Creating Alarm Rules
You can set alarm rules and notifications for ECSs. This helps you learn about ECS statuses and receive alarm notifications in a timely manner.
This section describes how to set ECS alarm rules.
- Click
in the upper left corner and select a region and project. - Under Management & Governance, click Cloud Eye.
- In the navigation pane on the left, choose Alarm Management > Alarm Rules.
- On the displayed Alarm Rules page, click Create Alarm Rule.
You can also select an existing alarm rule and modify it as needed.
- Configure basic information of the alarm rule. Figure 1 Alarm rule information
Table 1 Basic parameters for alarm rules Parameter
Example Value
Name
Name of the alarm rule. The system generates a random name, and you can change it as needed.
alarm-cprn
Description of the alarm rule. This parameter is optional.
- Select an object to be monitored and configure alarm parameters.
- If you select Metric for Alarm Type, you can create an alarm rule for ECS metrics. Figure 2 Metric alarm configuration
Key parameters are described below. For details, see Creating an Alarm Rule and Notifications.
- Alarm Type: The type of the alarm that the alarm rule applies to. You can select Metric or Event.
- Cloud Product: The cloud product you want to monitor. This parameter is only available if you select Metric for Alarm Type. Example: Elastic Cloud Server - ECSs
- Resource Level: Select the resource level of the monitored object. You are advised to select Specific dimension and then select different dimensions such as disk, mount point, and process from the drop-down list based on service requirements.
To create an alarm rule for a GPU-accelerated ECS, select ECSs - GPU for Specific dimension.
- Monitoring Scope: The scope that the alarm rule applies to. You can select All resources, Resource groups, or Specific resources.
- Method: Select Associate template or Configure manually.
After an associated template is modified, the policies contained in this alarm rule to be created will be modified accordingly.
- Alarm Policy: The policy for triggering an alarm.
- If you select Event for Alarm Type, you can create an alarm rule for ECS events. Figure 3 Event alarm configuration
- Event Type: You can select System event or Custom event.
- Event Source: Select the name of the cloud service from which events are reported.
- Set alarm notification parameters.
To send alarm notifications by email, SMS, HTTP, or HTTPS, enable Alarm Notifications.
For details about related parameters, see Creating an Alarm Rule and Notifications.
- Click Create.
