations
Download the sbsign and efitools installation packages.
mkdir -p ~/certs; cd ~/certs yum install mtools -y wget http://rpmfind.net/linux/almalinux/8.10/devel/x86_64/os/Packages/sbsigntools-0.9.4-11.el8.x86_64.rpm wget http://rpmfind.net/linux/almalinux/8.10/devel/x86_64/os/Packages/efitools-1.9.2-9.el8.x86_64.rpm rpm -ivh ./*.rpm
Sign the kernel file.
cd ~/certs sudo sbsign --key db.key --cert db.crt --output /boot/vmlinuz-$(uname -r).signed /boot/vmlinuz-$(uname -r) # Replace the image file. mv /boot/vmlinuz-$(uname -r).signed /boot/vmlinuz-$(uname -r)
Sign the boot files.
cd ~/certs sudo sbsign --key db.key --cert db.crt --output /boot/efi/EFI/hce/grubx64.efi.signed /boot/efi/EFI/hce/grubx64.efi sudo sbsign --key db.key --cert db.crt --output /boot/efi/EFI/hce/shimx64.efi.signed /boot/efi/EFI/hce/shimx64.efi sudo sbsign --key db.key --cert db.crt --output /boot/efi/EFI/hce/mmx64.efi.signed /boot/efi/EFI/hce/mmx64.efi sudo sbsign --key db.key --cert db.crt --output /boot/efi/EFI/hce/fbx64.efi.signed /boot/efi/EFI/hce/fbx64.efi # Replace the original files. sudo mv -f /boot/efi/EFI/hce/grubx64.efi.signed /boot/efi/EFI/hce/grubx64.efi sudo mv -f /boot/efi/EFI/hce/shimx64.efi.signed /boot/efi/EFI/hce/shimx64.efi sudo mv -f /boot/efi/EFI/hce/mmx64.efi.signed /boot/efi/EFI/hce/mmx64.efi sudo mv -f /boot/efi/EFI/hce/fbx64.efi.signed /boot/efi/EFI/hce/fbx64.efi
Replace the files in the BOOT directory.
cp /boot/efi/EFI/hce/shimx64.efi /boot/efi/EFI/BOOT/BOOTX64.EFI cp /boot/efi/EFI/hce/grubx64.efi /boot/efi/EFI/BOOT/grubx64.efi cp /boot/efi/EFI/hce/mmx64.efi /boot/efi/EFI/BOOT//mmx64.efi cp /boot/efi/EFI/hce/fbx64.efi /boot/efi/EFI/BOOT/fbx64.efi
Preparations
Obtain the cert-to-efi-sig-list and sign-efi-sig-list command line tools from the rpmfind.net website.
Download the pesign signing tool.
yum install pesign -y
Prepare the signing environment.
In the Kunpeng architecture, use the pesign tool to encapsulate the db.key and db.crt into the NSS database. This operation requires a password. In this example, the password is ${pwd}. Run the following command to combine the DB certificate into a PKCS#12 file:
openssl pkcs12 -export -inkey db.key -in db.crt -out db.p12 -name "My-DB-Cert"
# Create and import the database.
mkdir ./cert_db
certutil -N -d ./cert_db --empty-password
# Enter the password ${pwd}.
pk12util -i db.p12 -d ./cert_db Sign the kernel file.
- Decompress the kernel of the Huawei Cloud EulerOS image and restore it from the gzip format to the PE format.
# Decompress the vmlinuz file of Huawei Cloud EulerOS. zcat /boot/vmlinuz-`uname -r` > /boot/vmlinuz.raw # Check the signature information of the original vmlinuz file. pesign -i /boot/vmlinuz.raw -S
Expected output:
# pesign -i /boot/vmlinuz.raw -S --------------------------------------------- certificate address is 0xffff98e4c208 Content was not encrypted. Content is detached; signature cannot be verified. The signer's common name is HCE Secure Boot RSA Code-Signing Authority 2 No signer email address. No signing time included. There were certs or crls included. ---------------------------------------------
- Sign the kernel.
