What Is QingTian Enclave?
Introduction
- QingTian Enclave instances are secure and isolated virtual machines (VMs) using the QingTian architecture. The instance that has the ownership of QingTian Enclave instances is called the parent instance. QingTian Enclave instances are completely independent VMs and have no persistent storage, interactive access, or external networking. They communicate with the parent instance through a secure local channel, which is called vsock. Even the root user of the parent instance cannot access or SSH into QingTian Enclave instances.
- The QingTian Hypervisor isolates the vCPUs and memory of QingTian Enclave instances from the parent instance to provide an isolated environment and greatly reduce the attack surface area. QingTian Enclave helps you protect sensitive core data and applications and enhance the security of your services running in QingTian Enclave instances.
- QingTian Enclave also supports attestation that allows you to verify the trusted measurements of QingTian Enclave instances. Huawei Cloud Key Management Service (KMS) provides built-in support for attestation to only allow applications in specific QingTian Enclave instances to be able to call KMS APIs for sensitive data processing.
QingTian Enclave instances have the following constraints.
| Name | Constraints |
| Parent instance (primary VM) |
| QingTian Enclave instances (secondary VMs) |
The relationship between QingTian Enclave instances and their parent instance are as follows:
- A maximum of two QingTian Enclave instances can be created from a parent instance.
- QingTian Enclave instances cannot share the same physical core with their parent instance.
- QingTian Enclave instances are running only when the parent instance is running. If the parent instance is stopped or terminated, QingTian Enclave instances are also stopped or terminated.
- Resources (vCPUs and memory) of QingTian Enclave instances come from the parent instance. The memory range must be a continuous physical range aligned by 2 MiB/1 GiB.
You also need to note the following:
- If your services running in the QingTian Enclave instances are terminated unexpectedly, you need to manually run the services again.
- By default, 1 GiB hugepages are configured for QingTian Enclave instances, with 1 GiB of memory and 2 vCPUs.
- A QingTian Enclave parent instance must have at least 8 vCPUs and 16 GiB of memory.
Related Services
QingTian Enclave integrates with the following Huawei Cloud services:
- KMS
KMS is a core service in Huawei Cloud Data Encryption Workshop (DEW). KMS is a highly available cloud service that helps users create, store, manage, and audit keys. KMS uses Hardware Security Modules (HSMs) to protect keys and can be integrated with multiple Huawei Cloud data storage services. Additionally, you can develop customized encryption applications using KMS.
- IAM
Identity and Access Management (IAM) provides permissions management to securely manage access to your Huawei Cloud services and resources.
