Deleting Tags
If you no longer need a tag, delete it in any of the following ways:
- Deleting a Tag on the ECS Details Page
- Deleting a Tag on the TMS Console
- Batch Deleting Tags on the TMS Console
- Click
in the upper left corner and select a region and project. - Click
. Under Compute, click Elastic Cloud Server. The Elastic Cloud Server page is displayed. - In the ECS list, click the name of the target ECS.
- Click the Tags tab, locate the tag to be deleted, and click Delete in the Operation column.
- Click OK.
- In the upper right corner of the page, hover over the username and click Tag Management. Figure 1 Tag Management
- On the Resource Tags page, set the search criteria for ECSs and click Search.
- In the Search Results area, click Edit to make the resource tag list editable.
If the key of a tag you want to delete is not contained in the list, click
and select the target tag keys. It is a good practice to select at most 10 keys to display. - Locate the row containing the target ECS and click
. - (Optional) Click
in the upper right of the Search Results area. The resource list is refreshed and the refresh time is updated.
Exercise caution when deleting tags in a batch. After you delete the tags, they will be removed from all the associated ECSs and cannot be recovered.
- Select the target ECSs.
- Click Manage Tag in the upper left corner of the list.
- In the displayed Manage Tag dialog box, click Delete in the Operation column. Click OK.
- (Optional) Click
in the upper right of the Search Results area. The resource tag list is refreshed.