# Sign the kernel. pesign -n ./cert_db -c "My-DB-Cert" -s -i /boot/vmlinuz.raw -o /boot/vmlinuz-signed.eif -f
- Check whether the signature can be verified.
openssl x509 -in db.crt -outform DER -out db.der pesigcheck -v -i /boot/vmlinuz-signed.eif -c db.der -n 1
Expected output:
linux-EjmSNO(AgentVM):~/certs # pesigcheck -v -i /boot/vmlinuz-signed.eif -c db.der -n 1 Searching dbx MokListXRT-605dab50-e046-4300-abb6-3dd810dd8b23 Searching db MokListRT-605dab50-e046-4300-abb6-3dd810dd8b23 Searching db db.der Searching dbx MokListXRT-605dab50-e046-4300-abb6-3dd810dd8b23 Searching db MokListRT-605dab50-e046-4300-abb6-3dd810dd8b23 Searching dbx MokListXRT-605dab50-e046-4300-abb6-3dd810dd8b23 Searching db MokListRT-605dab50-e046-4300-abb6-3dd810dd8b23 Certificate type not approved for application. Searching db db.der Certificate type not approved for application. Whitelist entry: put a breakpoint at pesigcheck.c:179 put a breakpoint at pesigcheck.c:172 cert: 0xaaaad7a5c038 put a breakpoint at pesigcheck.c:172 cert: 0xaaaad7a5c050 pesigcheck: "/boot/vmlinuz-signed" is valid.
- Back up the original boot files.
# Back up the boot files. cp /boot/efi/EFI/hce/shimaa64.efi /boot/efi/EFI/hce/shimaa64.efi.bak cp /boot/efi/EFI/hce/grubaa64.efi /boot/efi/EFI/hce/grubaa64.efi.bak cp /boot/efi/EFI/hce/mmaa64.efi /boot/efi/EFI/hce/mmaa64.efi.bak cp /boot/efi/EFI/hce/fbaa64.efi /boot/efi/EFI/hce/fbaa64.efi.bak
- Sign boot files.
# Sign. pesign -n ./cert_db -c "My-DB-Cert" -s -i /boot/efi/EFI/hce/shimaa64.efi -o /boot/efi/EFI/hce/shimaa64.efi.signed -f pesign -n ./cert_db -c "My-DB-Cert" -s -i /boot/efi/EFI/hce/grubaa64.efi -o /boot/efi/EFI/hce/grubaa64.efi.signed -f pesign -n ./cert_db -c "My-DB-Cert" -s -i /boot/efi/EFI/hce/mmaa64.efi -o /boot/efi/EFI/hce/mmaa64.efi.signed -f pesign -n ./cert_db -c "My-DB-Cert" -s -i /boot/efi/EFI/hce/fbaa64.efi -o /boot/efi/EFI/hce/fbaa64.efi.signed -f
- Check whether the signing is successful.
pesign -i /boot/efi/EFI/hce/shimaa64.efi.signed -S pesign -i /boot/efi/EFI/hce/grubaa64.efi.signed -S pesign -i /boot/efi/EFI/hce/mmaa64.efi.signed -S pesign -i /boot/efi/EFI/hce/fbaa64.efi.signed -S
Expected output:
--------------------------------------------- certificate address is 0xffffa37bc008 Content was not encrypted. Content is detached; signature cannot be verified. The signer's common name is HCE Secure Boot RSA Code-Signing Authority 2 No signer email address. No signing time included. There were certs or crls included. --------------------------------------------- certificate address is 0xffffa37bcef8 Content was not encrypted. Content is detached; signature cannot be verified. The signer's common name is Signature Database key No signer email address. Signing time: Sun May 10, 2026 There were certs or crls included. ---------------------------------------------
- Replace the original boot files.
mv /boot/efi/EFI/hce/shimaa64.efi.signed /boot/efi/EFI/hce/shimaa64.efi mv /boot/efi/EFI/hce/grubaa64.efi.signed /boot/efi/EFI/hce/grubaa64.efi mv /boot/efi/EFI/hce/mmaa64.efi.signed /boot/efi/EFI/hce/mmaa64.efi mv /boot/efi/EFI/hce/fbaa64.efi.signed /boot/efi/EFI/hce/fbaa64.efi
cp /boot/efi/EFI/hce/shimaa64.efi /boot/efi/EFI/BOOT/BOOTAA64.EFI cp /boot/efi/EFI/hce/fbaa64.efi /boot/efi/EFI/BOOT/fbaa64.efi cp /boot/efi/EFI/hce/mmaa64.efi /boot/efi/EFI/BOOT/mmaa64.efi
Modify the grub.cfg file.
- Ensure that the Linux command points to the uncompressed kernel that you have signed.
vim /boot/grub2/grub.cfg
- Point the Linux path to the decompressed, signed kernel file.
The Linux path is /vmlinuz-signed.eif, rather than /boot/vmlinuz-signed.eif.
... linux /vmlinuz-signed.eif .... ....
