Help Center/ Elastic Cloud Server/ User Guide/ Cloud Eye Monitoring/ OS Monitoring Metrics Supported by ECSs with the Agent Installed
Updated on 2026-04-24 GMT+08:00
OS monitoring provides system-level, proactive, and fine-grained monitoring. It requires the Agent to be installed on the ECSs to be monitored. This section describes OS monitoring metrics reported to Cloud Eye. Monitoring data is collected every one minute.
OS monitoring supports metrics about the CPU, CPU load, memory, disk, disk I/O, file system, GPU, network interface, NTP, and TCP connections.
After the Agent is installed, you can view monitoring metrics of ECSs running different OSs.
Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). Level 3 is the deepest level. For example, if the monitored dimension of a metric is instance_id,mount_point, instance_id indicates level 0 and mount_point indicates level 1.
Namespace
AGT.ECS
OS Metric: CPU
Table 1 CPU metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
Monitoring Period (Raw Data)
cpu_usage
(Agent) CPU Usage
CPU usage of the monitored object
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command to check the %Cpu(s) value.
  • Windows: Obtain the metric value using the Windows API GetSystemTimes.
0-100
N/A
instance_id
1 minute
cpu_usage_idle
(Agent) Idle CPU Usage
Percentage of time that CPU is idle
0-100
N/A
instance_id
1 minute
cpu_usage_user
(Agent) User Space CPU Usage
Percentage of time that the CPU is used by user space
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command to check the %Cpu(s) us value.
0-100
N/A
instance_id
1 minute
cpu_usage_system
(Agent) Kernel Space CPU Usage
Percentage of time that the CPU is used by kernel space
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command to check the %Cpu(s) sy value.
0-100
N/A
instance_id
1 minute
cpu_usage_other
(Agent) Other Process CPU Usage
Percentage of time that the CPU is used by other processes
  • Linux: Other Process CPU Usage = 1 – Idle CPU UsageKernel Space CPU UsageUser Space CPU Usage
  • Windows: Other Process CPU Usage = 1 – Idle CPU UsageKernel Space CPU UsageUser Space CPU Usage
0-100
N/A
instance_id
1 minute
cpu_usage_nice
(Agent) Nice Process CPU Usage
Percentage of time that the CPU is used by the Nice process
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command to check the %Cpu(s) ni value.
  • Windows is not supported currently.
0-100
N/A
instance_id
1 minute
cpu_usage_iowait
(Agent) iowait Process CPU Usage
Percentage of time that the CPU is waiting for I/O operations to complete
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command to check the %Cpu(s) wa value.
0-100
N/A
instance_id
1 minute
cpu_usage_irq
(Agent) CPU Interrupt Time
Percentage of time that the CPU is servicing interrupts
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command to check the %Cpu(s) hi value.
0-100
N/A
instance_id
1 minute
cpu_usage_softirq
(Agent) CPU Software Interrupt Time
Percentage of time that the CPU is servicing software interrupts
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command to check the %Cpu(s) si value.
0-100
N/A
instance_id
1 minute
OS Metric: CPU Load
Table 2 CPU load metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
load_average1
(Agent) 1-Minute Single-Core Load Average
CPU load averaged from the last 1 minute
Linux: Obtain its value by using the load1 value in /proc/loadavg to divide the number of logical CPUs. You can run the top command to obtain the load1 value.
≥ 0
N/A
N/A
instance_id
1 minute
load_average5
(Agent) 5-Minute Single-Core Load Average
CPU load averaged from the last 5 minutes
Linux: Obtain its value by using the load5 value in /proc/loadavg to divide the number of logical CPUs. Run the top command to obtain the load5 value.
≥ 0
N/A
N/A
instance_id
1 minute
load_average15
(Agent) 15-Minute Single-Core Load Average
CPU load averaged from the last 15 minutes
Linux: Obtain its value by using the load15 value in /proc/loadavg to divide the number of logical CPUs. Run the top command to obtain the load15 value.
≥ 0
N/A
N/A
instance_id
1 minute
The Windows OS does not support the CPU load metrics.
OS Metric: Memory
Table 3 Memory metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
mem_available
(Agent) Available Memory
Available memory size of the monitored object
  • Linux: Obtain the metric value from /proc/meminfo.
    • If MemAvailable is displayed in /proc/meminfo, obtain the value.
