Updated on 2026-04-24 GMT+08:00
Viewing Failed Tasks
You can view the details of failed tasks (if there are any) in the Failures area, including the task names and statuses. This section describes how to view failures.
Failure Types
Table 1 lists the types of failures that can be recorded in the Failures area.
Table 1 Failure types
Failure Type
Creation failures
A task failed. For a failed task, the system rolls back the task and displays an error code, for example, Ecs.0013 Insufficient EIP quota.
Operation failures
  • Modifying ECS specifications
    If an ECS specification modification failed, this operation is recorded in Failures.
  1. Log in to the ECS console and access the ECS list page.
  2. View Failures on the right side of common operations above the ECS list.
    Figure 1 Failures
  3. Click the number displayed in the Failures area to view task details.
    • Creation Failures: show the failed ECS creation tasks.
    • Operation Failures: show the tasks with failed operations and error codes, which help you troubleshoot the faults.
