Searching for ECSs
After purchasing an ECS, you can use the search function on the management console to search for ECSs in the current region. You can search for ECSs by name, ID, AZ, status, flavor name, image ID, EIP, private IP address, creation time, billing mode, VPC ID, enterprise project, or resource tag.
Search Syntax
A variety of ECS search types are available. For details, see Table 1.
    - For certain properties, if you enter complete values, the system can automatically identity the property type and search for them.
 - The following properties only support exact search and you need to enter complete values: ID, image ID, EIP, VPC ID, and enterprise project.
 - When you use multiple properties including the private IP address for search, you need to enter complete values of the IP address.
 - The private IP address must be in the following CIDR blocks: 10.0.0.0/8-24, 172.16.0.0/12-24, and 192.168.0.0/16-24.
 - You can search by tag key or key-value pair. You can add one or more tags. If keys are different, the tags are automatically joined with AND. If the keys are the same but the values are different, the tags are also automatically joined with AND.
 - Tags do not support multi-value search if no property is selected.
 - You cannot use both the private IP address and EIP for a combination of search.
         Search Type  |
         Supported Property  |
         Format  |
         Example  |
         Description  |
         Property value Automatic property matching  |
         ID Flavor name EIP Private IP address  |
         Complete property value  |
         ID: 4a79dfec-f0d8-4181-9bef-495b8b7220e1 Flavor Name: s2.xlarge.4 Private IP Address: 192.168.99.231  |
         When you search by keyword, enter a complete property value instead of selecting a property. The system can automatically match the property type for search. Separate every two values with a comma (,). Otherwise, only the last value will be used for the search. Multiple property values are in OR relationship.  |
         Property value Fuzzy search  |
         Name Private IP address Flavor name  |
         Incomplete property value  |
         Name: ecs-c Flavor name: s7n Private IP address: 192.168.0  |
         Select a property, and enter or choose the corresponding property value.  |
         Single property  |
         All properties on the console  |
         Property: Value  |
         Select a property, and enter or choose the corresponding property value. The following properties only support exact search and you need to enter complete values for them: ID, EIP, image ID, and VPC ID.  |
         Multiple properties  |
         Property 1: Value Property 2: Value  |
         Private IP Address: 192.168.99.231 Name: ecs-c  |
         You can search by multiple properties and the properties are in AND relationship. The following properties only support exact search and you need to enter complete values for them: ID, EIP, image ID, and VPC ID.  |
         Single property with multiple values  |
         ID Flavor name EIP  |
         Property: Value 1,Value 2  |
         ID: 624eda28-6bd9-402a-934b-26c8969f7169,bf6c0281-f749-42d7-b732-23ac69d80ebe Flavor Name: s2,s3  |
         Select a property and enter or choose multiple values. The values are in OR relationship. The ID only supports exact search. You need to enter a complete ECS ID for search.  |
         Status Billing mode  |
         Property: Value 1 Property: Value 2  |
         Status: Running Status: Stopped  |
         Select a property and choose multiple values. The values are in OR relationship.  |
         Multiple properties with multiple values  |
         ID, flavor name, status, EIP, billing mode, and private IP address  |
         Property 1: Value 1,Value 2 Property 2: Value 1,Value 2  |
         Multi-property and multi-value search
 The ID only supports exact search. You need to enter a complete ECS ID for search. You can use vertical bars (|) to separate values of the following properties: status and billing mode. Alternatively, you can directly select the properties and corresponding values.  |
 - Click
. Under Compute, click Elastic Cloud Server.
     The ECS console is displayed.
 - In the search box, specify search criteria.
You can use either of the following methods:
- Directly enter a property value for search.
 - Select a property first and specify the property value for search.
- Click the search box and select a property.
         Figure 1 Selecting a property
          - In the search box, enter or select properties as prompted, such as ID, status, and flavor name, and press Enter.
Example 1: Searching by Property Value
After you enter a complete property value, the system automatically identifies the property type and search for it. Separate every two values with a comma (,). Otherwise, only the last value is used for the search. Multiple property values are in OR relationship.
- Searching by a single value
Enter a complete ECS ID and press Enter to search.
Figure 2 Entering a complete ECS ID
     Figure 3 Automatic property matching
       - Searching by multiple values
     Enter multiple complete flavor names and press Enter to search.Figure 4 Entering multiple complete flavor names
      Figure 5 Automatic property matching for search
Example 2: Searching by a Single Property
- Fuzzy search by private IP address
- Select Private IP Address in the search box.
 - Enter a private IP address and press Enter to search. Private IP addresses can be used for fuzzy search. For example, you can enter 192.168.0 to search for all ECSs that use the 192.168.0 IP address.
       Figure 6 Searching by private IP address
 - Exact search by ID
- Select ID in the search box.
 - Enter a complete ECS ID and press Enter to search.
       Figure 7 Searching for an ECS by ID
Example 3: Searching by Multiple Properties
In this example, use Name and Private IP Address for a combination of search.
- Select Name and enter an ECS name in the search box for fuzzy search.
 - Select Private IP Address and enter a private IP address for fuzzy search.
     Figure 8 Searching by name and private IP address
Example 4: Searching by a Single Property with Multiple Values
You can choose from the following properties: status, ID, flavor name, private IP address, EIP, billing mode, and tag.
The following properties only support exact search and you need to enter complete values for them: ID, private IP address, and EIP.
Select a property and enter multiple values. The values are in OR relationship.
- Fuzzy search
- Select Flavor Name in the search box.
 - Enter multiple flavor names and separate them with commas (,).
       Figure 9 Searching by flavor name
 - Exact search
 - Enter multiple complete private IP addresses and separate them with commas (,).
       Figure 10 Searching by private IP address
Example 5: Searching by Multiple Properties with Multiple Values
You can choose from the following properties to search by properties with multiple values: ID, flavor name, status, billing mode, and EIP.
Multi-property, multi-value search
- Multiple properties are in AND relationship.
 - Multiple values of the same property are in OR relationship.
- Fuzzy search
- Select Status in the search box and choose Running and Stopped.
 - Add Flavor Name, enter multiple flavors, and separate them with commas (,).
       Figure 11 Searching by status and flavor name
 - Exact search
 - Add ID, enter multiple IDs, and separate them with commas (,).
       Figure 12 Searching by status and ID
Example 6: Searching by Tags
- Searching by a single tag
In the search box, select a tag key under Resource Tag and then select a tag value for auto search.
Figure 13 Searching by tag
      - Searching by multiple tags
In the search box, select multiple tag key-value pairs for auto search.
If you search by multiple tags, the tags are in the AND relationship.
Figure 14 Searching by tag