    • If MemAvailable is not displayed in /proc/meminfo, MemAvailable = MemFree + Buffers + Cached
  • Collection method (Windows): formula (Total memory – Used memory). The value is obtained by calling the Windows API GlobalMemoryStatusEx.
≥ 0
GB
N/A
instance_id
1 minute
mem_usedPercent
(Agent) Memory Usage
Memory usage of the monitored object
  • Linux: Obtain the metric value from the /proc/meminfo file: (MemTotal - MemAvailable)/MemTotal
    • If MemAvailable is displayed in /proc/meminfo, MemUsedPercent = (MemTotal-MemAvailable)/MemTotal
    • If MemAvailable is not displayed in /proc/meminfo, MemUsedPercent = (MemTotalMemFreeBuffersCached)/MemTotal
  • Windows: The calculation formula is as follows: Used memory size/Total memory size*100%.
0-100
N/A
instance_id
1 minute
mem_free
(Agent) Idle Memory
Amount of memory that is not being used
≥ 0
GB
N/A
instance_id
1 minute
mem_buffers
(Agent) Buffer
Amount of memory that is being used for buffers
  • Linux: Obtain the metric value from /proc/meminfo. Run the top command to check the KiB Mem:buffers value.
≥ 0
GB
N/A
instance_id
1 minute
mem_cached
(Agent) Cache
Amount of memory that is being used for caches
  • Linux: Obtain the metric value from /proc/meminfo. Run the top command to check the KiB Swap:cached Mem value.
≥ 0
GB
N/A
instance_id
1 minute
total_open_files
(Agent) Total File Handles
Total handles used by all processes
  • Linux: Use the /proc/{pid}/fd file to summarize the handles used by all processes.
≥ 0
Count
N/A
instance_id
1 minute
OS Metric: Disk
  • Currently, only physical disks are monitored. The NFS-attached disks cannot be monitored.
  • By default, Docker-related mount points are shielded. The prefixes of mount points are as follows:
    /var/lib/docker;/mnt/paas/kubernetes;/var/lib/mesos
Table 4 Disk metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
disk_free
(Agent) Available Disk Space
Free space on the disks
  • Linux: Run the df -h command to check the value in the Avail column. The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
  • Windows: Use the WMI interface to call GetDiskFreeSpaceExW API to obtain disk space data. The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
≥ 0
GB
N/A
1 minute
disk_total
(Agent) Disk Storage Capacity
Total space on the disks, including used and free
  • Linux: Run the df -h command to check the value in the Size column.
≥ 0
GB
N/A
1 minute
disk_used
(Agent) Used Disk Space
Used space on the disks
  • Linux: Run the df -h command to check the value in the Used column. The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
≥ 0
GB
N/A
1 minute
disk_usedPercent
(Agent) Disk Usage
Percentage of total disk space that is used, which is calculated as follows: Disk Usage = Used Disk Space/Disk Storage Capacity
  • Linux: It is calculated as follows: Used/Size. The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
0-100
N/A
1 minute
OS Metric: Disk I/O
Table 5 Disk I/O metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
disk_agt_read_bytes_rate
(Agent) Disks Read Rate
Number of bytes read from the monitored disk per second
  • Linux:
    The disk read rate is calculated based on the data changes in the sixth column of the corresponding device in file /proc/diskstats in a collection period.
  • Windows:
    • The disk I/O data is obtained through the Win32_PerfFormattedData_PerfDisk_LogicalDisk object in WMI. The object is obtained once in each collection period. The instantaneous value returned by the object indicates the metric value in a collection period.
    • The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
    • When the CPU usage is high, monitoring data obtaining timeout may occur and result in the failure of obtaining monitoring data.
≥ 0
byte/s
1024(IEC)
  • instance_id,disk
  • instance_id,mount_point
1 minute
disk_agt_read_requests_rate
(Agent) Disks Read Requests
Number of read requests sent to the monitored disk per second
  • Linux:
    The disk read requests are calculated based on the data changes in the fourth column of the corresponding device in file /proc/diskstats in a collection period.
  • Windows:
≥ 0
Request/s
N/A
  • instance_id,disk
1 minute
disk_agt_write_bytes_rate
(Agent) Disks Write Rate
Number of bytes written to the monitored disk per second
  • Linux:
    The disk write rate is calculated based on the data changes in the tenth column of the corresponding device in file /proc/diskstats in a collection period.
