Updated on 2026-04-24 GMT+08:00
Changing Yearly/Monthly to Pay-per-Use
Yearly/Monthly is a prepaid billing mode in which your ECS will be billed based on the required duration. This cost-effective mode is ideal when the duration of ECS usage is predictable.
If you require a more flexible billing mode, in which your ECS will be billed based on usage frequency and duration, you can change the billing mode from yearly/monthly to pay-per-use.
You can change the billing mode from yearly/monthly to pay-per-use in either of the following ways:
  • Change to pay-per-use immediately: The pay-per-use billing mode takes effect immediately.
  • Change to pay-per-use upon expiration: The pay-per-use billing mode takes effect only after the yearly/monthly subscription has expired.
  • You have passed real-name authentication.
  • You can change the billing mode from yearly/monthly to pay-per-use only for ECSs whose status is Provisioned on the Renewals page.
  • The billing modes of products in a solution portfolio cannot be changed from yearly/monthly to pay-per-use.
Change to Pay-per-Use Immediately
  1. Log in to the ECS console and access the ECS list page.
  2. In the ECS list, select one or more ECSs.
  3. In the upper left corner above the ECS list, choose More > Manage Billing > Change to Pay-per-Use Immediately.
  4. In the displayed dialog box, click OK. Then you are switched to Billing Center.
  5. Confirm or select the ECSs for which you want to change the billing mode.
  6. Confirm the refund information and click Change to Pay-Per-Use.
  7. In the displayed dialog box, confirm the resources again and click OK.
Changing to Pay-per-Use upon Expiration (Console)
  3. In the upper left corner above the ECS list, choose More > Manage Billing > Change to Pay-per-Use upon Expiration.
  6. Click Change to Pay-Per-Use.
Change to Pay-per-Use upon Expiration (Billing Center)
  2. On the top navigation bar, choose Billing > Renewal.
    The Renewals page is displayed.
  3. Customize search criteria.
    • On the Pay-per-Use After Expiration tab, you can search for the ECSs whose billing mode has been changed to pay-per-use.
    • On the Manual Renewals, Auto Renewals, and Renewals Canceled tabs, you can also change the billing mode of the ECSs to pay-per-use (taking effect after the subscription expires).
    Figure 1 Renewals
  4. Change the ECS billing mode to pay-per-use after the yearly/monthly subscription expires.
    • Single ECS: Select the ECS for which you want to change the billing mode, and choose More > Change to Pay-per-Use After Expiration in the Operation column.
    • Multiple ECSs: Select the ECSs for which you want to change the billing mode, and click Change to Pay-per-Use After Expiration above the ECS list.
  5. Confirm the change details and click Change to Pay-per-Use.
