Help Center/ Elastic Cloud Server/ User Guide/ Disks/ Enabling Advanced Disk
Updated on 2025-11-25 GMT+08:00
  • Disk functions have been upgraded on the platform. Newly created ECSs can have up to 60 attached disks. However, an existing ECS can still have a maximum of 24 attached disks (40 for certain ECSs). To allow such ECSs to have up to 60 attached disks, enable Advanced Disk.
  • After Advanced Disk is enabled, you can view the mapping between device names and disks. For details, see "What Is the Mapping Between Device Names and Disks?"
This section describes how to enable Advanced Disk on an ECS.
  2. Click in the upper left corner and select a region and project.
  3. Click . Under Compute, click Elastic Cloud Server.
  4. Click the name of the target ECS. The ECS details page is displayed.
  5. Click the Disks tab.
  6. View the current number of disks that can be attached to the ECS and enable Advanced Disk as instructed.
    The Enable Advanced Disk dialog box is displayed.
  7. Click OK.
  8. Stop and then start the target ECS.
    This operation allows Advanced Disk to take effect.
  9. Switch to the ECS details page again, click the Disks tab, and check whether the number of disks that can be attached to the ECS has been changed.
    • If yes, Advanced Disk has been enabled.
    • If no, enabling Advanced Disk failed. In such a case, try again later or contact customer service.
