Help Center/ Elastic Cloud Server/ User Guide/ Security/ Project and Enterprise Project
Updated on 2025-04-30 GMT+08:00
Creating a Project and Assigning Permissions
  • Creating a project
    Log in to the management console, click the username in the upper right corner, and select Identity and Access Management from the drop-down list box. In the navigation pane on the left, choose Projects. In the right pane, click Create Project. On the displayed Create Project page, select a region and enter a project name.
  • Assigning permissions
    You can assign permissions (of resources and operations) to user groups to associate projects with user groups. You can add users to a user group to control projects that users can access and the resources on which users can perform operations. To do so, perform the following operations:
    1. On the User Groups page of the IAM console, locate the target user group and click Authorize in the Operation column.
    2. Select policies or roles from the list.
    3. Click Next and select Region-specific projects.
    4. In the displayed regional project list, select one or more projects and click OK.
    5. On the Users page, locate the target user and click Authorize in the Operation column.
    6. Select Inherit permissions from user groups and select the user group authorized in step 1.
    7. Click OK.
Creating an Enterprise Project and Assigning Permissions
  • Creating an enterprise project
    On the management console, choose Enterprise > Project Management in the upper right corner. On the Enterprise Project Management console, click Create Enterprise Project.
    Enterprise is available on the management console only if you have enabled the enterprise project, or your account is the primary account. To enable this function, contact customer service.
    You can add a user group to an enterprise project and configure a policy to associate the enterprise project with the user group. You can add users to a user group to control projects users can access and the resources on which users can perform operations. To do so, perform the following operations:
    1. On the Enterprise Management console, click the name of an enterprise project to go to the enterprise project details page.
    2. On the Permissions tab, click Authorize User Group to go to the User Groups page on the IAM console. Associate the enterprise project with a user group and assign permissions to the group.
      For details, see Creating a User Group and Assigning Permissions.
  • Associating ECSs with enterprise projects
    You can use enterprise projects to manage cloud resources.
    • Select enterprise projects when purchasing ECSs.
      On the page for buying an ECS, select an enterprise project from the Enterprise Project drop-down list.
    • Add ECSs to an enterprise project.
      On the Enterprise Project Management page, you can add existing ECSs to an enterprise project.
      Value default indicates the default enterprise project. Resources that are not allocated to any enterprise projects under your account are displayed in the default enterprise project.
For more details, see Enterprise Management User Guide.