  • Windows:
≥ 0
byte/s
1024(IEC)
  • instance_id,disk
1 minute
disk_agt_write_requests_rate
(Agent) Disks Write Requests
Number of write requests sent to the monitored disk per second
  • Linux:
    The disk write requests are calculated based on the data changes in the eighth column of the corresponding device in file /proc/diskstats in a collection period.
  • Windows:
≥ 0
Request/s
N/A
  • instance_id,disk
1 minute
disk_readTime
(Agent) Average Read Request Time
Average amount of time that read requests have waited on the disks
  • Linux:
    The average read request time is calculated based on the data changes in the seventh column of the corresponding device in file /proc/diskstats in a collection period.
≥ 0
ms/Count
N/A
  • instance_id,disk
1 minute
disk_writeTime
(Agent) Average Write Request Time
Average amount of time that write requests have waited on the disks
  • Linux:
    The average write request time is calculated based on the data changes in the eleventh column of the corresponding device in file /proc/diskstats in a collection period.
≥ 0
ms/Count
N/A
  • instance_id,disk
1 minute
disk_ioUtils
(Agent) Disk I/O Usage
Percentage of the time that the disk has had I/O requests queued to the total disk operation time
  • Linux:
    The disk I/O usage is calculated based on the data changes in the thirteenth column of the corresponding device in file /proc/diskstats in a collection period.
0-100
N/A
  • instance_id,disk
1 minute
disk_queue_length
(Agent) Disk Queue Length
A reflection of the disk usage in a specified period. It can be used to evaluate the disk I/O performance. A larger value indicates a busier disk and poorer I/O performance.
  • Linux:
    The metric value is calculated by dividing the data changes in the fourteenth column of the corresponding device in /proc/diskstats in a collection period by the metric collection period.
≥ 0
Count
N/A
  • instance_id,disk
1 minute
disk_write_bytes_per_operation
(Agent) Average Disk Write Size
Average number of bytes in an I/O write for the monitored disk in the monitoring period
  • Linux:
    The average disk write size is calculated based on the data changes in the tenth column of the corresponding device to divide that of the eighth column in file /proc/diskstats in a collection period.
≥ 0
Byte/op
N/A
  • instance_id,disk
1 minute
disk_read_bytes_per_operation
(Agent) Average Disk Read Size
Average number of bytes in an I/O read for the monitored disk in the monitoring period
  • Linux:
    The average disk read size is calculated based on the data changes in the sixth column of the corresponding device to divide that of the fourth column in file /proc/diskstats in a collection period.
≥ 0
Byte/op
N/A
  • instance_id,disk
1 minute
disk_io_svctm
(Agent) Disk I/O Service Time
Average time in an I/O read or write for the monitored disk in the monitoring period
  • Linux:
    The average disk I/O service time is calculated based on the data changes in the thirteenth column of the corresponding device to divide the sum of data changes in the fourth and eighth columns in file /proc/diskstats in a collection period.
≥ 0
ms/op
N/A
  • instance_id,disk
1 minute
disk_device_used_percent
Block Device Usage
Percentage of the used physical disk of the monitored object. Calculation formula: Used storage space of all mounted disk partitions/Total disk storage space
  • Collection method for Linux ECSs: Obtain the disk usage of each mount point, calculate the total disk storage space based on the disk sector size and the number of sectors, and then you can calculate the overall disk usage.
0-100
N/A
instance_id,disk
1 minute
OS Metric: File System
Table 6 File system metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
disk_fs_rwstate
(Agent) File System Read/Write Status
Read and write status of the mounted file system of the monitored object. Value: 0 (read and write) or 1 (read only)
Linux: Check file system information in the fourth column in file /proc/mounts.
  • 0: readable and writable
  • 1: read-only
N/A
N/A
1 minute
disk_inodesTotal
(Agent) Disk inode Total
Total number of index nodes on the disk
Linux: Run the df -i command to check the value in the Inodes column. The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
≥ 0
Count
N/A
1 minute
disk_inodesUsed
(Agent) Total inode Used
Number of used index nodes on the disk
Linux: Run the df -i command to check the value in the IUsed column. The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
≥ 0
Count
N/A
1 minute
disk_inodesUsedPercent
(Agent) Percentage of Total inode Used
Percentage of used index nodes on the disk
Linux: Run the df -i command to check the value in the IUse% column. The path of the mount point prefix cannot exceed 64 characters. It must start with a letter, and contain only digits, letters, hyphens (-), periods (.), and tildes (~).
