QingTian Enclave Log Forwarding Tool
Updated on 2025-01-02 GMT+08:00
Overview
QingTian Enclave log (qlog) is an O&M tool for QingTian Enclave. A QingTian Enclave instance is a completely isolated sub-VM running in a QingTian VM. Even the root user cannot log in to the QingTian Enclave instance via SSH. To help O&M personnel monitor services running in QingTian Enclave and locate faults, the qlog tool is provided. qlog can collect specified log files and resource usage (CPU and memory usages) of QingTian Enclave instances and send the collected data to the parent instance.
The qlog tool is an executable binary file. It needs to be executed using different commands on the parent instance and QingTian Enclave instance.
  • On the parent instance, run /path/to/qlog receive-file <cid>/path/to/config_qlog.toml to enable qlog.
  • On a QingTian Enclave instance, run /path/to/qlog monitor /path/to/config_qlog.toml to enable qlog.
Service logs of traditional VMs are stored in a directory similar to /var/log/service.log.
After services are migrated to QingTian Enclave, you can use qlog to export the log files (stored in /var/log/service.log) to the parent instances.
You can run qlog receive-file and qlog monitor on the parent instance and QingTian Enclave instance, respectively, to execute a given qlog binary file. A local vsock-based communication link is established between them. The qlog component running in a QingTian Enclave instance collects specified service logs or resource usage of the QingTian Enclave instance, and sends the collected data to the qlog component of the parent instance. The qlog component of the parent instance stores the received data in a specified directory, for example, /var/log/qlog/service.log.
Figure 1 Seamless migration of a network service to QingTian Enclave
The following describes how to use qlog.
  1. You have obtained qlog by performing the following:
    Clone the QingTian Enclave code repository.
    git clone https://gitee.com/HuaweiCloudDeveloper/huawei-qingtian.git
  2. You have obtained the cargo tool chain by performing the following:
    1. Install rustup.
      curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
    2. After the installation is complete, load rustup.
      source $HOME/.cargo/env
    3. Check that rustc and cargo are installed.
      rustc -V
      cargo -V
  3. You have learned about the pre-dependency of qlog.
    Table 1 Pre-dependency
    Dependency Item
    Earliest Test Version
    glibc
    2.34
    cargo
    1.77.0
  4. You have prepared the QingTian Enclave environment by performing the following:
    1. Install the qt CLI tool and required RPM packages.
    2. Install Docker.
    3. Install Python 3 and required Python modules (docker and knack).
    For details, see Getting Started with QingTian Enclave and Installation of the qt CLI.
  1. Build qlog.
    Go to the qingtian-tools/qlog directory and run the following cargo command:
    cargo build --release
    The generated qlog binary file is compiled in qingtian-tools/qlog/target/release.
  2. Create a working directory.
    Create a working directory named workspace and copy the qlog binary file to the workspace. Store the files generated subsequently in the workspace.
  1. Configure config_qlog.toml.
    In the workspace directory, create the config_qlog.toml file with the following content:
    port: 6000
    workspace: /var/log/qlog
    server_logfile: server.log
    client_logfile: client.log
    server_threads: 4
    client_threads: 1
    log_level: info
    rotate_size: 65536
    rotate_num: 10
    monitor_items:
      - name: service  #Service name
        monitor_type: file
        monitor_path: /var/log/service.log  #QingTian Enclave service log path
        outputfile: service.log  #Name of the log file synchronized to the parent instance
      - name: resource
        monitor_type: resource
        monitor_internel: 15
        outputfile: resource.log
  2. Create a QingTian Enclave image that contains qlog.
    1. In the workspace directory, create the start.sh script.
      #/bin/bash
      /root/qlog monitor /root/config_qlog.toml &
      LOG_FILE="/var/log/service.log"
      LOG_MESSAGE="Hello, service."
      while true; do
          TIMESTAMP=$(date '+%Y-%m-%d %H:%M:%S')
          echo "$TIMESTAMP - $LOG_MESSAGE" >> "$LOG_FILE"
          sleep 3
      done
    1. Run the following command in the workspace to grant start.sh execute permissions:
      chmod +x start.sh
    2. In the workspace directory, create the Dockerfile file with the following content:
      FROM ubuntu:latest
      COPY ./qlog /root/qlog
      COPY ./config_qlog.toml /root/config_qlog.toml
      COPY ./start.sh /root/start.sh
      CMD /root/start.sh
    3. Run the following command in the workspace to grant start.sh execute permissions:
      chmod +x start.sh
    4. Run the following command in the workspace to create a Docker image:
      docker build -f Dockerfile -t test_qlog_enclave .
