On this page
Creating an Image
Updated on 2024-10-18 GMT+08:00
You can use an existing ECS to create a system disk image, data disk image, and full-ECS image.
  • System disk image: contains an OS and application software for running services. You can use a system disk image to create ECSs and migrate your services to the cloud.
  • Data disk image: contains only service data. You can create a data disk image from an ECS data disk. You can also use a data disk image to create EVS disks and migrate your service data to the cloud.
  • Full-ECS image: contains all the data of an ECS, including the data on the data disks attached to the ECS. A full-ECS image can be used to rapidly create ECSs with service data.
  • ISO image: is created from an external ISO image file. It is a special image that can only be used to create temporary ECSs.
You can use a private image to change the OS. For instructions about how to create a private image, see Image Management Service User Guide.
Before creating an image, ensure that you have completed required configurations.
For details, see How Do I Configure an ECS, BMS, or Image File Before I Use It to Create an Image?
  2. Click in the upper left corner and select your region and project.
  3. Click . Under Compute, click Elastic Cloud Server.
  4. In the ECS list, choose More > Manage Image > Create Image in the Operation column.
  5. Configure the following information:
    Table 1 and Table 2 list the parameters in the Image Type and Source and Image Information areas, respectively.
    Table 1 Image type and source
    Type
    Select Create Image.
    Region
    Select a region close to your business.
    If you select an incorrect region here, you can replicate the created image to your desired region. For details, see Replicating Images Across Regions.
    Image Type
    Select System disk image.
    Source
    Click the ECS tab and select an ECS with required configurations.
    Table 2 Image information
    Encryption
    This parameter specifies whether the image will be encrypted. The value is provided by the system and cannot be changed.
    • Only an unencrypted private image can be created from an unencrypted ECS.
    • Only an encrypted private image can be created from an encrypted ECS.
    Name
    Set a name for the image.
    Enterprise Project
    Select an enterprise project from the drop-down list. This parameter is available only if you have enabled enterprise projects or your account is an enterprise account. To enable this function, contact your customer manager.
    An enterprise project provides central management of cloud resources on a project.
    Tag
    (Optional) Set a tag key and a tag value for the image to make identification and management of your images easier.
    (Optional) Enter a description of the image.
  6. Click Next and submit the request.