0-100
N/A
1 minute
The Windows OS does not support the file system metrics.
OS Metric: NIC
Table 7 NIC metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
net_bitRecv
(Agent) Outbound Bandwidth
Number of bits sent by this NIC per second
  • Linux: Check metric value changes in file /proc/net/dev in a collection period.
  • Windows: Use the MibIfRow object in the WMI to obtain network metric data.
≥ 0
bit/s
1024(IEC)
instance_id
1 minute
net_bitSent
(Agent) Inbound Bandwidth
Number of bits received by this NIC per second
≥ 0
bit/s
1024(IEC)
instance_id
1 minute
net_packetRecv
(Agent) NIC Packet Receive Rate
Number of packets received by this NIC per second
≥ 0
Counts/s
N/A
instance_id
1 minute
net_packetSent
(Agent) NIC Packet Send Rate
Number of packets sent by this NIC per second
≥ 0
Counts/s
N/A
instance_id
1 minute
net_errin
(Agent) Receive Error Rate
Percentage of error packets detected by this NIC to the total number of packets received by the NIC per second
0-100
N/A
instance_id
1 minute
net_errout
(Agent) Transmit Error Rate
Percentage of error packets detected by this NIC to the total number of packets transmitted by the NIC per second
0-100
N/A
instance_id
1 minute
net_dropin
(Agent) Received Packet Drop Rate
Percentage of packets received by this NIC which were dropped per second
0-100
N/A
instance_id
1 minute
net_dropout
(Agent) Transmitted Packet Drop Rate
Percentage of packets transmitted by this NIC which were dropped per second
0-100
N/A
instance_id
1 minute
OS Metric: NTP
Table 8 NTP metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
ntp_offset
(Agent) NTP Offset
NTP offset of the monitored object
  • Collection method for Linux ECSs: Run chronyc sources -v to obtain the offset.
≥ 0
ms
N/A
instance_id
1 minute
OS Metric: TCP
Table 9 TCP metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
net_tcp_total
(Agent) Total TCP Connections
Total number of TCP connections in all states
  • Linux: Obtain TCP connections in all states from the /proc/net/tcp file, and then collect the number of connections in each state.
  • Windows: Obtain the metric value using WindowsAPI GetTcpTable2.
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_established
(Agent) TCP ESTABLISHED Connection
Number of TCP connections in ESTABLISHED state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_sys_sent
(Agent) TCP SYS_SENT Connections
Number of TCP connections that are being requested by the client
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_sys_recv
(Agent) TCP SYS_RECV Connections
Number of pending TCP connections received by the server
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_fin_wait1
(Agent) TCP FIN_WAIT1 Connections
Number of TCP connections waiting for ACK packets when the connections are being actively closed by the client
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_fin_wait2
(Agent) TCP FIN_WAIT2 Connections
Number of TCP connections in the FIN_WAIT2 state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_time_wait
(Agent) TCP TIME_WAIT Connections
Number of TCP connections in TIME_WAIT state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_close
(Agent) TCP CLOSE Connections
Number of closed TCP connections
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_close_wait
(Agent) TCP CLOSE_WAIT Connections
Number of TCP connections in CLOSE_WAIT TCP state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_last_ack
(Agent) TCP LAST_ACK Connections
Number of TCP connections waiting for ACK packets when the connections are being passively closed by the client
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_listen
(Agent) TCP LISTEN Connections
Number of TCP connections in the LISTEN state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_closing
(Agent) TCP CLOSING Connections
Number of TCP connections to be automatically closed by the server and the client at the same time
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_retrans
(Agent) TCP Retransmission Rate
Percentage of packets that are resent
  • Linux: Obtain the metric value from the /proc/net/snmp file. The value is the ratio of the number of retransmitted packets to the number of sent packets in a collection period.
  • Windows: Obtain the metric value using WindowsAPI GetTcpStatistics.
0-100
N/A
instance_id
1 minute
OS Metric: GPU
Table 10 GPU metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
gpu_status
(Agent) GPU Health Status
Overall measurement of the GPU health
  • Linux: Obtain the metric value from the libnvidia-ml.so.1 library file of the GPU.
