Overview of Password Reset
What Is a Password?
Passwords are used to log in to ECSs. If you select the password login mode when purchasing an ECS, you can use the username and password to log in to the ECS. The password is very important. Keep it secure.
You can set a password when purchasing an ECS.
- The password is lost.
- The password has expired.
- You intend to change the initial password at the first login.
- You selected Set password later or Key pair for Login Mode in ECS custom config.
- You purchased an ECS in quick config mode (the Login Mode is Set password later by default).
Password Reset Scenarios
Table 1 describes the methods of resetting passwords for ECSs. You can select a proper method based on service requirements.
| Method | Applicable OS | Characteristics | Constraints |
| Windows/Linux |
| Windows/Linux |
| Windows/Linux |
| Windows |
| This method is only available for Windows ECSs authenticated using key pairs and the corresponding private key file has been obtained. |
Scenarios of the One-Click Password Reset Plug-in
The offline password reset depends on the one-click password reset plug-in (CloudResetPwdAgent). With the one-click password reset plug-in, you can reset the password of an ECS that is in Running or Stopped state. This operation does not depend on other services, and you do not need to enter the old password or log in to the ECS.
The new password takes effect after the ECS is restarted or started.
The one-click password reset plug-in is installed by default for ECSs created using public images. You can directly reset the password offline for such ECSs.
If the password of an ECS fails to be reset offline, the one-click password reset plug-in may not be installed or may have expired. You can install or update the plug-in as needed.
| Scenario | Reference | Applicable OS | Description |
| Obtaining the plug-in | Windows/Linux | Download the plug-in and verify its integrity before installing or updating the plug-in. | |
| Installing the plug-in | Installing the One-Click Password Reset Plug-in on an Individual ECS | Windows/Linux | If the one-click password reset plug-in is not installed or has been deleted from an ECS, install the plug-in for the ECS. By default, the one-click password reset plug-in has been installed on ECSs created using public images. This operation is commonly used for ECSs created using private images. |
| Updating the plug-in | Updating the One-Click Password Reset Plug-in for an Individual ECS | Windows/Linux | Update the plug-in for an individual ECS for security purposes. |
| Using Scripts to Batch Update the One-Click Password Reset Plug-ins for Linux ECSs | Linux | Batch update one-click password reset plug-ins for multiple Linux ECSs.
| Using Scripts to Batch Update the One-Click Password Reset Plug-ins for Windows ECSs | Windows | Batch update one-click password reset plug-ins for multiple Windows ECSs.
Password Complexity Requirements
Table 3 shows the password complexity requirements in two scenarios: ECS creation and password reset.
| Password Complexity Requirements | ECS Creation | Password Reset |
| Length | Must contain 8 to 26 characters. | Must contain 8 to 26 characters. |
| Characters | Must contain at least three of the supported four character types. | Must contain at least three of the supported four character types. |
| Security |
| Other | None | Cannot start with a slash (/) for Windows ECSs. |
| Supported characters | Uppercase letters | Uppercase letters |
| Lowercase letters | Lowercase letters | |
| Digits | Digits | |