    5. Run the following command in the workspace to create a QingTian Enclave image:
      qt enclave make-img --docker-uri test_qlog_enclave --eif test_qlog_enclave.eif
  3. Start qlog.
    1. Run the following command in the workspace to start a QingTian Enclave instance:
      qt enclave start --cpus 2 --mem 1024 --cid 4 --eif test_qlog_enclave.eif
    2. Run the following command in the workspace to start qlog in the parent instance:
      ./qlog receive-file 4 ./config_qlog.toml &
    3. Run the following command on the parent instance to view the service log:
      tail -F /var/log/qlog/service.log
      A line of "Hello, service." is printed every 3 seconds.
    4. Run the following command on the parent instance to check the resource usage of the QingTian Enclave instance:
      tail -F /var/log/qlog/resource.log
      The CPU usage and memory usage are printed every 15 seconds.
qlog Help Information
qlog help
$ qlog --help
A tool to monitor logs and resource usage over a Vsock connection
Usage: qlog <COMMAND>
Commands:
  monitor       Monitor resource usage
  receive-file  Receive data from qlog monitor
  help          Print this message or the help of the given subcommand(s)
Options:
  -h, --help  Print help
qlog monitor help
$ qlog help monitor
Monitor logs and/or resource usage
Usage: qlog monitor [OPTIONS] <CONFIG>
Arguments:
  <CONFIG>  A configuration file in yaml format, which defines items to be monitored
Options:
  -c, --cid <CID>  CID to listen on (defaults to VMADDR_CID_ANY) [default: 4294967295]
qlog receive-file help
$ qlog help receive-file
Usage: qlog receive-file [OPTIONS] <CID> <CONFIG>
Arguments:
  <CID>     Enclave VM's CID
Options:
  -w, --workspace <WORKSPACE>  Set to workspace if specified, prior to configuration file
Configuration Information
Table 2 Configuration parameters
Variable
Type
port
u32
Vsock port
workspace
String
Workspace for writing process logs and monitoring data
server_logfile
String
Writing process logs of the server (qlog monitor) to <workspace>/<server_logfile>
client_logfile
String
Writing process logs of the client (qlog receive-file) to <workspace>/<client_logfile>
server_threads
u32
Number of threads on the server (qlog monitor)
client_threads
u32
Number of threads on the client (qlog receive-file)
log_level
String
Log levels (TRACE, DEBUG, INFO, WARN, ERROR, and OFF)
rotate_size
u32
(Optional) Log file dump size. The default value is 2 MB.
rotate_num
u32
(Optional) Number of old log files to be retained during log file dump. The default value is 10.
monitor_items
Vector
Monitored item list
Table 3 Monitoring item parameters
Variable
Type
name
String
Name of the monitoring item.
monitor_type
String
Monitoring type. The value file indicates log files, and the value resource indicates resource usage.
monitor_path
String
(Optional) Path of the log file to be monitored in the QingTian Enclave instance. This parameter can be specified only when monitor_type is file.
monitor_internel
u32
(Optional) Resource monitoring interval, in seconds. The default value is 15. This parameter can be specified only when monitor_type is resource.
outputfile
String
Name of a monitoring data file. The path for writing monitoring data is <workspace>/<outputfile>.
Configuration File Reference
port: 6000
server_threads: 4
client_threads: 1
log_level: info
rotate_size: 65536
rotate_num: 10
monitor_items:
  - name: item1
    monitor_type: file
    monitor_path: /var/log/item1.log
    outputfile: output1.log
  - name: item2
    monitor_type: file
    monitor_path: /var/log/item2.log
    outputfile: output2.log
  - name: item3
    monitor_type: file
    monitor_path: /var/log/item3.log
    outputfile: output3.log
  - name: item4
    monitor_type: file
    monitor_path: /var/log/item4.log
    outputfile: output4.log
  - name: item5
    outputfile: output5.log