  • Windows: Obtain the metric value from the nvml.dll library of the GPU.
  • 0: healthy
  • 1: subhealthy
  • 2: faulty
N/A
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_usage_encoder
(Agent) Encoding Usage
Encoding capability usage of the GPU
0-100
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_usage_decoder
(Agent) Decoding Usage
Decoding capability usage of the GPU
0-100
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_volatile_correctable
(Agent) Volatile Correctable ECC Errors
Number of correctable ECC errors since the GPU is reset. The value is reset to 0 each time the GPU is reset.
≥ 0
Count
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_volatile_uncorrectable
(Agent) Volatile Uncorrectable ECC Errors
Number of uncorrectable ECC errors since the GPU is reset. The value is reset to 0 each time the GPU is reset.
≥ 0
Count
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_aggregate_correctable
(Agent) Aggregate Correctable ECC Errors
Aggregate correctable ECC errors on the GPU
≥ 0
Count
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_aggregate_uncorrectable
(Agent) Aggregate Uncorrectable ECC Errors
Aggregate uncorrectable ECC Errors on the GPU
≥ 0
Count
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_retired_page_single_bit
(Agent) Retired Page Single Bit Errors
Number of retired page single bit errors, which indicates the number of single-bit pages blocked by the GPU
≥ 0
Count
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_retired_page_double_bit
(Agent) Retired Page Double Bit Errors
Number of retired page double bit errors, which indicates the number of double-bit pages blocked by the GPU
≥ 0
Count
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_performance_state
(Agent) Performance Status
GPU performance status
P0-P15, P32
  • P0: indicates the maximum performance status.
  • P15: indicates the minimum performance status.
  • P32: indicates the unknown performance status.
N/A
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_usage_mem
(Agent) GPU Memory Usage
GPU memory usage
0-100
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_usage_gpu
(Agent) GPU Usage
GPU compute usage
0-100
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_free_mem
(Agent) Remaining GPU Memory
Remaining GPU memory
≥ 0
MB
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_graphics_clocks
(Agent) GPU Graphics Clocks
GPU graphics (shader) clock frequency
≥ 0
MHz
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_mem_clocks
(Agent) GPU Memory Clocks
Clock frequency of the GPU memory
≥ 0
MHz
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_power_draw
(Agent) GPU Draw Power
Draw power on the GPU
NA
W
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_rx_throughput_pci
(Agent) GPU PCI Rx Throughput
PCI Rx throughput on the GPU
≥ 0
MB/s
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_sm_clocks
(Agent) GPU SM Clocks
SM clocks on the GPU
≥ 0
MHz
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_temperature
(Agent) GPU Temperature
Temperature of the GPU
≥ 0
°C
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_tx_throughput_pci
(Agent) GPU PCI Tx Throughput
PCI Tx throughput on the GPU
≥ 0
MB/s
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_used_mem
(Agent) GPU Used Memory
Memory used on the GPU
≥ 0
MB
N/A
  • instance_id
  • instance_id,gpu
1 minute
gpu_video_clocks
(Agent) GPU Video Clocks
Video clocks on the GPU
≥ 0
MHz
N/A
  • instance_id
  • instance_id,gpu
1 minute
OS Metric: NPU
Table 11 NPU metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
npu_device_health
(Agent) NPU Device Health
Overall measurement of the NPU health
Linux: Obtain the metric value from the libdcmi.so library file of the NPU card.
  • 0: healthy
  • 1: minor alarms
  • 2: major alarms
  • 3:critical alarms
N/A
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_util_rate_mem
(Agent) NPU Memory Usage
Memory usage of the NPU
0-100
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_util_rate_ai_core
(Agent) NPU AI Core Usage
AI core usage of the NPU
0-100
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_util_rate_ai_cpu
(Agent) NPU AI CPU Usage
AI CPU usage of the NPU
0-100
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_util_rate_ctrl_cpu
(Agent) NPU Control CPU Usage
CPU control usage of the NPU
0-100
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_util_rate_mem_bandwidth
(Agent) NPU Memory Bandwidth Usage
Memory bandwidth usage of the NPU
0-100
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_freq_mem
(Agent) NPU Memory Frequency
Clock frequency of the NPU memory
≥ 0
MHz
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_freq_ai_core
(Agent) NPU AI Core Frequency
Clock frequency of the NPU's AI core
≥ 0
MHz
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_usage_mem
(Agent) Used NPU Memory
Used size of the NPU memory
≥ 0
MB
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_sbe
(Agent) NPU Single-Bit Errors
Numbers of single-bit errors of the NPU
≥ 0
Count
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_dbe
(Agent) NPU Double-Bit Errors
Numbers of double-bit errors of the NPU
≥ 0
Count
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_power
(Agent) NPU Power
The power of the NPU (Rated power displayed for 310 only, actual power displayed for other cards)
≥ 0
W
N/A
  • instance_id
  • instance_id,npu
1 minute
npu_temperature
(Agent) NPU Temperature
Current temperature of the NPU
≥ 0
°C
N/A
  • instance_id
  • instance_id,npu
1 minute
The Windows OS does not support NPU metrics.
