Attaching an Existing Non-Shared Disk
This topic describes how to attach an existing non-shared disk to a server and use it as data disk. A non-shared disk can be attached to only one server.
- Disk Sharing: Disabled
- Function: Bootable disk or Data disk
- Status: Available
Bootable disks are the system disks detached from servers. A bootable disk can be re-attached to a server to be used as a system disk or data disk depending on the disk function selected.
- Log in to the console.
- Choose Dedicated Distributed Storage Service > Disks.
The disk list page is displayed.
- Locate the target disk in the list and click Attach in the Operation column.
A disk can be attached to a server to be used as a system disk only when its function is Bootable disk and its status is Available.
- Select the server and then select a device name from the drop-down list. Ensure that the disk and server are in the same AZ.
One device name can be used for one disk only. For how to obtain the disk name in the OS, see FAQ "How Do I Obtain My Disk Name in the ECS OS Using the Device Identifier Provided on the Console?" in the Elastic Cloud Server FAQs.
Return to the disk list page. The disk status is Attaching, indicating that the disk is being attached to a server. When the disk status changes to In-use, the disk is successfully attached.
