- What's New
Service Overview
- DSS Infographics
- What Is DSS?
- Region and AZ
- Storage Pool Types and Performance
- Storage Pool Capacity Description
- DSS Disks
- DSS Three-Copy Redundancy
- Device Types and Usage Instructions
- Shared Disks and Usage Instructions
- Disk Encryption
- Disk Backup
- DSS and Other Services
- Billing
- Permissions
- Constraints
- Change History
Getting Started
- Operation Procedure
- Step 1: Apply for a Storage Pool
- Step 2: Create a Disk
- Step 3: Attach a Disk
Step 4: Initialize a Data Disk
- Introduction to Data Disk Initialization Scenarios and Partition Styles
- Initializing a Data Disk in Windows (Windows Server 2008)
- Initializing a Data Disk in Windows (Windows Server 2016)
- Initializing a Data Disk in Linux (fdisk)
- Initializing a Data Disk in Linux (parted)
- Initializing a Data Disk Greater Than 2 TB in Windows (Windows Server 2008)
- Initializing a Data Disk Greater Than 2 TB in Windows (Windows Server 2012)
- Initializing a Data Disk Greater Than 2 TB in Linux (parted)
- Change History
User Guide
- Permissions Management
- Storage Pool Management
Disk Management
- Detaching a Disk
- Attaching an Existing Disk
- Deleting a Disk
Expanding the Capacity of a Disk
- Introduction to Expansion Scenarios
- Expanding an In-use Disk
- Expanding an Available Disk
- Extending Partitions and File Systems on Windows
- Extending Partitions and File Systems on Linux (fdisk)
- Extending Partitions and File Systems on Linux (parted)
- Extending Partitions and File Systems of a SCSI Data Disk on Linux (fdisk)
- Extending Partitions and File Systems of a System Disk on Linux (fdisk)
- Managing Encrypted Disks
- Managing Shared Disks
- Managing Backups
- Change History
- API Reference
- What Are the Risks of Not Expanding the Storage Pool Capacity?
- How Many Statuses Does a Storage Pool Have?
- How Many Statuses Does a Disk Have?
- Troubleshooting and Impacts on the DSS Usage
- Can I Attach a Disk to Multiple Servers?
- Will Data in the DSS Disk Be Lost When the DSS Disk Is Detached?
- What Should I Do If an Error Occurs on My DSS Disk?
- How Can I Test DSS Disk Performance?
- What Are the Restrictions on Attaching a Disk to an ECS?
- What Are the Precautions for Detaching a Disk from an ECS?
- Why My Disk Cannot Be Attached to a Server?
- Can the Disk Space Usage Be Reduced If I Delete Files on a Server?
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Introduction
Quick Start
- Obtaining the Domain Name
- Obtaining the Region
Management
Disk Management
- Detaching a Disk
- Deleting a Disk
- Performing Post-Expansion Operations for a Windows Disk
- Performing Post-Expansion Operations for a Disk in Linux (fdisk)
- Performing Post-Expansion Operations for a Disk in Linux (parted)
- Performing Post-Expansion Operations for a SCSI Data Disk in Linux (fdisk)
- Performing Post-Expansion Operations for a System Disk in Linux (fdisk)
- Managing an Encrypted Disk
- Managing a Shared Disk
- Managing a Backup
- Change History
Show all
DSS Custom Policies
Custom policies can be created to supplement the system-defined policies of DSS. For the actions supported for custom policies, see Permissions Policies and Supported Actions.
You can create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Edit JSON policies from scratch or based on an existing policy.
For operation details, see Creating a Custom Policy. The following section contains examples of common custom policies.
Example Custom Policies
- Example 1: Authorize a user to query storage pools.
{ "Version": "1.1", "Statement": [ { "Action": [ "dss:pools:get", "dss:pools:list", ], "Effect": "Allow" } ] }