OS Metric: DAVP
Table 12 DAVP metrics
Metric
Value Range
Unit
Conversion Rule
Dimension
davp_device_health
(Agent) DAVP Device Health
An overall measurement of the DAVP health
Linux: Obtain the metric value from the libvaml.so library file in the VAtools tool of the DAVP card.
  • 0: healthy
  • 1: abnormal
N/A
N/A
  • instance_id
  • instance_id,davp
1 minute
davp_util_rate_mem
(Agent) DAVP Memory Usage
The memory usage of the DAVP
0-100
N/A
  • instance_id
  • instance_id,davp
1 minute
davp_usage_mem
(Agent) Used DAVP Memory
The used size of the DAVP memory
≥ 0
MB
N/A
  • instance_id
  • instance_id,davp
1 minute
davp_util_rate_ai_core
(Agent) DAVP AI Core Usage
The AI core usage of the DAVP
0-100
N/A
  • instance_id
  • instance_id,davp
1 minute
davp_util_rate_vdsp_core
(Agent) DAVP VDSP Core Usage
The VDSP core usage of the DAVP
0-100
N/A
  • instance_id
  • instance_id,davp
1 minute
davp_util_rate_enc_core
(Agent) DAVP Encoding Core Usage
The encoding core usage of the DAVP
0-100
N/A
  • instance_id
  • instance_id,davp
1 minute
davp_util_rate_dec_core
(Agent) DAVP Decoding Core Usage
The decoding core usage of the DAVP
0-100
N/A
  • instance_id
  • instance_id,davp
1 minute
davp_sysc_temperature
(Agent) DAVP System Module Temperature
The temperature of DAVP system module
≥ 0
­°C
N/A
  • instance_id
  • instance_id,davp
1 minute
The Windows OS does not support DAVP metrics.
Dimension
Dimension
Key
Value
ECS
instance_id
Specifies the ECS ID.
You can obtain the value by referring to Querying the Original Dimension Values in Server Monitoring.
ECS - Disk
disk
Specifies the disks attached to an ECS.
ECS - Mount point
mount_point
Specifies the mount point of a disk.
ECS - GPU
gpu
Specifies the GPU of an ECS.
ECS - NPU
npu
Specifies the NPU of an NPU-based ECS.
ECS - DAVP
davp
Specifies the DaoCloud DAVP1 video acceleration card of a DAVP-based ECS.
Example of Querying Multi-Level Dimension Metrics Using APIs
If an object has multiple dimension levels, you need to specify the monitored dimension levels when you use an API to query the metrics of this object.
For example, if you want to query the remaining storage capacity (disk_free) of a disk mount point for an ECS, the dimension of the metric is instance_id,mount_point, where instance_id indicates level 0 and mount_point indicates level 1.
  • To query a single metric by calling an API, the mount_point dimension is used as follows:
    dim.0=instance_id,3d65c1ac-9a9f-4c5f-a054-35184a087bb2&dim.1=mount_point,6666cd76f96956469e7be39d750cc7d9
    3d65c1ac-9a9f-4c5f-a054-35184a087bb2 and 6666cd76f96956469e7be39d750cc7d9 are the values of instance_id and mount_point, respectively. For details about how to obtain the values, see the obtaining guide in the Dimension table.
  • To query multiple metrics by calling an API, the mount_point dimension is used as follows:
    "dimensions": [
                        "name": "instance_id",
                        "value": "3d65c1ac-9a9f-4c5f-a054-35184a087bb2"
                        "name": "mount_point",
                        "value": "6666cd76f96956469e7be39d750cc7d9"