Preparations
Install the required package.
apt install sbsigntool efitools uuid-runtime -y
mkdir ~/certs cd ~/certs sudo sbsign --key db.key --cert db.crt --output /boot/vmlinuz-$(uname -r).signed /boot/vmlinuz-$(uname -r) # Replace the image file. mv /boot/vmlinuz-$(uname -r).signed /boot/vmlinuz-$(uname -r)
cd ~/certs sudo sbsign --key db.key --cert db.crt --output /boot/efi/EFI/ubuntu/grubx64.efi.signed /boot/efi/EFI/ubuntu/grubx64.efi sudo sbsign --key db.key --cert db.crt --output /boot/efi/EFI/ubuntu/shimx64.efi.signed /boot/efi/EFI/ubuntu/shimx64.efi sudo sbsign --key db.key --cert db.crt --output /boot/efi/EFI/ubuntu/mmx64.efi.signed /boot/efi/EFI/ubuntu/mmx64.efi # Replace the original files. sudo mv /boot/efi/EFI/ubuntu/grubx64.efi.signed /boot/efi/EFI/ubuntu/grubx64.efi sudo mv /boot/efi/EFI/ubuntu/shimx64.efi.signed /boot/efi/EFI/ubuntu/shimx64.efi sudo mv /boot/efi/EFI/ubuntu/mmx64.efi.signed /boot/efi/EFI/ubuntu/mmx64.efi
cp /boot/efi/EFI/ubuntu/shimx64.efi /boot/efi/EFI/BOOT/BOOTX64.EFI cp /boot/efi/EFI/ubuntu/grubx64.efi /boot/efi/EFI/BOOT/grubx64.efi cp /boot/efi/EFI/ubuntu/mmx64.efi /boot/efi/EFI/BOOT/mmx64.efi
Obtaining a Secure Boot Certificate
Contact the image provider to obtain a secure boot certificate.
Transcoding the Secure Boot Certificate
- Platform Key (PK) transcoding
__platform_key=$(cat PK.cer | base64 -w 0)
- Key Exchange Key (KEK) transcoding
__key_exchange_key=$(cat KEK.cer | base64 -w 0)
- Signature Database (DB) transcoding
__signature_database=$(cat db.cer | base64 -w 0)
- Forbidden Signatures Database (DBX) transcoding
__forbidden_signatures_database=$(cat dbx.cer | base64 -w 0)
- Timestamp Signatures Database (DBT) transcoding
__timestamp_signatures_database=$(cat dbt.cer | base64 -w 0)
- PK.cer is the platform key (PK) certificate.
- KEK.cer is the Key Exchange Key (KEK) certificate.
- db.cer is the Signature Database (DB) certificate.
- dbx.cer is the Forbidden Signatures Database (DBX) certificate.
- dbt.cer is the Timestamp Signatures Database (DBT) certificate.
Creating a Private Image
You can create a private image using IMS. A private image can be created using either of the following methods:
Updating Secure Boot Image Metadata
You can call the following API to update the image metadata:
hw_firmware_type=uefi
__support_secure_boot=true
__platform_key=${__platform_key}
__key_exchange_key=${__key_exchange_key}
__signature_database=${__signature_database}
__forbidden_signatures_database=${__forbidden_signatures_database}
__timestamp_signatures_database=${__timestamp_signatures_database} Enabling Secure Boot for an Image
- Click
in the upper left corner and select a region and project. - Choose Compute > Image Management Service to access the IMS console.
- Click the Private Images tab to show the image list.
- Locate the row containing the target image and click Modify in the Operation column.
- In the displayed dialog box, select the UEFI boot mode.
- After secure boot is enabled, specify the key databases.
- Click OK.
- Click
in the upper left corner and select a region and project. - Click
. Under Compute, click Elastic Cloud Server. - Click Buy ECS.
- Set Trusted Settings based on service requirements.
- To enable secure boot, select Secure boot.
- To disable secure boot, deselect Secure boot.
For details about how to configure basic, network, and advanced settings when purchasing an ECS, see Purchasing an ECS in Custom Config Mode.
- Click OK.
Follow-up Operations
- (Windows) Check whether UEFI secure boot is enabled.
- Open the msinfo32 tool.
- Check the Secure Boot State field.
If the value of Secure Boot State is Supported, UEFI secure boot is enabled.
- (Linux) Check whether UEFI secure boot is enabled.
- Run the following command on the ECS:
mokutil --sb
- View the command output.
- If UEFI secure boot is enabled, the command output contains SecureBoot enabled.
- If UEFI secure boot is not enabled, the command output contains SecureBoot disabled or Failed to read SecureBoot.
