Updated on 2025-03-13 GMT+08:00
Changing Pay-per-Use to Yearly/Monthly
  • Pay-per-use: a postpaid billing mode, in which an ECS is billed by usage duration. You can provision or delete such an ECS at any time.
  • Yearly/Monthly: a prepaid billing mode, in which an ECS is billed based on the purchased duration. This mode is more cost-effective than the pay-per-use mode and is suitable for predictable usage.
If you need to use an ECS for a long time, you can change its billing mode from pay-per-use to yearly/monthly to reduce costs by referring to the content in this section.
  • For certain associated resources (such as EVS disks and EIPs), their billing modes can be changed together with the ECS to yearly/monthly.
  • For associated resources whose billing modes cannot be changed together with the ECS to yearly/monthly, they will retain their original billing modes. For details, see Billing Mode Change Rules for Associated Resources.
  • ECSs created using ISO images do not support the change from pay-per-use to yearly/monthly.
Resources associated with ECSs include disks and EIPs. Table 1 and Table 2 show the billing mode change rules for these associated resources.
Table 1 Billing mode change rules for disks attached to an ECS
Disk Type
Billing Mode
Shared
Changed Together with ECS to Yearly/Monthly
Measure
Local disks
N/A
No
N/A
None
DSS/DESS disks
Yearly/Monthly (the same as the storage pool billing mode)
No
N/A
None
EVS disks
Pay-per-use
No
Yes (not supported for extreme SSD V2 disks)
None
EVS disks
Pay-per-use
Yes
No
On the EVS console, change the billing mode of EVS disks from pay-per-use to yearly/monthly.
For details, see Billing for Disks.
EVS disks
Yearly/Monthly
No
No
The billing mode is already yearly/monthly. No actions are required.
EVS disks
Yearly/Monthly
Yes
No
Table 2 Billing mode change rules for EIPs bound to an ECS
Resource
Billing Mode
Billed By
Bandwidth Type
Measure
EIP
Pay-per-use
Bandwidth
Dedicated
Yes
None
EIP
Pay-per-use
Traffic
Dedicated
No
On the EIP console page, change the billing mode from billing by traffic (pay-per-use) to billing by bandwidth (pay-per-use) first and then to yearly/monthly.
For details, see Changing EIP Billing Mode.
EIP
Pay-per-use
Bandwidth
Shared
No
On the EIP console, change the billing mode from pay-per-use to yearly/monthly.
EIP
Yearly/Monthly
Bandwidth
Dedicated or shared
No
  • The selected ECS is billed on a pay-per-use basis.
  • The target ECS must be in Running or Stopped state.
  2. Click in the upper left corner and select your region and project.
  3. Click . Under Compute, choose Elastic Cloud Server.
  4. On the Elastic Cloud Server page, select the target ECS.
  5. Choose More > Change to Yearly/Monthly in the Operation column.
    You can batch change the billing modes of multiple ECSs. To do so, perform the following operations:
    1. Select the target ECSs.
    2. Choose More > Manage Billing > Change to Yearly/Monthly above the ECS list.
  6. Confirm the ECS details, specify the usage duration, and pay for the order.
